Other Parts Discussed in Thread: CONTROLSUITE
hi,
i have generated the sinepwm for 3 phase inverter using Event Manager A ,see the spec at below:
pwm1 - 0 phase shift - 50 hz sine pwm
pwm2 - 0 phase shift - 50 hz inverted sine pwm with respect to pwm1.
pwm3 - 120 phase shift with respect to pwm1 - 50 hz sine pwm
pwm4 - 120 phase shift with respect to pwm1 - 50 hz inverted sine pwm with respect to pwm3.
pwm5 - 240 phase shift with respect to pwm1 - 50 hz sine pwm
pwm6 - 240 phase shift with respect to pwm1 - 50 hz inverted sine pwm with respect to pwm5.
successfully i have generated this, but (coming to the testing point) my doubt is when am connecting the CRO PROBE positive terminal to any pwm pin and ground terminal to ground am getting signal properly., the same when am connecting the CRO PROBE ground terminal to any pwm pin and positive terminal to ground am not getting the inverted signal., so, WHAT I HAVE TO DO , TO GET SUCH INVERTED SIGNAL , IS THEIR ANY REGISTER SETUP OR HARDWARE CIRCUIT TO SOLVE MY PROBLEM ??????????/ PLEASE HELP SOON......, AM NEW TO PWM
