Part Number: LAUNCHXL-F280025C
I am trying to run the universal motor control lab and get uart joystick data coming in from another board and I want to use this data to control the motor speed. The data was not getting decoded correctly when it was just reading the uart in the main motor loop. I have used the Task class when developing with the CC2640R2 ble board. However, this is not built in to the F280025C c2000 family of boards. So I am attempting to use FreeRTOS. I looked at the FreeRTOS Blinky and was trying to mimic this in the universal motor control lab. However, I am getting an Interrupt_illegalOperationHandler exception. Not quite sure why. I am thinking maybe I did not set up the CPU interrupt correctly.
Here is the main code. I highlighted my changes
// $Copyright:
// Copyright (C) 2017-2025 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
//! \file /solutions/universal_motorcontrol_lab/common/source/sys_main.c
//! \brief This project is used to implement motor control with FAST, eSMO
//! Encoder, and Hall sensors based sensored/sensorless-FOC.
//! Supports multiple TI EVM boards
// dcsm_security_tool guidance refer to: www.ti.com/.../spracp8
// include the related header files
#include "user.h"
#include "sys_settings.h"
#include "sys_main.h"
#include "device.h"
// #include "FreeRTOS.h"
// #include "semphr.h"
// #include "task.h"
volatile SYSTEM_Vars_t systemVars;
#pragma DATA_SECTION(systemVars,"sys_data");
#ifdef CPUTIME_ENABLE
// define CPU time for performance test
CPU_TIME_Obj cpuTime;
CPU_TIME_Handle cpuTimeHandle;
#pragma DATA_SECTION(cpuTime,"sys_data");
#pragma DATA_SECTION(cpuTimeHandle,"sys_data");
#endif // CPUTIME_ENABLE
#if defined(EPWMDAC_MODE)
#if defined(HVMTRPFC_REV1P1)
HAL_PWMDACData_t pwmDACData;
#pragma DATA_SECTION(pwmDACData,"sys_data");
// HVMTRPFC_REV1P1
#else
#error EPWMDAC is not supported on this kit!
#endif // !HVMTRPFC_REV1P1
#endif // EPWMDAC_MODE
#if defined(DAC128S_ENABLE)
DAC128S_Handle dac128sHandle; //!< the DAC128S interface handle
DAC128S_Obj dac128s; //!< the DAC128S interface object
#pragma DATA_SECTION(dac128sHandle,"sys_data");
#pragma DATA_SECTION(dac128s,"sys_data");
#define DAC_SCALE_SET (4096.0f) // 12bit
#endif // DAC128S_ENABLE
#if defined(SFRA_ENABLE)
float32_t sfraNoiseId;
float32_t sfraNoiseIq;
float32_t sfraNoiseSpd;
float32_t sfraNoiseOut;
float32_t sfraNoiseFdb;
SFRA_TEST_e sfraTestLoop; //speedLoop;
bool sfraCollectStart;
#pragma DATA_SECTION(sfraNoiseId, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraNoiseIq, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraNoiseSpd, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraNoiseOut, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraNoiseFdb, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraTestLoop, "SFRA_F32_Data");
#pragma DATA_SECTION(sfraCollectStart, "SFRA_F32_Data");
#endif // SFRA_ENABLE
#define STACK_SIZE 1024U
static StaticTask_t motorTaskBuffer;
static StackType_t motorTaskStack[STACK_SIZE];
#pragma DATA_SECTION(motorTaskStack, ".freertosStaticStack")
#pragma DATA_ALIGN ( motorTaskStack , portBYTE_ALIGNMENT )
static StaticTask_t idleTaskBuffer;
static StackType_t idleTaskStack[STACK_SIZE];
#pragma DATA_SECTION(idleTaskStack, ".freertosStaticStack")
#pragma DATA_ALIGN ( idleTaskStack , portBYTE_ALIGNMENT )
