I downloaded "SPRM800.ZIP" from https://www.ti.com/product/TMS320F280039C#design-tools-simulation , but I found that it contains INSTRUCTION_PRIVATE. I would like to know if there is any documentation describing it.
I do not see INSTRUCTION_PRIVATE in this .bsd file. Can you please clarify what you are referring to?
Allison
Thank you for clarifying. Please allow another day for me to follow up on these items.
Allison
Will do. I'm reaching out to another colleague on this for some input as well, appreciate the patience in the meantime.
Allison
Hello. The PRIVATE is an internal test mode which is not documented or intended for use in the application. Internal means it is a register link which does not control or observe the pins. The JTAG software should understand this and pad it with dummy data as it interprets the BSDL, it is a standard JTAG syntax. You can review JTAG 1149.1 documentation for more details.
