Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I'm using SysConfig to configure ePWM signals. Configuration for PWMs looks like this:
The deadband control is based on active high complimentary presets:
When the enable phase shift load is enabled, even thought the phase shift value is 0, the waveform (PWM1A, PWM1B) will become asymmetric.
The code generated by Sysconfig is
EPWM_enablePhaseShiftLoad(PWM1_BASE);
EPWM_setPhaseShift(PWM1_BASE, 0);
vs
EPWM_disablePhaseShiftLoad(PWM1_BASE);
Is this normal/expected? If yes what's the equation for calculating duty cycle of each signal (PWMxA and PWMxB)?
If no, what could be the source of the problem?