// static SemaphoreHandle_t xSemaphore = NULL;
static StaticSemaphore_t xSemaphoreBuffer;
void vApplicationStackOverflowHook( TaskHandle_t xTask, char *pcTaskName )
while(1);
void vApplicationGetIdleTaskMemory( StaticTask_t **ppxIdleTaskTCBBuffer, StackType_t **ppxIdleTaskStackBuffer, configSTACK_DEPTH_TYPE *pulIdleTaskStackSize )
*ppxIdleTaskTCBBuffer = &idleTaskBuffer;
*ppxIdleTaskStackBuffer = idleTaskStack;
*pulIdleTaskStackSize = STACK_SIZE;
#define MSB_MASK 0xFF00
#define LSB_MASK 0x00FF
uint16_t joystickValue;
uint16_t rxStatus;
void motor_Task(void*);
void main(void)
// Clear memory for system and controller
// The variables must be assigned to these sector if need to be cleared to zero
HAL_clearDataRAM((void *)loadStart_est_data, (uint16_t)loadSize_est_data);
HAL_clearDataRAM((void *)loadStart_user_data, (uint16_t)loadSize_user_data);
HAL_clearDataRAM((void *)loadStart_hal_data, (uint16_t)loadSize_hal_data);
HAL_clearDataRAM((void *)loadStart_foc_data, (uint16_t)loadSize_foc_data);
HAL_clearDataRAM((void *)loadStart_sys_data, (uint16_t)loadSize_sys_data);
HAL_clearDataRAM((void *)loadStart_vibc_data, (uint16_t)loadSize_vibc_data);
HAL_clearDataRAM((void *)loadStart_datalog_data, (uint16_t)loadSize_datalog_data);
HAL_clearDataRAM((void *)loadStart_SFRA_F32_Data, (uint16_t)loadSize_SFRA_F32_Data);
#if defined(SYSCONFIG_EN)
systemVars.projectConfig = PRJ_DEV_SYSCONFIG;
#else
systemVars.projectConfig = PRJ_NON_SYSCONFIG;
#endif // SYSCONFIG_EN
systemVars.boardKit = BOARD_HVMTRPFC_REV1P1; // HVMTRPFC_REV1P1
#elif defined(DRV8329AEVM_REVA)
systemVars.boardKit = BOARD_DRV8329AEVM_REVA; // DRV8329AEVM_REVA
#elif defined(BSXL8323RS_REVA)
systemVars.boardKit = BOARD_BSXL8323RS_REVA; // BSXL8323RS_REVA
#elif defined(BSXL8323RH_REVB)
systemVars.boardKit = BOARD_BSXL8323RH_REVB; // BSXL8323RH_REVB
#elif defined(BSXL8353RS_REVA)
systemVars.boardKit = BOARD_BSXL8353RS_REVA; // BSXL8353RS_REVA
#elif defined(BSXL3PHGAN_REVA)
systemVars.boardKit = BOARD_BSXL3PHGAN_REVA; // BSXL3PHGAN_REVA
#elif defined(BSXL8316RT_REVA)
systemVars.boardKit = BOARD_BSXL8316RT_REVA; // BSXL8316RT_REVA
#elif defined(DRV8300DRGE_EVM)
systemVars.boardKit = BOARD_BSXL8300RT_REVA; // DRV8300DRGE_EVM
#else
#error Not select a right board for this project
#endif
#if defined(MOTOR1_ISBLDC) && (defined(MOTOR1_FAST) || \
defined(MOTOR1_ESMO) || defined(MOTOR1_ENC) || defined(MOTOR1_HALL))
#error ISBLDC can't work with other estimaor simultaneously
#elif defined(MOTOR1_ENC) && defined(MOTOR1_HALL)
#error Can't support ENC and HALL simultaneously
#elif defined(MOTOR1_ESMO) && defined(MOTOR1_HALL)
#error Can't support ESMO and HALL simultaneously
#elif defined(MOTOR1_FAST) && defined(MOTOR1_ENC)
systemVars.estType = EST_TYPE_FAST_ENC; // the estimator is FAST and ENC
#elif defined(MOTOR1_FAST) && defined(MOTOR1_ESMO)
systemVars.estType = EST_TYPE_FAST_ESMO; // the estimator is FAST and ESMO
#elif defined(MOTOR1_FAST) && defined(MOTOR1_RESL)
systemVars.estType = EST_TYPE_FAST_RESL; // the estimator is FAST and RESOLVER
#elif defined(MOTOR1_FAST) && defined(MOTOR1_PSCOS)
systemVars.estType = EST_TYPE_FAST_PSCOS; // the estimator is FAST and SIN/COS Encoder
#elif defined(MOTOR1_FAST) && defined(MOTOR1_HALL)
systemVars.estType = EST_TYPE_FAST_HALL; // the estimator is FAST and HALL
#elif defined(MOTOR1_ESMO) && defined(MOTOR1_ENC)
