Part Number: TMS320F28388D
I have a project using CPU1 and CM. Each codebase is on separated folders:
. ├── README.md ├── cm │ ├── CM_FLASH │ │ ├── ... │ │ └── cm.out │ └── cmd │ └── flash.cmd ├── cpu1 │ ├── Debug │ │ ├── ... │ │ └── cpu1.out │ └── cmd │ └── flash.cmd ├── debug.launch ├── shared │ ├── .../.cpp │ └── .../.hpp ├── sw-motion.yaml └── target.ccxml
With CCS 12.x I can manage a debug configuration that would:
- Build both subprojects
- Load the flash on each cores
- Start with initial breakpoint
With CCS 20.x it doesn't work the same. I opened as workspace the root folder which contains the two subprojects. I can build each subproject successfully, but I did not find how to configure the launch.
"version": "0.2.0",
"configurations": [
"name": "cm+cpu1",
"type": "ccs-debug",
"request": "launch",
"groupInfo": [
"name": "group",
"cores": [
"cm",
"cpu1"
"syncMode": true
"targetConfig": "$(cwd)/target.ccxml"
"name": "cm",
"projectInfo": {
"name": "motion-cm",
"resourceId": "/motion-cm"
"name": "cpu1",
"projectInfo": {
"name": "motion-cpu1",
"resourceId": "/motion-cpu1"
I don't find how to properly setup this launch.json.
