Part Number: TMDSCNCD28P55X
Hello TI Team,
I am currently using the TMDSCNCD28P55X control card for development purposes.
I encountered an issue when importing the LED blink project located at:
C:\ti\c2000\C2000Ware_5_05_00_00\device_support\f28p55x\examples\led
into Code Composer Studio (CCS). The project imports successfully, and when I debug the code step-by-step, it works as expected. However, when I run the code continuously, I am unable to track its execution. I have attached a video showing the debugging behavior for your reference.
Below are the versions of the tools I am using:
CCS Version: 20.2.0.12__1.8.0
C2000Ware Version: 5.05.00.00
Please let me know if there’s anything I might be missing or if you have any suggestions to resolve this issue.
// FILE: led_ex1_blinky.c
// TITLE: LED Blinky Example
//! \addtogroup bitfield_example_list
//! <h1> LED Blinky Example </h1>
//! This example demonstrates how to blink a LED.
//! \b External \b Connections \n
//! - None.
//! \b Watch \b Variables \n
//! - None.
// C2000Ware v5.05.00.00
// Copyright (C) 2024 Texas Instruments Incorporated - http://www.ti.com
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "f28x_project.h"
// Defines
#define DEVICE_GPIO_PIN_LED1 31
// Main
void main(void)
// Initialize device clock and peripherals
InitSysCtrl();
// Initialize GPIO and configure the GPIO pin as a push-pull output
InitGpio();
GPIO_SetupPinMux(DEVICE_GPIO_PIN_LED1, GPIO_MUX_CPU1, 0);
GPIO_SetupPinOptions(DEVICE_GPIO_PIN_LED1, GPIO_OUTPUT, GPIO_PUSHPULL);
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
InitPieVectTable();
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
// Loop Forever
for(;;)
// Turn on LED
GPIO_WritePin(DEVICE_GPIO_PIN_LED1, 0);
// Delay for a bit.
DELAY_US(500000);
// Turn off LED
GPIO_WritePin(DEVICE_GPIO_PIN_LED1, 1);
// Delay for a bit.
DELAY_US(500000);
// End of File