systemVars.estType = EST_TYPE_ESMO_ENC; // the estimator is ESMO and ENC
systemVars.estType = EST_TYPE_FAST; // the estimator is only FAST
systemVars.estType = EST_TYPE_ESMO; // the estimator is only ESMO
systemVars.estType = EST_TYPE_ENC; // the estimator is only ENC
#elif defined(MOTOR1_HALL)
systemVars.estType = EST_TYPE_HALL; // the estimator is only HALL
#elif defined(MOTOR1_ISBLDC)
systemVars.estType = EST_TYPE_ISBLDC; // the estimator is only ISBLDC
#else
#error Not select a right estimator for this project
#endif // MOTOR1_FAST->MOTOR1_ENC
#if defined(MOTOR1_FAST)
systemVars.estLibVersion = EST_getFASTVersion(); // gets FAST version
#if defined(MOTOR1_DCLINKSS) || defined(MOTOR1_ISBLDC)
systemVars.currentSenseType = CURSEN_TYPE_SINGLE_SHUNT;
systemVars.currentSenseType = CURSEN_TYPE_INLINE_SHUNT;
#else
systemVars.currentSenseType = CURSEN_TYPE_THREE_SHUNT;
#endif // Current Sense Type
#if defined(MOTOR1_HALL) && defined(_F280013x)
#error HALL sensors based FOC is not supported on this device
#endif // MOTOR1_HALL & _F280013x
#if defined(MOTOR1_DCLINKSS) && defined(DRV8329AEVM_REVA)
// This kit supports single shunt
#elif defined(MOTOR1_DCLINKSS)
#error This kit doesn't support single shunt
// Only modificated BSXL8323RS_REVA and BSXL8323RS_REVA support single shunt
#endif // MOTOR1_DCLINKSS
#if defined(MOTOR1_ISBLDC) && defined(DRV8329AEVM_REVA)
// This kit supports IS-BLDC
#error This kit doesn't support InstaSPIN-BLDC
// Only modificated BSXL8323RS_REVA and BSXL8323RS_REVA support instaspin-bldc
#endif // MOTOR1_ISBLDC
#if defined(DATALOGF2_EN) && defined(STEP_RP_EN)
#error DATALOG and GRAPH_STEP_RESPONSE can't be used simultaneously on this device
#endif // DATALOGF2_EN && STEP_RP_EN
#if defined(MOTOR1_ISBLDC) && defined(MOTOR1_DCLINKSS)
#error Don't need to enable single shunt pre-define name if use instaspin-bldc
#endif // MOTOR1_ISBLDC & MOTOR1_DCLINKSS
#if (defined(MOTOR1_SSIPD) || defined(MOTOR1_OVM)) && defined(MOTOR1_DCLINKSS)
#error Don't enable SSIPD and OVM if enable single shunt
#endif // (MOTOR1_SSIPD | MOTOR1_OVM) & (MOTOR1_DCLINKSS
#if defined(MOTOR1_ISBLDC) && (defined(MOTOR1_OVM) || defined(MOTOR1_FWC) || \
defined(MOTOR1_MTPA) || defined(MOTOR1_SSIPD))
#error Don't need to enable these functions if use instaspin-bldc
#endif // MOTOR1_ISBLDC & (MOTOR1_OVM | MOTOR1_FWC | MOTOR1_MTPA | MOTOR1_SSIPD)
// ** above codes are only for checking the settings, not occupy the memory
// Initialize device clock and peripherals
Device_init(); // call the function in device.c
// Disable pin locks and enable internal pullups.
Device_initGPIO(); // call the function in device.c
// Initializes PIE and clears PIE registers. Disables CPU interrupts.
Interrupt_initModule(); // call the function in driverlib.lib
// Initializes the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable(); // call the function in driverlib.lib
// initialize the driver
halHandle = HAL_init(&hal, sizeof(hal));
// set the driver parameters
HAL_setParams(halHandle);
// initialize the interrupt vector table
HAL_initIntVectorTable(halHandle);
// enable the ADC/PWM interrupts for control
// enable interrupts to trig DMA
HAL_enableCtrlInts(halHandle);
// for(;;)
// while(SCI_getRxFIFOStatus(SCIA_BASE) == SCI_FIFO_RX0) {}
// // Read a character from the FIFO.
