TMS320F28P650DK: Configuring ePWM to trigger DMA transfer
Part Number: TMS320F28P650DK
Other Parts Discussed in Thread: C2000WARE,
I would like to use the XCMP complex waveform generator mode to configure ePWM waveforms. Currently, I am using DMA to load compare values from memory into the shadow registers of the ePWM module. My goal is to have three shadow registers, one at a time, loaded into the active register of the ePWM.
Right now, I trigger an interrupt when the ePWM1A Time-Base Counter = 0. In the ISR, I:
  1. Locate the next source address in memory for the next set of compare values to be moved to the ePWM shadow registers, and
  2. Enable the ePWM XCMP reload event.
This works, but when I move to higher frequency ePWM waveforms, the interrupt latency becomes too long.
What I would like to achieve is:
  1. Have the DMA automatically reload based on the hardware ePWM trigger, and
  2. Have the DMA automatically increment the source memory location for the next compare values.
I’ve attached/pasted my .c and .syscfg files, where I implemented ePWM to output on three channels.
Could you please advise on the correct configuration to achieve this DMA-driven automatic reload and address increment behavior with XCMP?
#include "driverlib.h"
#include "device.h"
#include "board.h"
#include "c2000ware_libraries.h"
// Globals for XCMP register configuration
#define SHADOW_SETS 3           // 3 shadow register sets (Shadow1, Shadow2, Shadow3)
#define XCMP_PER_SHADOW 18      // 16 values per shadow
#define TOTAL_COMPARE_VALUES (SHADOW_SETS * XCMP_PER_SHADOW)  // Total values per config
#define NUM_CONFIGS 3           // Number of different configurations
// XCMP Compare configurations - using packed structure to match register layout
// Note: The registers XCMP2, XCMP3, XCMP4 are consecutive in memory
uint16_t compareConfigsCH1[NUM_CONFIGS * TOTAL_COMPARE_VALUES] = {
   // Configuration 1
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    100, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    200, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    300, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    400, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    600, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    700, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    800, //XTBPRD_SHDW1
    00, //XTBPRDHR_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    200, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    400, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    600, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    800, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    1000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    1200, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    1400, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    1600, //XTBPRD_SHDW2
    00, //XTBPRDHR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    300, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    600, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    900, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    1200, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    1500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    1800, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    2100, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    2400, //XTBPRD_SHDW3
    00, //XTBPRDHR_SHDW3
    00, //XCMP1_SHDW1
    //Configuration 2
    00, //XCMP1HR_SHDW1
    400, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    800, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    1200, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    1600, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    2000, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    2400, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    2800, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    3200, //XTBPRD_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    500, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1000, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    1500, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    2000, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    2500, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    3000, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    3500, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    4000, //XTBPRD_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    600, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1200, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    1800, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    2400, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    3000, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    3600, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    4200, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    4800, //XTBPRD_SHDW3
    //Configuration 3
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    700, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    1400, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    2100, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    2800, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    3500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    4200, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    4900, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    5600, //XTBPRD_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    800, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1600, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    2400, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    3200, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    4000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    4800, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    5600, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    6400, //XTBPRD_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    900, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1800, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    2700, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    3600, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    4500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    5400, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    6300, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    7200, //XTBPRD_SHDW3
uint16_t compareConfigsCH2[NUM_CONFIGS * TOTAL_COMPARE_VALUES] = {
   // Configuration 1
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    100, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    200, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    300, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    400, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    600, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    700, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    800, //XTBPRD_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    200, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    400, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    600, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    800, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    1000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    1200, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    1400, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    300, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    600, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    900, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    1200, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    1500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    1800, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    2100, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    00, //XCMP1_SHDW1
