Part Number: F28377D-SEP
Other Parts Discussed in Thread: TMS320F28388D
I'm using TMS320F28388D MCU for my operation.
According to the ADC acquisition specification, a minimum of 4 acquisition cycles is required to obtain an accurate ADC reading. If the acquisition value is set below this minimum, the accuracy is not guaranteed.
I would like to understand the impact of this condition in more detail. If high switching activity introduces noise in the system when the minimum acquisition number is used, which bits of the ADC output are typically affected? Does the noise primarily impact the LSBs, the MSBs, or both? Also, does this error manifest symmetrically in both the positive and negative directions?
Additionally, if external noise sources have already been minimized but conversion errors are still observed with the minimum of 4 acquisition cycle, by how much should the acquisition time be increased to ensure stable and accurate readings?
