Other Parts Discussed in Thread: CODECOMPOSER
Hi
I am using the TMS320F2812 for my hardware, Where My device went into locked state Again!!!
It was working fine when I replaced with new part and started working on flash images.
I am using code composer studio 12.8.1.
I my test scenario, I will get continuous interrupt on INT13 external interrupt and I montioring a global variable increment in watch window.
Suddenly code composer studio got hanged and device is resetting contiuously and I tried stopping the debugging it was hanged. I tried loading the image again Code composer studio went into not responding state
and after closing the CCS and open again and I tried loading the Flash Image again and I got device is locked or not connected.
After that i loaded my non bios sample image where it uses only H0SARAM and i have seen the register window, it states like secure bit is set.
This is the second time I facing the Device locked issue .
I have attached the ccs hang log which was present in the path: C:\Users\sivakmu\AppData\Local\Texas Instruments\CCS\ccs1281\0\dmp
Kindly help me look dmp and what caused this issue
My Previous Issue:
TMS320F2812: By using the JTAG XDS200 - Facing the error '-233' (0xffffff17). The title is 'SC_ERR_PATH_BROKEN'. - C2000 microcontrollers forum - C2000︎ microcontrollers - TI E2E support forums