    //Configuration 2
    00, //XCMP1HR_SHDW1
    400, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    800, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    1200, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    1600, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    2000, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    2400, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    2800, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    500, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1000, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    1500, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    2000, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    2500, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    3000, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    3500, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    600, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1200, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    1800, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    2400, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    3000, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    3600, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    4200, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    //Configuration 3
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    700, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    1400, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    2100, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    2800, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    3500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    4200, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    4900, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    800, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1600, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    2400, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    3200, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    4000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    4800, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    5600, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    900, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1800, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    2700, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    3600, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    4500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    5400, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    6300, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
uint16_t compareConfigsCH3[NUM_CONFIGS * TOTAL_COMPARE_VALUES] = {
   // Configuration 1
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    100, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    200, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    300, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    400, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    600, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    700, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    800, //XTBPRD_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    200, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    400, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    600, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    800, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    1000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    1200, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    1400, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    300, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    600, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    900, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    1200, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    1500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    1800, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    2100, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    00, //XCMP1_SHDW1
    //Configuration 2
    00, //XCMP1HR_SHDW1
    400, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    800, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    1200, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    1600, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    2000, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    2400, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    2800, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    500, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1000, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    1500, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    2000, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    2500, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    3000, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    3500, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    600, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1200, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    1800, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    2400, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    3000, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    3600, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    4200, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
    //Configuration 3
    00, //XCMP1_SHDW1
    00, //XCMP1HR_SHDW1
    700, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW1
    1400, //XCMP3_SHDW1
    00, //XCMP3HR_SHDW1
    2100, //XCMP4_SHDW1
    00, //XCMP4HR_SHDW1
    2800, //XCMP5_SHDW1
    00, //XCMP5HR_SHDW1
    3500, //XCMP6_SHDW1
    00, //XCMP6HR_SHDW1
    4200, //XCMP7_SHDW1
    00, //XCMP7HR_SHDW1
    4900, //XCMP8_SHDW1
    00, //XCMP8HR_SHDW1
    00, //XCMP1_SHDW2
    00, //XCMP1HR_SHDW2
    800, //XCMP2_SHDW1
    00, //XCMP2HR_SHDW2
    1600, //XCMP3_SHDW2
    00, //XCMP3HR_SHDW2
    2400, //XCMP4_SHDW2
    00, //XCMP4HR_SHDW2
    3200, //XCMP5_SHDW2
    00, //XCMP5HR_SHDW2
    4000, //XCMP6_SHDW2
    00, //XCMP6HR_SHDW2
    4800, //XCMP7_SHDW2
    00, //XCMP7HR_SHDW2
    5600, //XCMP8_SHDW2
    00, //XCMP8HR_SHDW2
    00, //XCMP1_SHDW3
    00, //XCMP1HR_SHDW3
    900, //XCMP2_SHDW3
    00, //XCMP2HR_SHDW3
    1800, //XCMP3_SHDW3
    00, //XCMP3HR_SHDW3
    2700, //XCMP4_SHDW3
    00, //XCMP4HR_SHDW3
    3600, //XCMP5_SHDW3
    00, //XCMP5HR_SHDW3
    4500, //XCMP6_SHDW3
    00, //XCMP6HR_SHDW3
    5400, //XCMP7_SHDW3
    00, //XCMP7HR_SHDW3
    6300, //XCMP8_SHDW3
    00, //XCMP8HR_SHDW3
// Offset macros for configuration access
#define COMPARE_CONFIG_OFFSET_CH1(config) ((config) * TOTAL_COMPARE_VALUES)
#define COMPARE_CONFIG_OFFSET_CH2(config) ((config) * TOTAL_COMPARE_VALUES)
#define COMPARE_CONFIG_OFFSET_CH3(config) ((config) * TOTAL_COMPARE_VALUES)
// FIXED: Current configuration pointers - CH2 now points to correct array
uint16_t *currentCompareConfigCH1 = &compareConfigsCH1[COMPARE_CONFIG_OFFSET_CH1(0)];
uint16_t *currentCompareConfigCH2 = &compareConfigsCH2[COMPARE_CONFIG_OFFSET_CH2(0)];
uint16_t *currentCompareConfigCH3 = &compareConfigsCH3[COMPARE_CONFIG_OFFSET_CH3(0)];
// Configuration index tracker
static uint16_t configIndexCH1 = 0;
static uint16_t configIndexCH2 = 0;
static uint16_t configIndexCH3 = 0;
// Place buffers in GSRAM
#pragma DATA_SECTION(compareConfigsCH1, "ramgs0")
#pragma DATA_SECTION(compareConfigsCH2, "ramgs1")
#pragma DATA_SECTION(compareConfigsCH3, "ramgs1")
// Function Prototypes
void initDMACH1(void);
void initDMACH2(void);
void initDMACH3(void);
void initEPWM(uint16_t EPWM_BASE);
__interrupt void dmaCH1ISR(void);
__interrupt void dmaCH2ISR(void);
__interrupt void dmaCH3ISR(void);
void main(void)
    // Initialize device clock and peripherals
    Device_init();
    // Disable pin locks and enable internal pull-ups.
