Part Number: TMS320F28379D
I developed a test base program to have sci communacation on core 2 and have data exchange with core 1 via IPC. I developed it using register file; then I changed to bitfield to be consistent with the other programs developed by others in the team.
The problem I have is that core 2 cannot write into registers, and when I hover over the registers in the program while I pause the debugger, it does not show the address instead shows .... . It can write into variables and some registers such as IER.
I included F2837xD_GlobalVariableDefs and necessary files as far as I know, and I use default RAM lnk file for cpu2. My map file for cpu2 is as below.
TMS320C2000 Linker PC v22.6.1
>> Linked Thu Oct 16 22:47:10 2025
OUTPUT FILE NAME: <MVP3_Grid_COM_cpu2.out>
ENTRY POINT SYMBOL: "_c_int00" address: 000080cf
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
BEGIN 00000000 00000002 00000000 00000002 RWIX
RAMM0 000000a2 0000035e 0000006c 000002f2 RWIX
RAMLS0 00008000 00000800 000001e7 00000619 RWIX
RAMLS1 00008800 00000800 00000000 00000800 RWIX
RAMLS2 00009000 00000800 00000000 00000800 RWIX
RAMLS3 00009800 00000800 00000000 00000800 RWIX
RAMLS4 0000a000 00000800 00000000 00000800 RWIX
RAMD0 0000b000 00000800 000007fb 00000005 RWIX
RESET 003fffc0 00000002 00000000 00000002 RWIX
PAGE 1:
BOOT_RSVD 00000002 000000a0 000000a0 00000000 RWIX
RAMM1 00000400 000003f8 000003f8 00000000 RWIX
CPU_TIMER1 00000c00 00000008 00000008 00000000 RWIX
CPU_TIMER2 00000c08 00000008 00000008 00000000 RWIX
PIE_CTRL 00000ce0 00000020 00000020 00000000 RWIX
FLASHPUMPSEMAPHORE 00005f80 00000002 00000002 00000000 RWIX
PERIPH 00007000 00001000 00000fd5 0000002b RWIX
RAMLS5 0000a800 00000800 000004b4 0000034c RWIX
RAMD1 0000b800 00000800 00000000 00000800 RWIX
CPU2TOCPU1RAM 0003f800 00000400 00000005 000003fb RWIX
CPU1TOCPU2RAM 0003fc00 00000400 00000088 00000378 RWIX
CANA_MSG_RAM 00049000 00000800 00000000 00000800 RWIX
CANB_MSG_RAM 0004b000 00000800 00000000 00000800 RWIX
DEV_CFG 0005d000 00000180 00000000 00000180 RWIX
CLK_CFG 0005d200 00000100 00000032 000000ce RWIX
CPU_SYS 0005d300 00000100 00000082 0000007e RWIX
DCSM_Z1 0005f000 00000030 00000022 0000000e RWIX
DCSM_Z2 0005f040 00000030 00000022 0000000e RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.cinit 0 000000a2 0000006c
000000a2 00000011 F2837xD_struct.obj (.cinit:_ECAP)
000000b3 0000000e rts2800_fpu32.lib : exit.c.obj (.cinit)
000000c1 0000000b F2837xD_struct.obj (.cinit:_EQEP)
000000cc 0000000b F2837xD_struct.obj (.cinit:_SPI)
000000d7 00000009 F2837xD_struct.obj (.cinit:_SDFM)
000000e0 00000009 main_cpu2.obj (.cinit)
000000e9 00000007 F2837xD_struct.obj (.cinit:_I2C)
000000f0 00000007 F2837xD_struct.obj (.cinit:_MCBSP)
000000f7 00000007 F2837xD_struct.obj (.cinit:_SCI)
000000fe 00000005 rts2800_fpu32.lib : _lock.c.obj (.cinit:__lock)
00000103 00000005 : _lock.c.obj (.cinit:__unlock)
00000108 00000004 F2837xD_sci_io.obj (.cinit)
0000010c 00000002 --HOLE-- [fill = 0]
.reset 0 003fffc0 00000002 DSECT
003fffc0 00000002 rts2800_fpu32.lib : boot28.asm.obj (.reset)
.stack 1 00000400 00000200 UNINITIALIZED
00000400 00000200 --HOLE--
.pinit 0 000000a2 00000000 UNINITIALIZED
DcsmCommonRegsFile
* 1 00000cfa 00000006 UNINITIALIZED
00000cfa 00000006 F2837xD_GlobalVariableDefs.obj (DcsmCommonRegsFile)
.econst 1 0000a800 000001c0
0000a800 000001c0 F2837xD_PieVect.obj (.econst:_PieVectTableInit)
.ebss 1 0000a9c0 00000059 UNINITIALIZED
0000a9c0 00000018 F2837xD_CpuTimers.obj (.ebss)
0000a9d8 0000000e F2837xD_struct.obj (.ebss:_ECAP)
0000a9e6 00000008 F2837xD_struct.obj (.ebss:_EQEP)
