Part Number: TMS320F28379D
Dear all,
Greetings of the day,
I have configured a setup where two DSPs(F28379D) launchpads are interconnected using the CANH, CANL, and ground lines to establish CAN communication. Each DSP board is individually connected to a separate laptop for programming and monitoring purposes. At present, I am working on implementing CAN communication to enable message transmission from one DSP to the other. I am using C2000ware version 5.04 with CCS 12.8.1.00005 version
However, I am currently facing an issue: the messages sent from one DSP do not appear to be received by the other DSP. Even the transmitted message is not showing on the transmitting end CCS.
I have attached the codes for your reference and would appreciate it if you could kindly review it and suggest me possible solution to resolve this issue.
Thank you very much for your time and support.
Sameer