    Device_initGPIO();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    // Register DMA interrupt handlers
    Interrupt_register(INT_DMA_CH1, &dmaCH1ISR);
    Interrupt_register(INT_DMA_CH2, &dmaCH2ISR);
    Interrupt_register(INT_DMA_CH3, &dmaCH3ISR);
    // Disable sync(Freeze clock to PWM as well)
    SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Set EPWM Clock Divider to 1 to feed 200 MHz SysClock.
    SysCtl_setEPWMClockDivider(SYSCTL_EPWMCLK_DIV_1);
    // PinMux and Peripheral Initialization
    Board_init();
    // Initialize DMA for both channels
    initDMACH1();
    initDMACH2();  // NEW: Initialize DMA CH2 for ePWM2
    initDMACH3();
    // Initialize both ePWMs
    initEPWM(myEPWM1_BASE);
    // initEPWM(myEPWM2_BASE);
    // initEPWM(myEPWM3_BASE);
    // Enable sync and clock to PWM
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // C2000Ware Library initialization
    C2000Ware_libraries_init();
    // Enable DMA interrupts
    Interrupt_enable(INT_DMA_CH1);
    Interrupt_enable(INT_DMA_CH2);
    Interrupt_enable(INT_DMA_CH3);
    // Enable Global Interrupt (INTM) and real time interrupt (DBGM)
    EINT;
    ERTM;
    // Reset the prescale counter to ensure clean start
    EPWM_clearADCTriggerFlag(myEPWM1_BASE, EPWM_SOC_A);
    EPWM_clearADCTriggerFlag(myEPWM2_BASE, EPWM_SOC_A);
    EPWM_clearADCTriggerFlag(myEPWM3_BASE, EPWM_SOC_A);
    // Initial Shadow to Active load strobe
    EPWM_enableXLoad(myEPWM1_BASE);
    EPWM_enableXLoad(myEPWM2_BASE);
    EPWM_enableXLoad(myEPWM3_BASE);
    // Start DMA channels
    EALLOW;
    DMA_startChannel(DMA_CH1_BASE);
    DMA_startChannel(DMA_CH2_BASE);
    DMA_startChannel(DMA_CH3_BASE);
    EDIS;
    // Force initial SOCA trigger to start DMA immediately
    // Only trigger ePWM1 since both DMA channels are triggered by ePWM1SOCA
    EPWM_forceADCTrigger(myEPWM1_BASE, EPWM_SOC_A);
    while(1)
    // Configure ePWM for XCMP register operation
    // Most settings are handled by syscfg, but we need to add SOCA for DMA
    // Enable ADC/DMA trigger (SOCA) - only for ePWM1 since it's the master trigger
        EPWM_enableADCTrigger(EPWM_BASE, EPWM_SOC_A);
        // Set trigger source to TBCTR_ZERO for consistent timing
        EPWM_setADCTriggerSource(EPWM_BASE, EPWM_SOC_A, EPWM_SOC_TBCTR_ZERO);
        // Set prescale to trigger once per complete configuration cycle
        EPWM_setADCTriggerEventPrescale(EPWM_BASE, EPWM_SOC_A, 1);
        // Clear any pending flags
        EPWM_clearADCTriggerFlag(EPWM_BASE, EPWM_SOC_A);
    // Initialize DMA controller
    DMA_initController();
    // Calculate the exact register addresses for XCMP Shadow1 registers
    // XCMP2_SHADOW1 register address (0x22U offset from XCMP base)
    uint32_t xcmp2Shadow1Addr = myEPWM1_BASE + EPWM_O_XCMP + EPWM_O_XCMP1_ACTIVE + 0x20U + 1U;
    // DMA CH1 - XCMP Compare Values (Multiple XCMP Shadow registers)
    DMA_configAddresses(DMA_CH1_BASE,
                        (uint16_t *)xcmp2Shadow1Addr,    // Destination (start at XCMP2_SHADOW1)
                        currentCompareConfigCH1);           // Source (start with config0)
    // Burst configuration for XCMP registers with your array structure:
    DMA_configBurst(DMA_CH1_BASE, XCMP_PER_SHADOW, 1, 1);
    // Transfer configuration for complete configuration:
    DMA_configTransfer(DMA_CH1_BASE, SHADOW_SETS, 1, 0x20 - XCMP_PER_SHADOW + 1);
    DMA_configMode(DMA_CH1_BASE, DMA_TRIGGER_EPWM1SOCA,
                   DMA_CFG_ONESHOT_DISABLE | DMA_CFG_CONTINUOUS_ENABLE | DMA_CFG_SIZE_16BIT);
