Trip Zone test with Comparator input for Sine-wave generation
Other Parts Discussed in Thread: CONTROLSUITE, TMS320F28035
In the example "epwm_dcevent_trip_comp" under TMS320F28035 from ControlSUITE, it shows how to generate and  trip the epwm signal based on the result of the on-chip comparator.
I am just wondering how to use this technique to generate and trip a sinusoidal-wave (by epwm) instead of a regular square-wave (by epwm) which is the one used in the example.
I know how to generate a sine-wave by using a look-up table from IQmath library. Basically, I just use the table to calculate and update the counter-compare value(CMPA) during each ePWM interrupt.
I tried to use the same method to modify the example which uses an ePWM Trip Zone interrupt. It didn't work. It didn't give a time-varying-duty-cycle epwm signal.  It seems like it was not able to update the CMPA value.
Maybe I have some incorrect understandings of the trip-zone interrupt ? or this example?
Really need your hlep.
Thank you,
Frank