0000a9ee 00000008 F2837xD_struct.obj (.ebss:_SPI)
0000a9f6 00000006 F2837xD_struct.obj (.ebss:_SDFM)
0000a9fc 00000004 F2837xD_struct.obj (.ebss:_I2C)
0000aa00 00000006 main_cpu2.obj (.ebss)
0000aa06 00000006 rts2800_fpu32.lib : exit.c.obj (.ebss)
0000aa0c 00000004 F2837xD_struct.obj (.ebss:_MCBSP)
0000aa10 00000004 F2837xD_struct.obj (.ebss:_SCI)
0000aa14 00000002 rts2800_fpu32.lib : _lock.c.obj (.ebss:__lock)
0000aa16 00000002 : _lock.c.obj (.ebss:__unlock)
0000aa18 00000001 F2837xD_sci_io.obj (.ebss)
myCharArraySection2_1
* 1 0003f800 00000005 NOLOAD SECTION
0003f800 00000005 main_cpu2.obj (myCharArraySection2_1)
myCharArraySection1_2
* 1 0003fc00 00000000 UNINITIALIZED
PUTBUFFER
* 1 0003fc00 00000080 UNINITIALIZED
0003fc00 00000080 F2837xD_Ipc_Driver.obj (PUTBUFFER)
PUTWRITEIDX
* 1 0003fc80 00000004 UNINITIALIZED
0003fc80 00000004 F2837xD_Ipc_Driver.obj (PUTWRITEIDX)
GETREADIDX
* 1 0003fc84 00000004 UNINITIALIZED
0003fc84 00000004 F2837xD_Ipc_Driver.obj (GETREADIDX)
GETBUFFER
* 0 0003f800 00000080 DSECT
0003f800 00000080 F2837xD_Ipc_Driver.obj (GETBUFFER)
GETWRITEIDX
* 0 0003f880 00000004 DSECT
0003f880 00000004 F2837xD_Ipc_Driver.obj (GETWRITEIDX)
PUTREADIDX
* 0 0003f884 00000004 DSECT
0003f884 00000004 F2837xD_Ipc_Driver.obj (PUTREADIDX)
.text.1 0 00008000 000001e7
00008000 00000072 main_cpu2.obj (.text:retain)
00008072 0000005d main_cpu2.obj (.text)
000080cf 00000056 rts2800_fpu32.lib : boot28.asm.obj (.text)
00008125 00000028 F2837xD_PieCtrl.obj (.text)
0000814d 00000026 F2837xD_PieVect.obj (.text)
00008173 00000024 rts2800_fpu32.lib : cpy_tbl.c.obj (.text)
00008197 0000001d : memcpy.c.obj (.text)
000081b4 00000018 : ll_aox28.asm.obj (.text)
000081cc 00000012 : args_main.c.obj (.text)
000081de 00000009 : _lock.c.obj (.text)
.text.2 0 0000b000 000007fb
0000b000 00000585 F2837xD_DefaultISR.obj (.text:retain)
0000b585 0000024a F2837xD_SysCtrl.obj (.text)
0000b7cf 00000029 rts2800_fpu32.lib : exit.c.obj (.text)
0000b7f8 00000002 : pre_init.c.obj (.text)
0000b7fa 00000001 : startup.c.obj (.text)
Cla1RegsFile
* 1 00000002 0000003e UNINITIALIZED
00000002 0000003e F2837xD_GlobalVariableDefs.obj (Cla1RegsFile)
Sdfm1RegsFile
* 1 00000040 00000048 UNINITIALIZED
00000040 00000048 F2837xD_GlobalVariableDefs.obj (Sdfm1RegsFile)
DmaClaSrcSelRegsFile
* 1 00000088 0000001a UNINITIALIZED
00000088 0000001a F2837xD_GlobalVariableDefs.obj (DmaClaSrcSelRegsFile)
PieVectTableFile
* 1 00000600 000001c0 UNINITIALIZED
00000600 000001c0 F2837xD_GlobalVariableDefs.obj (PieVectTableFile)
GpioDataRegsFile
* 1 000007c0 00000030 UNINITIALIZED
000007c0 00000030 F2837xD_GlobalVariableDefs.obj (GpioDataRegsFile)
CpuTimer0RegsFile
* 1 000007f0 00000008 UNINITIALIZED
000007f0 00000008 F2837xD_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
* 1 00000c00 00000008 UNINITIALIZED
00000c00 00000008 F2837xD_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
* 1 00000c08 00000008 UNINITIALIZED
00000c08 00000008 F2837xD_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
* 1 00000ce0 0000001a UNINITIALIZED
00000ce0 0000001a F2837xD_GlobalVariableDefs.obj (PieCtrlRegsFile)
Flash0CtrlRegsFile
* 1 00007000 00000182 UNINITIALIZED
00007000 00000182 F2837xD_GlobalVariableDefs.obj (Flash0CtrlRegsFile)
Clb1LogicCfgRegsFile
* 1 00007182 0000003e UNINITIALIZED
00007182 0000003e F2837xD_GlobalVariableDefs.obj (Clb1LogicCfgRegsFile)
CanaRegsFile
* 1 000071c0 00000164 UNINITIALIZED
000071c0 00000164 F2837xD_GlobalVariableDefs.obj (CanaRegsFile)
Cmpss1RegsFile
* 1 00007324 0000001b UNINITIALIZED
00007324 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss1RegsFile)