// // receivedChar = SCI_readCharBlockingFIFO(SCIA_BASE);
// uint16_t myArray;
// SCI_readCharArray(SCIA_BASE, &myArray, 2);
// uint16_t *temp_num = &myArray;
// uint16_t temp = (temp_num[0] << 8);
// joystickValue = temp | (temp_num[1]);
// rxStatus = SCI_getRxStatus(SCIA_BASE);
// if((rxStatus & SCI_RXSTATUS_ERROR) != 0)
// //If Execution stops here there is some error
// //Analyze SCI_getRxStatus() API return value
// ESTOP0;
// uint16_t value[2];
// value[0] = (joystickValue & MSB_MASK) >> 8;
// value[1] = joystickValue & LSB_MASK;
// SCI_writeCharArray(SCIA_BASE, value, 2);
// joystickValue = 0;
// myArray = NULL;
// set the control parameters for motor 1
motorHandle_M1 = (MOTOR_Handle)(&motorVars_M1);
// set the reference speed, this can be replaced or removed
motorVars_M1.flagEnableRunAndIdentify = false;
motorVars_M1.speedRef_Hz = 60.0f; // Hz
motorVars_M1.speedRef_rpm = 600.0f; // rpm
// false - enables identification, true - disables identification
userParams_M1.flag_bypassMotorId = true; // false; //
initMotor1Handles(motorHandle_M1);
initMotor1CtrlParameters(motorHandle_M1);
// setup the GPIOs
HAL_setupGPIOs(halHandle);
// set up gate driver after completed GPIO configuration
motorVars_M1.faultMtrNow.bit.gateDriver =
HAL_MTR_setGateDriver(motorHandle_M1->halMtrHandle);
// enable the ePWM module time base clock sync signal
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
ERTM;
#if defined(CMD_POT_EN)
setExtCmdPotParams(motorHandle_M1);
#endif // CMD_POT_EN
#if defined(MOTOR1_HALL) && defined(CMD_CAP_EN)
#error HALL and CMD_CAP can't be enabled at the same time
#elif defined(CMD_CAP_EN)
setExtCmdCapParams(motorHandle_M1);
#endif // CMD_CAP_EN
#if defined(CMD_SWITCH_EN)
setExtCmdSwitchParams(motorHandle_M1);
#endif //CMD_SWITCH_EN
// initialize the CPU usage module
cpuTimeHandle = CPU_TIME_init(&cpuTime, sizeof(cpuTime));
CPU_TIME_reset(cpuTimeHandle);
CPU_TIME_setCtrlPeriod(cpuTimeHandle, HAL_getTimeBasePeriod(motorHandle_M1->halMtrHandle));
// set DAC parameters
pwmDACData.periodMax =
PWMDAC_getPeriod(halHandle->pwmDACHandle[PWMDAC_NUMBER_1]);
pwmDACData.ptrData[0] = &motorVars_M1.angleEST_rad; // PWMDAC1
// pwmDACData.ptrData[0] = &motorVars_M1.anglePLL_rad; // PWMDAC1
// pwmDACData.ptrData[1] = &motorVars_M1.angleENC_rad; // PWMDAC1
// pwmDACData.ptrData[1] = &motorVars_M1.angleHall_rad; // PWMDAC1
// pwmDACData.ptrData[1] = &motorVars_M1.angleGen_rad; // PWMDAC2
// pwmDACData.ptrData[1] = &motorVars_M1.adcData.I_A.value[0]; // PWMDAC2
pwmDACData.ptrData[1] = &motorVars_M1.speedAbs_Hz; // PWMDAC2
pwmDACData.ptrData[1] = &motorVars_M1.speedAbs_Hz; // PWMDAC3
// pwmDACData.ptrData[2] = &motorVars_M1.adcData.I_A.value[1]; // PWMDAC3
pwmDACData.ptrData[3] = &motorVars_M1.adcData.I_A.value[1]; // PWMDAC4
pwmDACData.offset[0] = 0.5f; // PWMDAC1
// pwmDACData.offset[1] = 0.5f; // PWMDAC2
pwmDACData.offset[1] = 0.0f; // PWMDAC2
pwmDACData.offset[1] = 0.0f; // PWMDAC3
// pwmDACData.offset[2] = 0.5f; // PWMDAC3
pwmDACData.offset[3] = 0.5f; // PWMDAC4
pwmDACData.gain[0] = 1.0f / MATH_TWO_PI; // PWMDAC1
// pwmDACData.gain[1] = 1.0f / MATH_TWO_PI; // PWMDAC2
// pwmDACData.gain[1] = 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A; // PWMDAC2
pwmDACData.gain[1] = 1.0f / USER_MOTOR1_FREQ_MAX_Hz; // PWMDAC2
pwmDACData.gain[2] = 1.0f / USER_MOTOR1_FREQ_MAX_Hz; // PWMDAC3
// pwmDACData.gain[2] = 1.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A; // PWMDAC3
