Part Number: F29H85X-SOM-EVM
In the Code Provisioning flow of the F29H85x, the SSU-SecCfg needs to be programmed, to convert the device from HS-KP to HS-SE.
Does the SSU-SecCfg require a separate X.509 certificate?
Is the SSU-SecCfg blob required to be programmed every time along with the C29 application?
If a separate X.509 certificate is required for the SSU-SecCfg, is there any documentation available which describes the procedure for creating the X.509 certificate for the SSU-SecCfg blob?
Shashank