CanbRegsFile
* 1 00007340 00000164 UNINITIALIZED
00007340 00000164 F2837xD_GlobalVariableDefs.obj (CanbRegsFile)
Cmpss2RegsFile
* 1 000074a4 0000001b UNINITIALIZED
000074a4 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss2RegsFile)
Clb1DataExchRegsFile
* 1 000074c0 00000108 UNINITIALIZED
000074c0 00000108 F2837xD_GlobalVariableDefs.obj (Clb1DataExchRegsFile)
AccessProtectionRegsFile
* 1 000075c8 0000002e UNINITIALIZED
000075c8 0000002e F2837xD_GlobalVariableDefs.obj (AccessProtectionRegsFile)
Emif1ConfigRegsFile
* 1 000075f6 0000000a UNINITIALIZED
000075f6 0000000a F2837xD_GlobalVariableDefs.obj (Emif1ConfigRegsFile)
Clb2DataExchRegsFile
* 1 00007600 00000108 UNINITIALIZED
00007600 00000108 F2837xD_GlobalVariableDefs.obj (Clb2DataExchRegsFile)
WdRegsFile
* 1 00007708 0000002b UNINITIALIZED
00007708 0000002b F2837xD_GlobalVariableDefs.obj (WdRegsFile)
XintRegsFile
* 1 00007733 0000000b UNINITIALIZED
00007733 0000000b F2837xD_GlobalVariableDefs.obj (XintRegsFile)
Clb3DataExchRegsFile
* 1 00007740 00000108 UNINITIALIZED
00007740 00000108 F2837xD_GlobalVariableDefs.obj (Clb3DataExchRegsFile)
Emif1RegsFile
* 1 00007848 00000028 UNINITIALIZED
00007848 00000028 F2837xD_GlobalVariableDefs.obj (Emif1RegsFile)
SciaRegsFile
* 1 00007870 00000010 UNINITIALIZED
00007870 00000010 F2837xD_GlobalVariableDefs.obj (SciaRegsFile)
Clb4DataExchRegsFile
* 1 00007880 00000108 UNINITIALIZED
00007880 00000108 F2837xD_GlobalVariableDefs.obj (Clb4DataExchRegsFile)
Flash0EccRegsFile
* 1 00007988 00000028 UNINITIALIZED
00007988 00000028 F2837xD_GlobalVariableDefs.obj (Flash0EccRegsFile)
ScibRegsFile
* 1 000079b0 00000010 UNINITIALIZED
000079b0 00000010 F2837xD_GlobalVariableDefs.obj (ScibRegsFile)
DmaRegsFile
* 1 000079c0 000000e0 UNINITIALIZED
000079c0 000000e0 F2837xD_GlobalVariableDefs.obj (DmaRegsFile)
Cmpss3RegsFile
* 1 00007aa0 0000001b UNINITIALIZED
00007aa0 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss3RegsFile)
AdcaRegsFile
* 1 00007ac0 0000007c UNINITIALIZED
00007ac0 0000007c F2837xD_GlobalVariableDefs.obj (AdcaRegsFile)
AdcbRegsFile
* 1 00007b40 0000007c UNINITIALIZED
00007b40 0000007c F2837xD_GlobalVariableDefs.obj (AdcbRegsFile)
AdccRegsFile
* 1 00007bc0 0000007c UNINITIALIZED
00007bc0 0000007c F2837xD_GlobalVariableDefs.obj (AdccRegsFile)
AdcdRegsFile
* 1 00007c40 0000007c UNINITIALIZED
00007c40 0000007c F2837xD_GlobalVariableDefs.obj (AdcdRegsFile)
MemCfgRegsFile
* 1 00007cc0 00000076 UNINITIALIZED
00007cc0 00000076 F2837xD_GlobalVariableDefs.obj (MemCfgRegsFile)
Sdfm2RegsFile
* 1 00007d40 00000048 UNINITIALIZED
00007d40 00000048 F2837xD_GlobalVariableDefs.obj (Sdfm2RegsFile)
IpcRegsFile
* 1 00007d88 00000024 UNINITIALIZED
00007d88 00000024 F2837xD_GlobalVariableDefs.obj (IpcRegsFile)
ScicRegsFile
* 1 00007dac 00000010 UNINITIALIZED
00007dac 00000010 F2837xD_GlobalVariableDefs.obj (ScicRegsFile)
Clb1LogicCtrlRegsFile
* 1 00007dc0 00000040 UNINITIALIZED
00007dc0 00000040 F2837xD_GlobalVariableDefs.obj (Clb1LogicCtrlRegsFile)
Clb2LogicCtrlRegsFile
* 1 00007e00 00000040 UNINITIALIZED
00007e00 00000040 F2837xD_GlobalVariableDefs.obj (Clb2LogicCtrlRegsFile)
Clb3LogicCtrlRegsFile
* 1 00007e40 00000040 UNINITIALIZED
00007e40 00000040 F2837xD_GlobalVariableDefs.obj (Clb3LogicCtrlRegsFile)
Clb4LogicCtrlRegsFile
* 1 00007e80 00000040 UNINITIALIZED
00007e80 00000040 F2837xD_GlobalVariableDefs.obj (Clb4LogicCtrlRegsFile)
Clb2LogicCfgRegsFile
* 1 00007ec0 0000003e UNINITIALIZED
00007ec0 0000003e F2837xD_GlobalVariableDefs.obj (Clb2LogicCfgRegsFile)
Clb3LogicCfgRegsFile
* 1 00007f00 0000003e UNINITIALIZED