pwmDACData.gain[3] = 2.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A; // PWMDAC4
// Initialize Datalog
datalogHandle = DATALOGIF_init(&datalog, sizeof(datalog));
DATALOG_Obj *datalogObj = (DATALOG_Obj *)datalogHandle;
HAL_setupDMAforDLOG(halHandle, 0, &datalogBuff1[0], &datalogBuff1[1]);
HAL_setupDMAforDLOG(halHandle, 1, &datalogBuff2[0], &datalogBuff2[1]);
#if (DMC_BUILDLEVEL <= DMC_LEVEL_2)
// set datalog parameters
datalogObj->iptr[0] = &motorVars_M1.adcData.I_A.value[0];
datalogObj->iptr[1] = &motorVars_M1.adcData.I_A.value[1];
#elif (DMC_BUILDLEVEL == DMC_LEVEL_3)
datalogObj->iptr[0] = &motorVars_M1.adcData.V_V.value[0];
datalogObj->iptr[1] = &motorVars_M1.adcData.V_V.value[1];
#elif (DMC_BUILDLEVEL == DMC_LEVEL_4)
datalogObj->iptr[0] = &motorVars_M1.angleFOC_rad;
datalogObj->iptr[1] = &motorVars_M1.speed_Hz;
// datalogObj->iptr[0] = &resl_M1.sin_os;
// datalogObj->iptr[1] = &resl_M1.cos_os;
// datalogObj->iptr[0] = &isbldc_M1.bemfInt;
// datalogObj->iptr[1] = &isbldc_M1.VintPhase;
#endif // DMC_BUILDLEVEL = DMC_LEVEL_1/2/3/4
#elif defined(DATALOGF4_EN) || defined(DATALOGI4_EN)
HAL_setupDMAforDLOG(halHandle, 2, &datalogBuff3[0], &datalogBuff3[1]);
HAL_setupDMAforDLOG(halHandle, 3, &datalogBuff4[0], &datalogBuff4[1]);
datalogObj->iptr[2] = &motorVars_M1.adcData.I_A.value[2];
datalogObj->iptr[3] = &motorVars_M1.angleFOC_rad;
datalogObj->iptr[2] = &motorVars_M1.adcData.V_V.value[2];
datalogObj->iptr[1] = &motorVars_M1.angleEST_rad;
datalogObj->iptr[2] = &motorVars_M1.adcData.I_A.value[0];
datalogObj->iptr[3] = &motorVars_M1.adcData.V_V.value[0];
#endif // DATALOGI4_EN
// initialize the DAC128S
dac128sHandle = DAC128S_init(&dac128s);
#if defined(BSXL8323RS_REVA) || defined(BSXL8353RS_REVA) || \
#if defined(_F280013x) || defined(_F280015x) // DRV and DAC share SPIA
// switch the SPI_STE pin for DRV device
HAL_switchSPICS(motorHandle_M1->halMtrHandle);
DEVICE_DELAY_US(1.0f); // delay 1.0us
// setup SPI for DAC128S
// DAC128S_setupSPI(dac128sHandle);
DAC128S_setupSPIBR(dac128sHandle, DACS_SPI_BITRATE);
#else // !(_F280013x | F280015x)
#endif // !(F280013x | F280015x)
#else // !(BSXL8323RS_REVA | BSXL8353RS_REVA | BSXL8316RT_REVA)
#endif // !(BSXL8323RS_REVA | BSXL8353RS_REVA | BSXL8316RT_REVA)
// The following settings are for output the values of different variables
// in each build level for debug. The User can select one of these groups in
// different build level as commented note
// DAC_LEVEL4_ISBLDC, DAC_LEVEL4_DCLINK, DAC_LEVEL4_VIBCOMP,
// DAC_LEVEL2_MOTOR1_VS, DAC_LEVEL2_MOTOR1_IS, DAC_LEVEL_MOTOR1_FAST,
// DAC_LEVEL4_FAST_ESMO, DAC_LEVEL4_FAST_ENC, DAC_LEVEL4_FAST_HALL
// DAC_LEVEL4_FAST, DAC_LEVEL4_FAST_ENC, DAC_LEVEL4_ENC, DAC_LEVEL4_HALL
// DAC_LEVEL4_PHADJ,
#define DAC_LEVEL4_ISBLDC // define the DAC level
#define DAC_LEVEL4_FAST_ESMO // define the DAC level
#else // !MOTOR1_RESL && !MOTOR1_PSCOS && !MOTOR1_PSCOS
#define DAC_LEVEL_MOTOR1_FAST // define the DAC level
#endif // !MOTOR1_RESL && !MOTOR1_PSCOS
#if defined(DAC_LEVEL4_ISBLDC)
dac128s.ptrData[0] = &isbldc_M1.VintPhase; // CH_A
dac128s.ptrData[1] = &isbldc_M1.bemfInt; // CH_B
dac128s.ptrData[2] = &isbldc_M1.Vabcn.value[0]; // CH_C
dac128s.ptrData[3] = &isbldc_M1.Vabcn.value[1]; // CH_D
