TMS320F280039: How many time of XRSn?
Part Number: TMS320F280039
Hi team,
I ask this for my customer.
My customer will pull down the XRSn pin to realize the hardware reset
My customer want to check how the XRSn influence the device's longevity :
1. After how many times XRSn reset, the device will fail?
2. After how many years, the device will fail?
Thansk for your reply
BRs
Shuqing
  • Hi Shuqing,
    The thread is assigned to the corresponding expert, please expect a response shortly.
    Sahana
    There is no specified maximum number of times the XRSn (External Reset) pin can be asserted before a microcontroller (MCU) fails. Unlike flash memory, which has a finite number of "write/erase" cycles, a reset pin is a digital input designed for repeated use throughout the device's operational life.
    While the silicon itself doesn't "wear out" from logic transitions, the external components (like a physical reset button or pull-up resistors) may have mechanical or electrical fatigue limits. Also avoiding partial resets and  holding Xrsn down for sufficient time as mentioned in datasheet are some of good practices to follow.