00007f00 0000003e F2837xD_GlobalVariableDefs.obj (Clb3LogicCfgRegsFile)
Clb4LogicCfgRegsFile
* 1 00007f40 0000003e UNINITIALIZED
00007f40 0000003e F2837xD_GlobalVariableDefs.obj (Clb4LogicCfgRegsFile)
MemoryErrorRegsFile
* 1 00007f80 0000003a UNINITIALIZED
00007f80 0000003a F2837xD_GlobalVariableDefs.obj (MemoryErrorRegsFile)
McbspaRegsFile
* 1 00007fc0 00000024 UNINITIALIZED
00007fc0 00000024 F2837xD_GlobalVariableDefs.obj (McbspaRegsFile)
Cmpss4RegsFile
* 1 00007fe4 0000001b UNINITIALIZED
00007fe4 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss4RegsFile)
McbspbRegsFile
* 1 0000aa19 00000024 UNINITIALIZED
0000aa19 00000024 F2837xD_GlobalVariableDefs.obj (McbspbRegsFile)
EQep1RegsFile
* 1 0000aa40 00000022 UNINITIALIZED
0000aa40 00000022 F2837xD_GlobalVariableDefs.obj (EQep1RegsFile)
Cmpss5RegsFile
* 1 0000aa62 0000001b UNINITIALIZED
0000aa62 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss5RegsFile)
EQep2RegsFile
* 1 0000aa80 00000022 UNINITIALIZED
0000aa80 00000022 F2837xD_GlobalVariableDefs.obj (EQep2RegsFile)
Cmpss6RegsFile
* 1 0000aaa2 0000001b UNINITIALIZED
0000aaa2 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss6RegsFile)
EQep3RegsFile
* 1 0000aac0 00000022 UNINITIALIZED
0000aac0 00000022 F2837xD_GlobalVariableDefs.obj (EQep3RegsFile)
Cmpss7RegsFile
* 1 0000aae2 0000001b UNINITIALIZED
0000aae2 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss7RegsFile)
I2caRegsFile
* 1 0000ab00 00000022 UNINITIALIZED
0000ab00 00000022 F2837xD_GlobalVariableDefs.obj (I2caRegsFile)
Cmpss8RegsFile
* 1 0000ab22 0000001b UNINITIALIZED
0000ab22 0000001b F2837xD_GlobalVariableDefs.obj (Cmpss8RegsFile)
I2cbRegsFile
* 1 0000ab40 00000022 UNINITIALIZED
0000ab40 00000022 F2837xD_GlobalVariableDefs.obj (I2cbRegsFile)
ECap1RegsFile
* 1 0000ab62 0000001a UNINITIALIZED
0000ab62 0000001a F2837xD_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
* 1 0000ab80 0000001a UNINITIALIZED
0000ab80 0000001a F2837xD_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
* 1 0000ab9a 0000001a UNINITIALIZED
0000ab9a 0000001a F2837xD_GlobalVariableDefs.obj (ECap3RegsFile)
ECap4RegsFile
* 1 0000abc0 0000001a UNINITIALIZED
0000abc0 0000001a F2837xD_GlobalVariableDefs.obj (ECap4RegsFile)
ECap5RegsFile
* 1 0000abda 0000001a UNINITIALIZED
0000abda 0000001a F2837xD_GlobalVariableDefs.obj (ECap5RegsFile)
ECap6RegsFile
* 1 0000ac00 0000001a UNINITIALIZED
0000ac00 0000001a F2837xD_GlobalVariableDefs.obj (ECap6RegsFile)
AdcaResultRegsFile
* 1 0000ac1a 00000018 UNINITIALIZED
0000ac1a 00000018 F2837xD_GlobalVariableDefs.obj (AdcaResultRegsFile)
AdcbResultRegsFile
* 1 0000ac40 00000018 UNINITIALIZED
0000ac40 00000018 F2837xD_GlobalVariableDefs.obj (AdcbResultRegsFile)
AdccResultRegsFile
* 1 0000ac58 00000018 UNINITIALIZED
0000ac58 00000018 F2837xD_GlobalVariableDefs.obj (AdccResultRegsFile)
AdcdResultRegsFile
* 1 0000ac80 00000018 UNINITIALIZED
0000ac80 00000018 F2837xD_GlobalVariableDefs.obj (AdcdResultRegsFile)
DcsmZ1RegsFile
* 1 0005f000 00000022 UNINITIALIZED
0005f000 00000022 F2837xD_GlobalVariableDefs.obj (DcsmZ1RegsFile)
DcsmZ2RegsFile
* 1 0005f040 00000022 UNINITIALIZED
0005f040 00000022 F2837xD_GlobalVariableDefs.obj (DcsmZ2RegsFile)
ClkCfgRegsFile
* 1 0005d200 00000032 UNINITIALIZED
0005d200 00000032 F2837xD_GlobalVariableDefs.obj (ClkCfgRegsFile)
CpuSysRegsFile
* 1 0005d300 00000082 UNINITIALIZED
0005d300 00000082 F2837xD_GlobalVariableDefs.obj (CpuSysRegsFile)
FlashPumpSemaphoreRegsFile
* 1 00005f80 00000002 UNINITIALIZED
00005f80 00000002 F2837xD_GlobalVariableDefs.obj (FlashPumpSemaphoreRegsFile)
RomPrefetchRegsFile
* 1 0000773e 00000002 UNINITIALIZED