dac128s.gain[0] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.gain[1] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.gain[2] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.gain[3] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.offset[0] = (uint16_t)(0.5f * DAC_SCALE_SET);
dac128s.offset[1] = (uint16_t)(0.5f * DAC_SCALE_SET);
dac128s.offset[2] = (uint16_t)(0.5f * DAC_SCALE_SET);
dac128s.offset[3] = (uint16_t)(0.5f * DAC_SCALE_SET);
#elif defined(DAC_LEVEL4_DCLINK)
// Build_Level_2, verify the current sampling value
dac128s.ptrData[0] = &motorVars_M1.angleFOC_rad; // CH_A
dac128s.ptrData[1] = &motorVars_M1.adcData.I_A.value[0]; // CH_B
dac128s.ptrData[2] = &motorVars_M1.adcIs_A.value[0]; // CH_C
dac128s.ptrData[3] = &motorVars_M1.adcData.I_A.value[1]; // CH_D
dac128s.gain[0] = DAC_SCALE_SET / MATH_TWO_PI;
dac128s.gain[1] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
dac128s.gain[2] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
dac128s.gain[3] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
#elif defined(DAC_LEVEL4_FAST_ESMO)
dac128s.ptrData[0] = &motorVars_M1.angleEST_rad; // CH_A
dac128s.ptrData[1] = &motorVars_M1.anglePLL_rad; // CH_B
#if defined(ESMO_DEBUG)
dac128s.ptrData[2] = &esmo_M1.thetaElec_rad; // CH_C
#else //!ESMO_DEBUG
dac128s.ptrData[2] = &motorVars_M1.adcData.I_A.value[0]; // CH_C
#endif //!ESMO_DEBUG
dac128s.gain[1] = DAC_SCALE_SET / MATH_TWO_PI;
dac128s.gain[2] = DAC_SCALE_SET / MATH_TWO_PI;
#else //!ESMO_DEBUG
#elif defined(DAC_LEVEL_MOTOR1_FAST)
dac128s.ptrData[2] = &motorVars_M1.adcData.I_A.value[1]; // CH_C
dac128s.ptrData[3] = &motorVars_M1.adcData.I_A.value[2]; // CH_D
dac128s.gain[3] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_Interrupt_illegalOperationHandlerSCALE_CURRENT_A;
dac128s.ptrData[0] = &motorVars_M1.angleEST_rad; // CH_B
dac128s.ptrData[2] = &motorVars_M1.adcData.I_A.value[0]; // CH_D
dac128s.ptrData[3] = &motorVars_M1.adcData.I_A.value[1]; // CH_E
#elif defined(DAC_LEVEL4_FAST_ENC)
dac128s.ptrData[1] = &motorVars_M1.angleENC_rad; // CH_B
#elif defined(DAC_LEVEL4_FAST_HALL)
dac128s.ptrData[1] = &motorVars_M1.angleHall_rad; // CH_B
#elif defined(DAC_LEVEL4_FAST)
dac128s.ptrData[2] = &motorVars_M1.adcData.V_V.value[0]; // CH_C
dac128s.gain[1] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
dac128s.gain[3] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
#elif defined(DAC_LEVEL4_PHADJ)
dac128s.ptrData[0] = &motorVars_M1.Vab_out_V.value[0]; // CH_A
dac128s.ptrData[1] = &motorVars_M1.estInputData.Iab_A.value[0]; // CH_B
dac128s.ptrData[2] = &motorVars_M1.Eab_V.value[0]; // CH_C
dac128s.ptrData[3] = &motorVars_M1.Eab_V.value[1]; // CH_D
dac128s.gain[1] = DAC_SCALE_SET * 4.0f / USER_M1_ADC_FULL_SCALE_CURRENT_A;
#elif defined(DAC_LEVEL3_MOTOR1_FAST)
// Build_Level_2 or Level_3, verify the estimator
dac128s.ptrData[0] = &motorVars_M1.angleGen_rad; // CH_A
dac128s.ptrData[1] = &motorVars_M1.angleEST_rad; // CH_B
dac128s.gain[2] = DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_CURRENT_A;
#elif defined(DAC_LEVEL2_MOTOR1_IS)
#elif defined(DAC_LEVEL2_MOTOR1_VS)
dac128s.ptrData[1] = &motorVars_M1.adcData.V_V.value[0]; // CH_B
dac128s.ptrData[2] = &motorVars_M1.adcData.V_V.value[1]; // CH_C
dac128s.ptrData[3] = &motorVars_M1.adcData.V_V.value[2]; // CH_D
dac128s.gain[1] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.gain[2] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
dac128s.gain[3] = 2.0f * DAC_SCALE_SET / USER_M1_ADC_FULL_SCALE_VOLTAGE_V;
#endif // (DMC_BUILDLEVEL <= DMC_LEVEL_3)
