Part Number: TMS320F28P550SJ
Hi Expert
I think GPIO3 pull up should be disable (GPAPUD.GPIO3 = 1) at default in TRM as below, however when connect target in CCS, the GPIO3 pull up display as enable (GPAPUD.GPIO3 = 0), even erase the device whole flash to make sure without firmware running, may I know what is the reason and how to avoid that? because customer use GPIO3 as PWM to drive power stage and cannot allow it turn on by high level signal in beginning.