0000773e 00000002 F2837xD_GlobalVariableDefs.obj (RomPrefetchRegsFile)
DacaRegsFile
* 1 00007d36 00000007 UNINITIALIZED
00007d36 00000007 F2837xD_GlobalVariableDefs.obj (DacaRegsFile)
DacbRegsFile
* 1 0000abb4 00000007 UNINITIALIZED
0000abb4 00000007 F2837xD_GlobalVariableDefs.obj (DacbRegsFile)
DaccRegsFile
* 1 0000abf4 00000007 UNINITIALIZED
0000abf4 00000007 F2837xD_GlobalVariableDefs.obj (DaccRegsFile)
NmiIntruptRegsFile
* 1 0000ac32 00000007 UNINITIALIZED
0000ac32 00000007 F2837xD_GlobalVariableDefs.obj (NmiIntruptRegsFile)
ScidRegsFile
* 1 0000ac70 00000010 UNINITIALIZED
0000ac70 00000010 F2837xD_GlobalVariableDefs.obj (ScidRegsFile)
SpiaRegsFile
* 1 0000ac98 00000010 UNINITIALIZED
0000ac98 00000010 F2837xD_GlobalVariableDefs.obj (SpiaRegsFile)
SpibRegsFile
* 1 0000aca8 00000010 UNINITIALIZED
0000aca8 00000010 F2837xD_GlobalVariableDefs.obj (SpibRegsFile)
SpicRegsFile
* 1 0000acc0 00000010 UNINITIALIZED
0000acc0 00000010 F2837xD_GlobalVariableDefs.obj (SpicRegsFile)
UidRegsFile
* 1 0000acd0 00000010 UNINITIALIZED
0000acd0 00000010 F2837xD_GlobalVariableDefs.obj (UidRegsFile)
MODULE SUMMARY
Module code initialized data uninitialized data
main_cpu2.obj 207 9 11
Total: 207 9 11
.\BSP\
F2837xD_GlobalVariableDefs.obj 0 0 5682
F2837xD_DefaultISR.obj 1413 0 0
F2837xD_SysCtrl.obj 586 0 0
F2837xD_PieVect.obj 38 448 0
F2837xD_Ipc_Driver.obj 0 0 136
F2837xD_struct.obj 0 69 48
F2837xD_PieCtrl.obj 40 0 0
F2837xD_CpuTimers.obj 0 0 24
F2837xD_sci_io.obj 0 4 1
Total: 2077 521 5891
C:/ti/ccs1281/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/lib/rts2800_fpu32.lib
boot28.asm.obj 86 0 0
exit.c.obj 41 14 6
cpy_tbl.c.obj 36 0 0
memcpy.c.obj 29 0 0
ll_aox28.asm.obj 24 0 0
_lock.c.obj 9 10 4
args_main.c.obj 18 0 0
pre_init.c.obj 2 0 0
startup.c.obj 1 0 0
Total: 246 24 10
Stack: 0 0 512
Grand Total: 2530 554 6424
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address data page name
00000002 0 (00000000) _Cla1Regs
00000040 1 (00000040) _Sdfm1Regs
00000088 2 (00000080) _DmaClaSrcSelRegs
00000400 10 (00000400) __stack
00000600 18 (00000600) _PieVectTable
000007c0 1f (000007c0) _GpioDataRegs
000007f0 1f (000007c0) _CpuTimer0Regs
00000c00 30 (00000c00) _CpuTimer1Regs
00000c08 30 (00000c00) _CpuTimer2Regs
00000ce0 33 (00000cc0) _PieCtrlRegs
00000cfa 33 (00000cc0) _DcsmCommonRegs
00005f80 17e (00005f80) _FlashPumpSemaphoreRegs
00007000 1c0 (00007000) _Flash0CtrlRegs
00007182 1c6 (00007180) _Clb1LogicCfgRegs
000071c0 1c7 (000071c0) _CanaRegs
00007324 1cc (00007300) _Cmpss1Regs
00007340 1cd (00007340) _CanbRegs
000074a4 1d2 (00007480) _Cmpss2Regs
000074c0 1d3 (000074c0) _Clb1DataExchRegs
000075c8 1d7 (000075c0) _AccessProtectionRegs
000075f6 1d7 (000075c0) _Emif1ConfigRegs
00007600 1d8 (00007600) _Clb2DataExchRegs
00007708 1dc (00007700) _WdRegs
00007733 1dc (00007700) _XintRegs
0000773e 1dc (00007700) _RomPrefetchRegs
00007740 1dd (00007740) _Clb3DataExchRegs
00007848 1e1 (00007840) _Emif1Regs
00007870 1e1 (00007840) _SciaRegs
00007880 1e2 (00007880) _Clb4DataExchRegs
00007988 1e6 (00007980) _Flash0EccRegs
000079b0 1e6 (00007980) _ScibRegs
000079c0 1e7 (000079c0) _DmaRegs
00007aa0 1ea (00007a80) _Cmpss3Regs
00007ac0 1eb (00007ac0) _AdcaRegs
00007b40 1ed (00007b40) _AdcbRegs
00007bc0 1ef (00007bc0) _AdccRegs
00007c40 1f1 (00007c40) _AdcdRegs
00007cc0 1f3 (00007cc0) _MemCfgRegs
00007d36 1f4 (00007d00) _DacaRegs
00007d40 1f5 (00007d40) _Sdfm2Regs
00007d88 1f6 (00007d80) _IpcRegs
00007dac 1f6 (00007d80) _ScicRegs
00007dc0 1f7 (00007dc0) _Clb1LogicCtrlRegs
00007e00 1f8 (00007e00) _Clb2LogicCtrlRegs
00007e40 1f9 (00007e40) _Clb3LogicCtrlRegs
00007e80 1fa (00007e80) _Clb4LogicCtrlRegs