    // Configure interrupts for CH1
    DMA_setInterruptMode(DMA_CH1_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH1_BASE);
    DMA_enableTrigger(DMA_CH1_BASE);
// NEW: DMA CH2 initialization for ePWM2
    // Calculate the exact register addresses for ePWM2 XCMP Shadow1 registers
    uint32_t xcmp2Shadow1Addr = myEPWM2_BASE + EPWM_O_XCMP + EPWM_O_XCMP1_ACTIVE + 0x20U + 1U;
    // DMA CH2 - ePWM2 XCMP Compare Values (Multiple XCMP Shadow registers)
    DMA_configAddresses(DMA_CH2_BASE,
                        (uint16_t *)xcmp2Shadow1Addr,    // Destination (ePWM2 XCMP2_SHADOW1)
                        currentCompareConfigCH2);           // Source (CH2 config array)
    // Burst configuration for XCMP registers:
    DMA_configBurst(DMA_CH2_BASE, XCMP_PER_SHADOW, 1, 1);
    DMA_configTransfer(DMA_CH2_BASE, SHADOW_SETS, 1, 0x20 - XCMP_PER_SHADOW + 1);
    // KEY: Both DMA channels triggered by the same ePWM1 SOCA signal for synchronization
    DMA_configMode(DMA_CH2_BASE, DMA_TRIGGER_EPWM1SOCA,
    // Configure interrupts for CH2
    DMA_setInterruptMode(DMA_CH2_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH2_BASE);
    DMA_enableTrigger(DMA_CH2_BASE);
    uint32_t xcmp2Shadow1Addr = myEPWM3_BASE + EPWM_O_XCMP + EPWM_O_XCMP1_ACTIVE + 0x20U + 1U;
    DMA_configAddresses(DMA_CH3_BASE,
                        (uint16_t *)xcmp2Shadow1Addr,    // Destination (ePWM3 XCMP2_SHADOW1)
                        currentCompareConfigCH3);           // Source (CH3 config array)
    DMA_configBurst(DMA_CH3_BASE, XCMP_PER_SHADOW, 1, 1);
    DMA_configTransfer(DMA_CH3_BASE, SHADOW_SETS, 1, 0x20 - XCMP_PER_SHADOW + 1);
    DMA_configMode(DMA_CH3_BASE, DMA_TRIGGER_EPWM1SOCA,
    DMA_setInterruptMode(DMA_CH3_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH3_BASE);
    DMA_enableTrigger(DMA_CH3_BASE);
// DMA Channel 1 ISR - Triggered once per complete configuration load
    GPIO_writePin(myGPIO1, 1);
    // This ISR executes once per complete configuration
    // All XCMP values have been loaded for ePWM1
    configIndexCH1++;
    if (configIndexCH1 >= NUM_CONFIGS) {
        configIndexCH1 = 0;
    // Calculate new addresses for next complete configuration
    currentCompareConfigCH1 = &compareConfigsCH1[COMPARE_CONFIG_OFFSET_CH1(configIndexCH1)];
    // Update DMA source addresses for next complete configuration transfer
    DMA_configSourceAddress(DMA_CH1_BASE, currentCompareConfigCH1);
    // Enable XLoad to transfer shadow to active registers for ePWM1
    // This activates the newly loaded configuration
    // Clear PIEACK for Group 7 (both DMA CH1 and CH2 are in this group)
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP7);
   GPIO_writePin(myGPIO1, 0);
// NEW: DMA Channel 2 ISR - Handles ePWM2 configuration updates
    // This ISR executes once per complete ePWM2 configuration
    // All XCMP values have been loaded for ePWM2
    configIndexCH2++;
    if (configIndexCH2 >= NUM_CONFIGS) {
        configIndexCH2 = 0;
    currentCompareConfigCH2 = &compareConfigsCH2[COMPARE_CONFIG_OFFSET_CH2(configIndexCH2)];
    DMA_configSourceAddress(DMA_CH2_BASE, currentCompareConfigCH2);
    // Enable XLoad to transfer shadow to active registers for ePWM2
    configIndexCH3++;
    if (configIndexCH3 >= NUM_CONFIGS) {
        configIndexCH3 = 0;
    currentCompareConfigCH3 = &compareConfigsCH3[COMPARE_CONFIG_OFFSET_CH3(configIndexCH3)];
    DMA_configSourceAddress(DMA_CH3_BASE, currentCompareConfigCH3);
 * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
 * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
