Other Parts Discussed in Thread: SFRA, C2000WARE
Hey.
Im trying to use SFRA in a project.
I can connect using the gui, but even when it connectes, all controls are greyed out.
Im using windows 11 - Language was set to english (united states).
I'll attach the .h/.c files that I use to handle the calls.
In my main() function I call
SFRA_PORT_background();
in every loop.
I am running a pwm at 100kHz frequency, and using the ADC to measure in the middle of the duty cycle, using the DCL_runPI_C7() function pi controller.
Im polling the ADC flag to run the controller when it's done its sample/conversion.
Heres the relevant part of the code that gets run when ADC is done:
in every loop.
// Clear ADC end-of-sequence flag once.
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;
//float ref_ctrl = SFRA_PORT_inject(setpoint); // returns reference + injected perturbation
const float ADC_INV = (1.0f/4096.0f);
float ref_ctrl_pu = SFRA_PORT_inject(setpoint * ADC_INV); // per-unit into SFRA
float ref_ctrl = ref_ctrl_pu * 4096.0f; // back to counts for the PI
// PHASE 1 -----------------------------------------------------------
// 1. Calculate mean of adc sample.
float compare = pwm_compare[ePWM1];
float old_duty_cycle = 1.0f - (inv_period * compare);
float adc_avg = (float)AdcaResultRegs.ADCRESULT1 * old_duty_cycle;
// 2. Do PI calculations and scale.
float pi_output = DCL_runPI_C7(&pi_current1, ref_ctrl, adc_avg); // Run the PI controller.
// 3. Clamp new compare value, and update the array copy
compare = period - (pi_output * period);
pwm_compare[ePWM1] = compare;
EPwm1Regs.CMPA.bit.CMPA = __f32toui16r(compare);
float u_sfra = pi_output; // already 0..1
float y_sfra = adc_avg * ADC_INV; // feedback in per-unit
SFRA_PORT_collect(&u_sfra, &y_sfra);
Any help it getting this utility to work?
#include "sfra_port.h" #include <math.h> // ---------- Config knobs ---------- #define SFRA_START_HZ 10.0f #define SFRA_STOP_HZ 8000.0f #define SFRA_PTS_PER_DECADE 20 // 10/20/40 are typical #define SFRA_INJ_AMPL 0.01f // 1% of normalized ref #define SFRA_SETTLE_SPEED 1 // 0=slowest .. 3=fastest (SDK enum/int) #define SFRA_MAX_POINTS 128 // must be >= actual points // ---------- State ---------- static SFRA_F32 sfra; // response/freq vectors (host reads these) static float h_mag[SFRA_MAX_POINTS]; static float h_phase[SFRA_MAX_POINTS]; static float gh_mag[SFRA_MAX_POINTS]; static float gh_phase[SFRA_MAX_POINTS]; static float cl_mag[SFRA_MAX_POINTS]; static float cl_phase[SFRA_MAX_POINTS]; static float freq[SFRA_MAX_POINTS]; // SCI instance for GUI #define SFRA_GUI_SCI_BASE SCIA_BASE #define SFRA_GUI_BAUD 115200U // compute how many points we’ll actually use static inline int16_t calc_num_points(void) { const float decades = log10f(SFRA_STOP_HZ) - log10f(SFRA_START_HZ); int16_t n = (int16_t)(ceilf(decades * (float)SFRA_PTS_PER_DECADE)) + 1; if (n > SFRA_MAX_POINTS) n = SFRA_MAX_POINTS; return n; } void SFRA_PORT_init(float ctrlISR_Hz) { #if ENABLE_SFRA SFRA_F32_reset(&sfra); const int16_t npts = calc_num_points(); const float fstep = 1.0f / (float)SFRA_PTS_PER_DECADE; // Configure the object SFRA_F32_config(&sfra, /* isrFrequency */ ctrlISR_Hz, /* injectionAmplitude*/ SFRA_INJ_AMPL, /* noFreqPoints */ npts, /* fraSweepStartFreq*/ SFRA_START_HZ, /* freqStep */ fstep, /* h_magVect */ h_mag, /* h_phaseVect */ h_phase, /* gh_magVect */ gh_mag, /* gh_phaseVect */ gh_phase, /* cl_magVect */ cl_mag, /* cl_phaseVect */ cl_phase, /* freqVect */ freq, /* speed */ SFRA_SETTLE_SPEED); // clear any previous results SFRA_F32_resetFreqRespArray(&sfra); // Initialize the frequency vector (log steps) SFRA_F32_initFreqArrayWithLogSteps(&sfra, SFRA_START_HZ, fstep); // ---- GUI SCI setup ---- // Get LSPCLK frequency uint32_t lsp_hz = SysCtl_getLowSpeedClock(DEVICE_SYSCLK_FREQ); SFRA_GUI_config(SFRA_GUI_SCI_BASE, lsp_hz, SFRA_GUI_BAUD, 17, GPIO_17_SCIA_RX, 24, GPIO_24_SCIA_TX, 0, 0, 0, &sfra, 1); #endif } void SFRA_PORT_background(void) { #if ENABLE_SFRA //SCI_writeCharNonBlocking(SFRA_GUI_SCI_BASE, '@'); // Temporary test. SFRA_F32_runBackgroundTask(&sfra); SFRA_GUI_runSerialHostComms(&sfra); #endif }