00007ec0 1fb (00007ec0) _Clb2LogicCfgRegs
00007f00 1fc (00007f00) _Clb3LogicCfgRegs
00007f40 1fd (00007f40) _Clb4LogicCfgRegs
00007f80 1fe (00007f80) _MemoryErrorRegs
00007fc0 1ff (00007fc0) _McbspaRegs
00007fe4 1ff (00007fc0) _Cmpss4Regs
0000a800 2a0 (0000a800) _PieVectTableInit
0000a9c0 2a7 (0000a9c0) _CpuTimer0
0000a9c8 2a7 (0000a9c0) _CpuTimer1
0000a9d0 2a7 (0000a9c0) _CpuTimer2
0000a9d8 2a7 (0000a9c0) _ECAP
0000a9e6 2a7 (0000a9c0) _EQEP
0000a9ee 2a7 (0000a9c0) _SPI
0000a9f6 2a7 (0000a9c0) _SDFM
0000a9fc 2a7 (0000a9c0) _I2C
0000aa00 2a8 (0000aa00) _rxComplete
0000aa01 2a8 (0000aa00) _i
0000aa02 2a8 (0000aa00) _J
0000aa03 2a8 (0000aa00) _fifoCount
0000aa04 2a8 (0000aa00) _myArrayFB
0000aa06 2a8 (0000aa00) ___TI_enable_exit_profile_output
0000aa08 2a8 (0000aa00) ___TI_cleanup_ptr
0000aa0a 2a8 (0000aa00) ___TI_dtors_ptr
0000aa0c 2a8 (0000aa00) _MCBSP
0000aa10 2a8 (0000aa00) _SCI
0000aa14 2a8 (0000aa00) __lock
0000aa16 2a8 (0000aa00) __unlock
0000aa18 2a8 (0000aa00) _deviceOpen
0000aa19 2a8 (0000aa00) _McbspbRegs
0000aa40 2a9 (0000aa40) _EQep1Regs
0000aa62 2a9 (0000aa40) _Cmpss5Regs
0000aa80 2aa (0000aa80) _EQep2Regs
0000aaa2 2aa (0000aa80) _Cmpss6Regs
0000aac0 2ab (0000aac0) _EQep3Regs
0000aae2 2ab (0000aac0) _Cmpss7Regs
0000ab00 2ac (0000ab00) _I2caRegs
0000ab22 2ac (0000ab00) _Cmpss8Regs
0000ab40 2ad (0000ab40) _I2cbRegs
0000ab62 2ad (0000ab40) _ECap1Regs
0000ab80 2ae (0000ab80) _ECap2Regs
0000ab9a 2ae (0000ab80) _ECap3Regs
0000abb4 2ae (0000ab80) _DacbRegs
0000abc0 2af (0000abc0) _ECap4Regs
0000abda 2af (0000abc0) _ECap5Regs
0000abf4 2af (0000abc0) _DaccRegs
0000ac00 2b0 (0000ac00) _ECap6Regs
0000ac1a 2b0 (0000ac00) _AdcaResultRegs
0000ac32 2b0 (0000ac00) _NmiIntruptRegs
0000ac40 2b1 (0000ac40) _AdcbResultRegs
0000ac58 2b1 (0000ac40) _AdccResultRegs
0000ac70 2b1 (0000ac40) _ScidRegs
0000ac80 2b2 (0000ac80) _AdcdResultRegs
0000ac98 2b2 (0000ac80) _SpiaRegs
0000aca8 2b2 (0000ac80) _SpibRegs
0000acc0 2b3 (0000acc0) _SpicRegs
0000acd0 2b3 (0000acc0) _UidRegs
0003f800 fe0 (0003f800) _g_asIPCCPU1toCPU2Buffers
0003f800 fe0 (0003f800) _rxData
0003f880 fe2 (0003f880) _g_usGetWriteIndexes
0003f884 fe2 (0003f880) _g_usPutReadIndexes
0003fc00 ff0 (0003fc00) _g_asIPCCPU2toCPU1Buffers
0003fc80 ff2 (0003fc80) _g_usPutWriteIndexes
0003fc84 ff2 (0003fc80) _g_usGetReadIndexes
0005d200 1748 (0005d200) _ClkCfgRegs
0005d300 174c (0005d300) _CpuSysRegs
0005f000 17c0 (0005f000) _DcsmZ1Regs
0005f040 17c1 (0005f040) _DcsmZ2Regs
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page address name
abs ffffffff .text
0 0000b7cf C$$EXIT
0 000081b4 LL$$AND
0 000081bc LL$$OR
0 000081c4 LL$$XOR
0 0000b0be _ADCA1_ISR
0 0000b33e _ADCA2_ISR
0 0000b348 _ADCA3_ISR
0 0000b352 _ADCA4_ISR
0 0000b334 _ADCA_EVT_ISR
0 0000b0c8 _ADCB1_ISR
0 0000b366 _ADCB2_ISR
0 0000b370 _ADCB3_ISR
0 0000b37a _ADCB4_ISR
0 0000b35c _ADCB_EVT_ISR
0 0000b0d2 _ADCC1_ISR
0 0000b4ce _ADCC2_ISR
0 0000b4d8 _ADCC3_ISR
0 0000b4e2 _ADCC4_ISR
0 0000b4c4 _ADCC_EVT_ISR
0 0000b0f0 _ADCD1_ISR
0 0000b4f6 _ADCD2_ISR
0 0000b500 _ADCD3_ISR
0 0000b50a _ADCD4_ISR
0 0000b4ec _ADCD_EVT_ISR
0 0000b546 _AUX_PLL_SLIP_ISR
1 000075c8 _AccessProtectionRegs
1 00007ac0 _AdcaRegs
1 0000ac1a _AdcaResultRegs
1 00007b40 _AdcbRegs
1 0000ac40 _AdcbResultRegs
1 00007bc0 _AdccRegs
1 0000ac58 _AdccResultRegs
1 00007c40 _AdcdRegs
1 0000ac80 _AdcdResultRegs
0 0000b7ab _AuxAuxClkSel
0 0000b795 _AuxIntOsc2Sel
0 0000b79f _AuxXtalOscSel
0 0000b30c _CANA0_ISR
0 0000b316 _CANA1_ISR
0 0000b320 _CANB0_ISR
0 0000b32a _CANB1_ISR
0 0000b384 _CLA1_1_ISR
0 0000b38e _CLA1_2_ISR
0 0000b398 _CLA1_3_ISR
0 0000b3a2 _CLA1_4_ISR