 * @cliArgs --device "F28P65x" --part "F28P65x_256ZEJ" --package "256ZEJ" --context "CPU1" --product "C2000WARE@6.00.00.00"
 * @v2CliArgs --device "TMS320F28P650DK" --package "256ZEJ" --variant "TMS320F28P650DK9" --context "CPU1" --product "C2000WARE@6.00.00.00"
 * @versions {"tool":"1.24.0+4110"}
 * Import the modules used in this configuration.
const epwm             = scripting.addModule("/driverlib/epwm.js");
const epwm1            = epwm.addInstance();
const epwm2            = epwm.addInstance();
const epwm3            = epwm.addInstance();
const gpio             = scripting.addModule("/driverlib/gpio.js", {}, false);
const gpio1            = gpio.addInstance();
const inputxbar_input  = scripting.addModule("/driverlib/inputxbar_input.js", {}, false);
const inputxbar_input1 = inputxbar_input.addInstance();
const inputxbar_input2 = inputxbar_input.addInstance();
const sysctl           = scripting.addModule("/driverlib/sysctl.js");
 * Write custom configuration values to the imported modules.
epwm.enableAllCode         = true;
epwm.commentOutDefaultCode = true;
epwm1.epwmTimebase_counterMode                        = "EPWM_COUNTER_MODE_UP";
epwm1.epwmTimebase_period                             = 1999;
epwm1.epwmTimebase_syncOutPulseMode                   = ["EPWM_SYNC_OUT_PULSE_ON_ALL"];
epwm1.epwmTimebase_syncInPulseSource                  = "EPWM_SYNC_IN_PULSE_SRC_DISABLE";
epwm1.epwmXCMP_enable                                 = true;
epwm1.epwmCounterCompare_shadowLoadModeCMPC           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm1.epwmCounterCompare_shadowLoadModeCMPD           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm1.epwmXCMP_selectNumberShadowRegisterLevels       = "EPWM_XCMP_XLOADCTL_SHDWLEVEL_3";
epwm1.epwmXCMP_selectLoadMode                         = "EPWM_XCMP_XLOADCTL_LOADMODE_LOADMULTIPLE";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm1.epwmXCMP_RegisterLoad_enable                    = true;
epwm1.epwmActionQualifier_EPWM_AQ_OUTPUT_A_shadowMode = true;
epwm1.epwmActionQualifier_EPWM_AQ_OUTPUT_B_shadowMode = true;
epwm1.epwmCounterCompare_enableShadowLoadModeCMPB     = false;
epwm1.epwmTimebase_hsClockDiv                         = "EPWM_HSCLOCK_DIVIDER_1";
epwm1.epwmXCMP_selectShadowRegisterLevelLoad          = "EPWM_XCMP_XLOADCTL_SHDWBUFPTR_ONE";
epwm1.epwmXCMP_setShadowRegisters1_XTBPRD             = 1000;
epwm1.epwmXCMP_setRegisters_XTBPRD                    = 1000;
epwm1.epwmXCMP_selectAllocationXCMPA_NoSplitorSplit   = "EPWM_XCMP_8_CMPA";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm1.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm1.$name                                           = "myEPWM1";
epwm1.epwm.$assign                                    = "EPWM1";
epwm1.epwm.epwm_aPin.$assign                          = "GPIO0";
epwm1.epwm.epwm_bPin.$assign                          = "GPIO1";
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm1, "epwmCounterCompare_cmpA");
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm1, "epwmCounterCompare_cmpB");
scripting.suppress("When XCMP mode is enabled, EPWM Time Base Period will be set within XCMP Mode", epwm1, "epwmTimebase_period");
epwm2.epwmTimebase_counterMode                        = "EPWM_COUNTER_MODE_UP";
epwm2.epwmTimebase_period                             = 1999;
epwm2.epwmTimebase_syncOutPulseMode                   = ["EPWM_SYNC_OUT_PULSE_ON_ALL"];
epwm2.epwmTimebase_syncInPulseSource                  = "EPWM_SYNC_IN_PULSE_SRC_DISABLE";
epwm2.epwmXCMP_enable                                 = true;