DAC128S_writeCommand(dac128sHandle);
// Plot GH & H plots using SFRA_GUI, GH & CL plots using SFRA_GUI_MC
configureSFRA(SFRA_GUI_PLOT_GH_H, USER_M1_ISR_FREQ_Hz);
sfraNoiseId = 0.0f;
sfraNoiseIq = 0.0f;
sfraNoiseSpd = 0.0f;
sfraNoiseOut = 0.0f;
sfraNoiseFdb = 0.0f;
sfraTestLoop = SFRA_TEST_D_AXIS;
sfraCollectStart = false;
#if defined(STEP_RP_EN)
GRAPH_init(&stepRPVars,
&motorVars_M1.speedRef_Hz, &motorVars_M1.speed_Hz,
&motorVars_M1.IdqRef_A.value[0], &motorVars_M1.Idq_in_A.value[0],
&motorVars_M1.IdqRef_A.value[1], &motorVars_M1.Idq_in_A.value[1]);
#endif // STEP_RP_EN
systemVars.flagEnableSystem = true;
#if defined(CMD_CAN_EN)
// initialize the CANCOM
initCANCOM(halHandle);
motorVars_M1.cmdCAN.speedSet_Hz = 40.0f;
motorVars_M1.cmdCAN.flagEnableCmd = false;
motorVars_M1.cmdCAN.flagEnableSyncLead = false;
#endif // CMD_CAN_EN
motorVars_M1.flagEnableOffsetCalc = true;
// run offset calibration for motor 1
runMotor1OffsetsCalculation(motorHandle_M1);
#if defined(MOTOR1_RESL)
motorVars_M1.flagEnableRESLAdcOffsetCalc = true;
// run offset calibration for resolver 1
runResolver1OffsetsCalculation(motorHandle_M1);
#endif // MOTOR1_RESL
// enable global interrupts
HAL_enableGlobalInts(halHandle);
// enable debug interrupts
HAL_enableDebugInt(halHandle);
systemVars.powerRelayWaitTime_ms = POWER_RELAY_WAIT_TIME_ms;
// Waiting for enable system flag to be set
while(systemVars.flagEnableSystem == false)
if(HAL_getCPUTimerStatus(halHandle, HAL_CPU_TIMER0))
HAL_clearCPUTimerFlag(halHandle, HAL_CPU_TIMER0);
systemVars.timerBase_1ms++;
if(systemVars.timerBase_1ms > systemVars.powerRelayWaitTime_ms)
systemVars.timerBase_1ms = 0;
// Code Added
xSemaphore = xSemaphoreCreateBinaryStatic( &xSemaphoreBuffer );
// Create the task without using any dynamic memory allocation.
xTaskCreateStatic(motor_Task, // Function that implements the task.
"Motor task", // Text name for the task.
STACK_SIZE, // Number of indexes in the xStack array.
( void * ) NULL, // Parameter passed into the task.
tskIDLE_PRIORITY + 1, // Priority at which the task is created.
motorTaskStack, // Array to use as the task's stack.
&motorTaskBuffer ); // Variable to hold the task's data structure.
vTaskStartScheduler();
} // end of main() function
void motor_Task(void* params) {
motorVars_M1.flagInitializeDone = true;
while(systemVars.flagEnableSystem == true)
// loop while the enable system flag is true
systemVars.mainLoopCnt++;
// 1ms time base
// toggle status LED on controller board
systemVars.counterLEDC++;
if(systemVars.counterLEDC > (uint16_t)(LED_BLINK_FREQ_Hz * 1000))
#if defined(_F28P65x)
HAL_toggleGPIO(halHandle, HAL_GPIO_LED2C); // Toggle on the LED
#else
HAL_toggleGPIO(halHandle, HAL_GPIO_LED1C); // Toggle on the LED
#endif
systemVars.counterLEDC = 0;
if(motorVars_M1.motorState >= MOTOR_CL_RUNNING)
systemVars.timeWaitLEDB =
(uint16_t)(40000.0f / (fabsf(motorVars_M1.speed_Hz) + 20.0f));
// toggle status LED on inverter board if have
systemVars.counterLEDB++;
if(systemVars.counterLEDB > systemVars.timeWaitLEDB)
HAL_toggleGPIO(halHandle, HAL_GPIO_LED1B); // Toggle on the LED
systemVars.counterLEDB = 0;
else
HAL_setGPIOHigh(halHandle, HAL_GPIO_LED1B); // Turn on the LED
switch(systemVars.timerBase_1ms)
case 1: // motor 1 protection check
runMotorMonitor(motorHandle_M1);
break;
case 2:
calculateRMSData(motorHandle_M1);
break;
case 3:
#if defined(MOTOR1_PI_TUNE)