0 0000b3ac _CLA1_5_ISR
0 0000b3b6 _CLA1_6_ISR
0 0000b3c0 _CLA1_7_ISR
0 0000b3ca _CLA1_8_ISR
0 0000b550 _CLA_OVERFLOW_ISR
0 0000b55a _CLA_UNDERFLOW_ISR
1 000071c0 _CanaRegs
1 00007340 _CanbRegs
1 00000002 _Cla1Regs
1 000074c0 _Clb1DataExchRegs
1 00007182 _Clb1LogicCfgRegs
1 00007dc0 _Clb1LogicCtrlRegs
1 00007600 _Clb2DataExchRegs
1 00007ec0 _Clb2LogicCfgRegs
1 00007e00 _Clb2LogicCtrlRegs
1 00007740 _Clb3DataExchRegs
1 00007f00 _Clb3LogicCfgRegs
1 00007e40 _Clb3LogicCtrlRegs
1 00007880 _Clb4DataExchRegs
1 00007f40 _Clb4LogicCfgRegs
1 00007e80 _Clb4LogicCtrlRegs
1 0005d200 _ClkCfgRegs
1 00007324 _Cmpss1Regs
1 000074a4 _Cmpss2Regs
1 00007aa0 _Cmpss3Regs
1 00007fe4 _Cmpss4Regs
1 0000aa62 _Cmpss5Regs
1 0000aaa2 _Cmpss6Regs
1 0000aae2 _Cmpss7Regs
1 0000ab22 _Cmpss8Regs
1 0005d300 _CpuSysRegs
1 0000a9c0 _CpuTimer0
1 000007f0 _CpuTimer0Regs
1 0000a9c8 _CpuTimer1
1 00000c00 _CpuTimer1Regs
1 0000a9d0 _CpuTimer2
1 00000c08 _CpuTimer2Regs
0 0000b740 _CsmUnlock
0 0000b014 _DATALOG_ISR
0 0000b258 _DMA_CH1_ISR
0 0000b262 _DMA_CH2_ISR
0 0000b26c _DMA_CH3_ISR
0 0000b276 _DMA_CH4_ISR
0 0000b280 _DMA_CH5_ISR
0 0000b28a _DMA_CH6_ISR
1 00007d36 _DacaRegs
1 0000abb4 _DacbRegs
1 0000abf4 _DaccRegs
1 00000cfa _DcsmCommonRegs
1 0005f000 _DcsmZ1Regs
1 0005f040 _DcsmZ2Regs
0 0000b643 _DisableDog
0 0000b604 _DisablePeripheralClocks
1 00000088 _DmaClaSrcSelRegs
1 000079c0 _DmaRegs
1 0000a9d8 _ECAP
0 0000b1ae _ECAP1_ISR
0 0000b1b8 _ECAP2_ISR
0 0000b1c2 _ECAP3_ISR
0 0000b1cc _ECAP4_ISR
0 0000b1d6 _ECAP5_ISR
0 0000b1e0 _ECAP6_ISR
1 0000ab62 _ECap1Regs
1 0000ab80 _ECap2Regs
1 0000ab9a _ECap3Regs
1 0000abc0 _ECap4Regs
1 0000abda _ECap5Regs
1 0000ac00 _ECap6Regs
0 0000b514 _EMIF_ERROR_ISR
0 0000b56e _EMPTY_ISR
0 0000b028 _EMU_ISR
0 0000b46a _EPWM10_ISR
0 0000b442 _EPWM10_TZ_ISR
0 0000b474 _EPWM11_ISR
0 0000b44c _EPWM11_TZ_ISR
0 0000b47e _EPWM12_ISR
0 0000b456 _EPWM12_TZ_ISR
0 0000b15e _EPWM1_ISR
0 0000b10e _EPWM1_TZ_ISR
0 0000b168 _EPWM2_ISR
0 0000b118 _EPWM2_TZ_ISR
0 0000b172 _EPWM3_ISR
0 0000b122 _EPWM3_TZ_ISR
0 0000b17c _EPWM4_ISR
0 0000b12c _EPWM4_TZ_ISR
0 0000b186 _EPWM5_ISR
0 0000b136 _EPWM5_TZ_ISR
0 0000b190 _EPWM6_ISR
0 0000b140 _EPWM6_TZ_ISR
0 0000b19a _EPWM7_ISR
0 0000b14a _EPWM7_TZ_ISR
0 0000b1a4 _EPWM8_ISR
0 0000b154 _EPWM8_TZ_ISR
0 0000b460 _EPWM9_ISR
0 0000b438 _EPWM9_TZ_ISR
1 0000a9e6 _EQEP
0 0000b1ea _EQEP1_ISR
0 0000b1f4 _EQEP2_ISR
0 0000b1fe _EQEP3_ISR
1 0000aa40 _EQep1Regs
1 0000aa80 _EQep2Regs
1 0000aac0 _EQep3Regs
1 000075f6 _Emif1ConfigRegs
1 00007848 _Emif1Regs
0 00008144 _EnableInterrupts
0 0000b528 _FLASH_CORRECTABLE_ERROR_ISR
0 0000b3fc _FPU_OVERFLOW_ISR
0 0000b406 _FPU_UNDERFLOW_ISR
1 00007000 _Flash0CtrlRegs
1 00007988 _Flash0EccRegs
1 00005f80 _FlashPumpSemaphoreRegs
1 000007c0 _GpioDataRegs
0 0000b7c9 _HALT
0 0000b7cc _HIB
1 0000a9fc _I2C
0 0000b29e _I2CA_FIFO_ISR
0 0000b294 _I2CA_ISR
0 0000b2b2 _I2CB_FIFO_ISR
0 0000b2a8 _I2CB_ISR
1 0000ab00 _I2caRegs
1 0000ab40 _I2cbRegs
0 0000b7b5 _IDLE
0 0000b03c _ILLEGAL_ISR
0 0000b410 _IPC0_ISR
0 0000b41a _IPC1_ISR
0 0000b424 _IPC2_ISR
0 0000b42e _IPC3_ISR
0 0000b651 _InitAuxPll
0 0000b58a _InitPeripheralClocks
0 00008125 _InitPieCtrl
0 0000814d _InitPieVectTable
0 0000b585 _InitSysCtrl
1 00007d88 _IpcRegs
1 0000aa02 _J
1 0000aa0c _MCBSP
0 0000b230 _MCBSPA_RX_ISR
0 0000b23a _MCBSPA_TX_ISR
0 0000b244 _MCBSPB_RX_ISR
0 0000b24e _MCBSPB_TX_ISR
1 00007fc0 _McbspaRegs
1 0000aa19 _McbspbRegs
1 00007cc0 _MemCfgRegs
1 00007f80 _MemoryErrorRegs
0 0000b032 _NMI_ISR
0 0000b57b _NOTUSED_ISR
1 0000ac32 _NmiIntruptRegs
0 0000b564 _PIE_RESERVED_ISR
1 00000ce0 _PieCtrlRegs
1 00000600 _PieVectTable