epwm2.epwmCounterCompare_shadowLoadModeCMPC           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm2.epwmCounterCompare_shadowLoadModeCMPD           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm2.epwmXCMP_selectNumberShadowRegisterLevels       = "EPWM_XCMP_XLOADCTL_SHDWLEVEL_3";
epwm2.epwmXCMP_selectLoadMode                         = "EPWM_XCMP_XLOADCTL_LOADMODE_LOADMULTIPLE";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm2.epwmXCMP_RegisterLoad_enable                    = true;
epwm2.epwmActionQualifier_EPWM_AQ_OUTPUT_A_shadowMode = true;
epwm2.epwmActionQualifier_EPWM_AQ_OUTPUT_B_shadowMode = true;
epwm2.epwmCounterCompare_enableShadowLoadModeCMPB     = false;
epwm2.epwmTimebase_hsClockDiv                         = "EPWM_HSCLOCK_DIVIDER_1";
epwm2.epwmXCMP_selectShadowRegisterLevelLoad          = "EPWM_XCMP_XLOADCTL_SHDWBUFPTR_ONE";
epwm2.epwmXCMP_setShadowRegisters1_XTBPRD             = 1000;
epwm2.epwmXCMP_setRegisters_XTBPRD                    = 1000;
epwm2.epwmXCMP_selectAllocationXCMPA_NoSplitorSplit   = "EPWM_XCMP_8_CMPA";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm2.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm2.$name                                           = "myEPWM2";
epwm2.epwm.$assign                                    = "EPWM8";
epwm2.epwm.epwm_aPin.$assign                          = "GPIO99";
epwm2.epwm.epwm_bPin.$assign                          = "GPIO75";
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm2, "epwmCounterCompare_cmpA");
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm2, "epwmCounterCompare_cmpB");
scripting.suppress("When XCMP mode is enabled, EPWM Time Base Period will be set within XCMP Mode", epwm2, "epwmTimebase_period");
epwm3.epwmTimebase_counterMode                        = "EPWM_COUNTER_MODE_UP";
epwm3.epwmTimebase_period                             = 1999;
epwm3.epwmTimebase_syncOutPulseMode                   = ["EPWM_SYNC_OUT_PULSE_ON_ALL"];
epwm3.epwmTimebase_syncInPulseSource                  = "EPWM_SYNC_IN_PULSE_SRC_DISABLE";
epwm3.epwmXCMP_enable                                 = true;
epwm3.epwmCounterCompare_shadowLoadModeCMPC           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm3.epwmCounterCompare_shadowLoadModeCMPD           = "EPWM_COMP_LOAD_ON_CNTR_PERIOD";
epwm3.epwmXCMP_selectNumberShadowRegisterLevels       = "EPWM_XCMP_XLOADCTL_SHDWLEVEL_3";
epwm3.epwmXCMP_selectLoadMode                         = "EPWM_XCMP_XLOADCTL_LOADMODE_LOADMULTIPLE";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP1          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP2          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP3          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP4          = "EPWM_AQ_OUTPUT_LOW";
epwm3.epwmXCMP_RegisterLoad_enable                    = true;
epwm3.epwmActionQualifier_EPWM_AQ_OUTPUT_A_shadowMode = true;
epwm3.epwmActionQualifier_EPWM_AQ_OUTPUT_B_shadowMode = true;
epwm3.epwmCounterCompare_enableShadowLoadModeCMPB     = false;
epwm3.epwmTimebase_hsClockDiv                         = "EPWM_HSCLOCK_DIVIDER_1";
epwm3.epwmXCMP_selectShadowRegisterLevelLoad          = "EPWM_XCMP_XLOADCTL_SHDWBUFPTR_ONE";
epwm3.epwmXCMP_setShadowRegisters1_XTBPRD             = 1000;
epwm3.epwmXCMP_setRegisters_XTBPRD                    = 1000;
