I am to implement a GPIO pin as PWM. Depending upon the period and duty cycle I would like to toggle GPIO ON & OFF. Is there any implementation examples that I can find in TI site or control suite?
Appreciate your response.
KK
KK
I'm trying to do the same thing as you.Using GPIO as PWM output pin. What I have done is do the simulation of the pwm generation using simulink, the let simulink generate the code for you. Its done successfully for low speed pwm generation.
madie
Hi KK,
You mean to say, leaving so many PWM peripherals apart, you want to simulate PWM via GPIO?
If so, then by toggling GPIO with an x delay you'll be able to achieve particular period and duty cycle.
You've an inbuilt delay routine which can be called like: DELAY_US(100); //100us delay
Gautam
