TMS320F28P650DH: Making customized syscfg
Part Number: TMS320F28P650DH
Other Parts Discussed in Thread: SYSCONFIG, POWERSUITE, C2000WARE
Hi Experts,
i find the soultion in the digital power sdk using .js to make customized syscfg files, where the paramters of the solution, instead of the device, are added to the GUI.
I would like extend this and add more customized parameters to the syscfg GUI. Is there any documents showing how to do it?
Hang
  • HI Hang ,
    Looking into it , will get back to you
  • Hi Verma,
    Is there any update?
  • Hi Hang ,
    Apologies for delay.
    There is no official documentation yet .
    But I can guide you how to do it customize your sysconfig for that reference design.
    The main sysconfig file for reference design specific parameters is
    C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_04_00_00\powerSUITE\source\devkits\.meta\TIDA_01606\TIDA_01606.syscfg.js
    You can add your custom parameters here. It takes information from Kit.json and solution.js and use their variables. Add your parameter in the config variable of TIDA_01606.syscfg.js , and reload you CCS . You will see your changes reflected.
    But as you will use that variable in the codebase of the reference design , you need to add code in the template file for code generation.
    You can find the template file in
    C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_04_00_00\powerSUITE\source\devkits\.meta\TIDA_01606\tinv\tinv_settings.h.xdt
    After you make your changes in the template file rebuild your project and you will see your new sysconfig variables you added as macros in the tinv_setting.h file in the sysconfig folder of your CCS project.
    You can refer to how other variables are initialized in the .js and .xdt file for programming guidance.
    I hope it helps , if you need any help let me know.
    Lakshya