1 0000a800 _PieVectTableInit
0 0000b532 _RAM_ACCESS_VIOLATION_ISR
0 0000b51e _RAM_CORRECTABLE_ERROR_ISR
0 0000b01e _RTOS_ISR
0 0000b62b _ReleaseFlashPump
1 0000773e _RomPrefetchRegs
1 0000aa10 _SCI
0 0000b2e4 _SCIA_RX_ISR
0 0000b2ee _SCIA_TX_ISR
0 0000b2f8 _SCIB_RX_ISR
0 0000b302 _SCIB_TX_ISR
0 0000b2bc _SCIC_RX_ISR
0 0000b2c6 _SCIC_TX_ISR
0 0000b2d0 _SCID_RX_ISR
0 0000b2da _SCID_TX_ISR
0 0000b488 _SD1_ISR
0 0000b492 _SD2_ISR
1 0000a9f6 _SDFM
1 0000a9ee _SPI
0 0000b208 _SPIA_RX_ISR
0 0000b212 _SPIA_TX_ISR
0 0000b21c _SPIB_RX_ISR
0 0000b226 _SPIB_TX_ISR
0 0000b49c _SPIC_RX_ISR
0 0000b4a6 _SPIC_TX_ISR
0 0000b7be _STANDBY
0 0000b53c _SYS_PLL_SLIP_ISR
1 00007870 _SciaRegs
1 000079b0 _ScibRegs
1 00007dac _ScicRegs
1 0000ac70 _ScidRegs
1 00000040 _Sdfm1Regs
1 00007d40 _Sdfm2Regs
0 0000b61c _SeizeFlashPump
0 0000b635 _ServiceDog
1 0000ac98 _SpiaRegs
1 0000aca8 _SpibRegs
1 0000acc0 _SpicRegs
0 0000b761 _SysIntOsc1Sel
0 0000b771 _SysIntOsc2Sel
0 0000b785 _SysXtalOscSel
0 0000b0fa _TIMER0_ISR
0 0000b000 _TIMER1_ISR
0 0000b00a _TIMER2_ISR
0 00008041 _TXFILL_IPC
0 0000b4b0 _UPPA_ISR
0 0000b4ba _USBA_ISR
0 0000b0a0 _USER10_ISR
0 0000b0aa _USER11_ISR
0 0000b0b4 _USER12_ISR
0 0000b046 _USER1_ISR
0 0000b050 _USER2_ISR
0 0000b05a _USER3_ISR
0 0000b064 _USER4_ISR
0 0000b06e _USER5_ISR
0 0000b078 _USER6_ISR
0 0000b082 _USER7_ISR
0 0000b08c _USER8_ISR
0 0000b096 _USER9_ISR
1 0000acd0 _UidRegs
0 0000b3f2 _VCU_ISR
0 0000b104 _WAKE_ISR
1 00007708 _WdRegs
0 0000b0dc _XINT1_ISR
0 0000b0e6 _XINT2_ISR
0 0000b3d4 _XINT3_ISR
0 0000b3de _XINT4_ISR
0 0000b3e8 _XINT5_ISR
1 00007733 _XintRegs
1 00000600 __STACK_END
abs 00000200 __STACK_SIZE
1 0000aa08 ___TI_cleanup_ptr
1 0000aa0a ___TI_dtors_ptr
1 0000aa06 ___TI_enable_exit_profile_output
abs ffffffff ___TI_pprof_out_hndl
abs ffffffff ___TI_prof_data_size
abs ffffffff ___TI_prof_data_start
abs ffffffff ___binit__
abs ffffffff ___c_args__
0 000000a2 ___cinit__
abs ffffffff ___etext__
abs ffffffff ___pinit__
abs ffffffff ___text__
0 000081cc __args_main
1 0000aa14 __lock
0 000081e6 __nop
0 000081e2 __register_lock
0 000081de __register_unlock
1 00000400 __stack
0 0000b7fa __system_post_cinit
0 0000b7f8 __system_pre_init
1 0000aa16 __unlock
0 0000b7cf _abort
0 000080cf _c_int00
0 00008173 _copy_in
1 0000aa18 _deviceOpen
0 0000b7d1 _exit
1 0000aa03 _fifoCount
0 0003f800 _g_asIPCCPU1toCPU2Buffers
1 0003fc00 _g_asIPCCPU2toCPU1Buffers
1 0003fc84 _g_usGetReadIndexes
0 0003f880 _g_usGetWriteIndexes
0 0003f884 _g_usPutReadIndexes
1 0003fc80 _g_usPutWriteIndexes
1 0000aa01 _i
0 00008072 _main
0 00008197 _memcpy
1 0000aa04 _myArrayFB
1 0000aa00 _rxComplete
1 0003f800 _rxData
0 00008000 _scicRxFIFOISR
abs ffffffff binit
0 000000a2 cinit
abs ffffffff etext
abs ffffffff pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
page address name
0 000000a2 cinit
0 00008072 _main
0 000080cf _c_int00
0 00008173 _copy_in
0 00008197 _memcpy
0 000081b4 LL$$AND
0 000081bc LL$$OR
0 000081c4 LL$$XOR
0 000081e6 __nop
0 0000b028 _EMU_ISR
0 0000b032 _NMI_ISR
0 0000b3f2 _VCU_ISR
0 0000b488 _SD1_ISR
0 0000b492 _SD2_ISR
0 0000b7b5 _IDLE
0 0000b7be _STANDBY
0 0000b7c9 _HALT
0 0000b7cc _HIB
0 0000b7cf C$$EXIT
0 0000b7cf _abort
0 0000b7d1 _exit
1 00000400 __stack
1 00007708 _WdRegs
1 000079c0 _DmaRegs
1 00007d88 _IpcRegs
1 0000a9d8 _ECAP
1 0000a9e6 _EQEP
1 0000a9ee _SPI
1 0000a9f6 _SDFM
1 0000a9fc _I2C
1 0000aa01 _i
1 0000aa02 _J
1 0000aa0c _MCBSP
1 0000aa10 _SCI
1 0000aa14 __lock
1 0000aa16 __unlock
1 0000acd0 _UidRegs
1 0003f800 _rxData
abs ffffffff .text
abs ffffffff binit
abs ffffffff etext
abs ffffffff pinit
[310 symbols]
I appreciate your help. Thank you