// Tune the gains of the controllers
tuneControllerGains(motorHandle_M1);
#endif // MOTOR1_PI_TUNE
break;
case 4: // calculate motor protection value
calcMotorOverCurrentThreshold(motorHandle_M1);
break;
case 5: // system control
systemVars.timerCnt_5ms++;
break;
updateCANCmdFreq(motorHandle_M1);
if((motorVars_M1.cmdCAN.flagEnableCmd == true) && (motorVars_M1.faultMtrUse.all == 0))
canComVars.flagCmdTxRun = motorVars_M1.cmdCAN.flagCmdRun;
canComVars.speedSet_Hz = motorVars_M1.cmdCAN.speedSet_Hz;
if(motorVars_M1.cmdCAN.flagEnableSyncLead == true)
motorVars_M1.flagEnableRunAndIdentify = motorVars_M1.cmdCAN.flagCmdRun;
motorVars_M1.speedRef_Hz = motorVars_M1.cmdCAN.speedSet_Hz;
else
motorVars_M1.flagEnableRunAndIdentify = canComVars.flagCmdRxRun;
motorVars_M1.speedRef_Hz = canComVars.speedRef_Hz;
updateExtCmdPotFreq(motorHandle_M1);
updateExtCmdCapFreq(motorHandle_M1,
HAL_calcCAPCount(motorHandle_M1->halMtrHandle));
updateCmdSwitch(motorHandle_M1);
// SFRA test
SFRA_F32_runBackgroundTask(&sfra1);
SFRA_GUI_runSerialHostComms(&sfra1);
// Generate Step response
GRAPH_generateStepResponse(&stepRPVars);
CPU_TIME_calcCPUWidthRatio(cpuTimeHandle);
} // 1ms Timer
outputCmdState(motorHandle_M1);
// runs control for motor 1
runMotor1Control(motorHandle_M1);
// Read/Write the registers of DRV device
if(HAL_getDRVFlagWR(motorHandle_M1->halMtrHandle) == true)
if(HAL_getSelectionSPICS(motorHandle_M1->halMtrHandle) != SPI_CS_DRV)
// setup the spi for drv8323/drv8353/drv8316
HAL_setupSPI(motorHandle_M1->halMtrHandle);
HAL_writeDRVData(motorHandle_M1->halMtrHandle, &drvicVars_M1);
HAL_readDRVData(motorHandle_M1->halMtrHandle, &drvicVars_M1);
else if(HAL_getSelectionSPICS(motorHandle_M1->halMtrHandle) != SPI_CS_DAC)
#else // !DAC128S_ENABLE
#endif // !DAC128S_ENABLE>
#elif defined(_F28002x) || defined(_F28003x) || defined(_F28P65x)
#else
#error This lab doesn't support thses devices, you need to change some files
#endif // !(F280013x | F280015x | F28002x | F28003x)
#endif // BSXL8323RS_REVA | BSXL8353RS_REVA | BSXL8316RT_REVA
} // end of while() loop
HAL_disablePWM(motorHandle_M1->halMtrHandle);
//-- end of this file ----------------------------------------------------------
I took the motor control code out of the main looop and put it in a function. And I was going to start a thread with that function as you can see in the code.
I also modified the hal.c where it initialzed the base timer and made a callback function for the interrupt. I'm thinking this could possibly be the culprit.
interrupt void timer1_ISR( void )
BaseType_t xHigherPriorityTaskWoken = pdFALSE;
xSemaphoreGiveFromISR( xSemaphore, &xHigherPriorityTaskWoken );
portYIELD_FROM_ISR( xHigherPriorityTaskWoken );
void HAL_setupTimeBaseTimer(HAL_Handle handle, const float32_t timeBaseFreq_Hz)
HAL_Obj *obj = (HAL_Obj *)handle;
Interrupt_register(INT_TIMER1, &timer1_ISR); // ADDED
uint32_t timerPeriod = (uint32_t)((USER_SYSTEM_FREQ_MHz * 1000.0f *1000.0f) /
timeBaseFreq_Hz);
// use timer 0 for CPU usage diagnostics
CPUTimer_setPreScaler(obj->timerHandle[0], 0);
CPUTimer_setEmulationMode(obj->timerHandle[0],
CPUTIMER_EMULATIONMODE_RUNFREE);
CPUTimer_setPeriod(obj->timerHandle[0], timerPeriod);
CPUTimer_enableInterrupt(obj->timerHandle[0]);
Interrupt_enable(INT_TIMER1);
CPUTimer_startTimer(obj->timerHandle[0]);
return;
} // end of HAL_setupTimeBaseTimer() function
Any help to remedy this would be greatly appreciated.
