TMS320F28388D: How to use #define in CLB simulation
Part Number: TMS320F28388D
Hi
I am working with multiple CLB and I do my simulation with GTKwave.
For the moment I use high(N), low(N), rpt(N) and rpt_end. Everything works but I need to generate complex stimulus and I have hundreds of line of high and low.
in spruir8b doc I see that there is a #define for macros.
How can I use it ? Is there examples ?
Sincerely.
Jérôme
  • To clarify, you want to generate complicated input signals to use for your CLB  simulation?
    Are you familiar with the input designer tool that's included in CLB sysconfig?
    thank you,
    Luke
  • Hi Luke
    Thank you for your reply.
    For the moment I use the boundary inputs (Simulation Only) with the custom waveform code in the Tile Design of Sysconfig.
    I generate a UART (8N1) signal at 12.5Mbits/s and I first wish to replace some parts of my code with more friendly values.
    For example, for the moment I use this kind of stimulus (for one byte but I have dozens of bytes):
    low(8) - start bit
    high(8)
    low(8)
    low(8)
    low(8)
    low(8)
    high(8)
    high(8)
    low(8) - 0x86
    high(8) - stop bit
    I would prefer to use something like:
    #define START_BIT (low(8))
    #define STOP_BIT (high(8))
    #define WORD_0x86 (high(8), low(8), low(8), low(8), low(8), high(8), high(8), low(8))
    START_BIT
    WORD_0x86
    STOP_BIT
    Is it possible to do so? This is to simplify the debug of my code (the words in my push fifo reg)
    Sincerely.
    Jérôme
  • Hi Jerome,
    There seems to be support for #define for custom input definitions. Unfortunately I cannot find much documentation on this. I would suggest trying different syntaxes in SysConfig until you don't see an error message. In the meantime I will debug this on my side to determine what the format requirements are.
    Thank you,
    Luke