epwm3.epwmXCMP_selectAllocationXCMPA_NoSplitorSplit   = "EPWM_XCMP_8_CMPA";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW1_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW2_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP5          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP6          = "EPWM_AQ_OUTPUT_LOW";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP7          = "EPWM_AQ_OUTPUT_HIGH";
epwm3.XCMPA_SHADOW3_OUTPUT_ON_TIMEBASE_XCMP8          = "EPWM_AQ_OUTPUT_LOW";
epwm3.$name                                           = "myEPWM3";
epwm3.epwm.$assign                                    = "EPWM4";
epwm3.epwm.epwm_aPin.$assign                          = "GPIO6";
epwm3.epwm.epwm_bPin.$assign                          = "GPIO7";
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm3, "epwmCounterCompare_cmpA");
scripting.suppress("It is recommended to use a non-zero counter compare value when using shadow to active load of action qualifier A/B control register on TBCTR=0 boundary", epwm3, "epwmCounterCompare_cmpB");
scripting.suppress("When XCMP mode is enabled, EPWM Time Base Period will be set within XCMP Mode", epwm3, "epwmTimebase_period");
gpio1.direction       = "GPIO_DIR_MODE_OUT";
gpio1.$name           = "myGPIO1";
gpio1.gpioPin.$assign = "GPIO21";
inputxbar_input1.$name          = "myINPUTXBARINPUT0";
inputxbar_input1.inputxbarInput = "XBAR_INPUT5";
inputxbar_input1.inputxbarGpio  = "GPIO40";
inputxbar_input2.$name          = "myINPUTXBARINPUT1";
inputxbar_input2.inputxbarInput = "XBAR_INPUT6";
inputxbar_input2.inputxbarGpio  = "GPIO40";
    Let me loop EPWM experts on this.
    Aswin
  • Thank you!
    You would need to setup DMA Channel to be configured to trigger by software and other peripheral triggers events.
    The source of the triggers are mentioned in the F28P65x reference manual, if you need help setting up DMA, let me know I can get DMA expert to help you.
    Normally we would write the updated values on the shadow registers directly and let the shadow loading take care for loading to active registers. Why are you storing these in memory and then writing to registers ?
  • Hi Prarthan,
    Does that mean that I have to use an ISR? My challenge is that I want to generate high-frequency (>= 10 MHz) PWM signals across multiple PWM modules in which the frequency and duty ratio change every period. However, when I include the ISR to push the shadow registers to the active register using EPWM_enableXLoad, I run into trouble.
    If it is possible to speak to a DMA expert, that would be extremely helpful. How could I get in contact with this person?
    I am loading values in from memory because the quantity of complex waveforms I want exceeds what is available in the shadow registers. Do you recommend another technique for doing this?
    If anyone is open to providing some more 1:1 support, please let me know.
  • I am looping in DMA expert on this thread
  • Hi Julia,
    Apologies for the delay. If all the compare values you want to load are stored sequentially in memory, this should be rather simple to do with the DMA. You just need to write the next (sequential) value from the array into the compare shadow register at each trigger, is that correct? For that, you can use a burst size of 1 and transfer size that equals the size of the array. On the source side, the burst step can be 1 to increment through the array addresses and use a wrap size equal to the length of the array so that it starts again at the beginning after a full transfer. The destination side can just constantly write to the same address (burst step and transfer step of 0) and does not need to wrap (wrap size of 65535 - the maximum). Let me know if you have any questions.
    Delaney
