F29H85X-SOM-EVM: the issue of sdk1.3.0 example "epwm_ex1_cpu1_cpu3_framesel"
Part Number: F29H85X-SOM-EVM
Hi all,
I found we can not open the sysconfig file of the SDK examples like:
example path: "C:\ti\f29h85x-sdk_1_03_00_00\examples\driverlib\multi_core\epwm\f29h85x\epwm_ex1_cpu1_cpu3_framesel_multi_c29x1.syscfg"
version: CCS20.3.0,  SDK 1.03.0, sysconfig 1.25.0/1.26.0
Jenney
  • Hi all,
    i also try it in CCS 20.4, SDK 1.3.0.3(latested),  sysconfig 1.27.0,also found the issue.
    Jenney
  • Yes this is an issue with SDK1.03, this check was added only in 1.03 release and not present in previous release.
    I have filed this issue adding software team to fix for this issue
    You can follow the below workaround to fix this issue also attached file that you can just replace :
    File that has the issue : C:/ti/f29h85x-sdk_1_03_00_00/source/driverlib/.meta/epwm.js
    Change at line 710 — add a null check before accessing .divideValue:
    Before: (this causes issue if pwm module is added to cpu2, cpu3)
    if(system.clockTree.EPWMCLKDIV.divideValue == 2)
    After: (instead change to below )
    if(system.clockTree["EPWMCLKDIV"] && system.clockTree["EPWMCLKDIV"].divideValue == 2)
    let Common              = system.getScript("/driverlib/Common.js");
    let Pinmux              = system.getScript("/driverlib/pinmux.js");
    let clocktree_common    = system.getScript("/driverlib/clocktree/clocktree_common.js");
    const device            = clocktree_common.device;
    const EPWM_div_support  = clocktree_common.EPWM_div_support;
    let device_driverlib_peripheral =
        system.getScript("/driverlib/device_driverlib_peripherals/" +
            Common.getDeviceName().toLowerCase() + "_epwm.js");
    let device_driverlib_peripheral_funcs =
        system.getScript("/driverlib/device_driverlib_peripherals/functions/" +
            Common.getDeviceName().toLowerCase() + "/epwm.js");
    let driverlib_funcs = device_driverlib_peripheral_funcs["epwm" + "_driverlib"];
    let sysctl_options =
            Common.getDeviceName().toLowerCase() + "_sysctl.js");
    //console.log(system)
    // console.log(driverlib_funcs)
    let epwm_validation =
        system.getScript("/driverlib/epwm/" +
            "epwm_validation.js");
    let sync_module = system.getScript("/driverlib/sync.js")
    var pinmuxOnlyRelease = false;
    var DO_NOT_COPY_configNames = [
        "epwmMemoryFileBrowse",
        "epwmLoadConfig",
        "copyUse",
        "copyFrom",
        "copyPerform",
        "generateCodeTemplate",
        "codeTemplateName",
        "AH",
        "AL",
        "AHC",
        "ALC",
        "DUAL",
        "hrpwm_tbclk",
        "hrpwm_mepSteps",
        "hrpwm_coarseSteps",
        "hrpwm_periodCoarseSteps",
        "hrpwm_calculatedCMPX",
        "hrpwm_calculatedCMPXHR",
        "hrpwm_calculatedTBPRD",
        "hrpwm_calculatedTBPRDHR",
        "hrpwm_calculatedRED",
        "hrpwm_calculatedREDHR",
        "hrpwm_calculatedFED",
        "hrpwm_calculatedFEDHR",
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_A" + "_usedEvents", //DEPRECATED
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_A" + "_t1Source", //DEPRECATED
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_A" + "_t2Source", //DEPRECATED
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_B" + "_usedEvents", //DEPRECATED
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_B" + "_t1Source", //DEPRECATED
        "epwmActionQualifier_" + "EPWM_AQ_OUTPUT_B" + "_t2Source", //DEPRECATED
    var mindb_icl_xbar_map = {
     "EPWM_MINDB_SEL_OUTXBAR_OUT1" : "XBAR_OUTPUT1",
     "EPWM_MINDB_SEL_OUTXBAR_OUT2" : "XBAR_OUTPUT2",
     "EPWM_MINDB_SEL_OUTXBAR_OUT3" : "XBAR_OUTPUT3",
     "EPWM_MINDB_SEL_OUTXBAR_OUT4" : "XBAR_OUTPUT4",
     "EPWM_MINDB_SEL_OUTXBAR_OUT5" : "XBAR_OUTPUT5",
     "EPWM_MINDB_SEL_OUTXBAR_OUT6" : "XBAR_OUTPUT6",
     "EPWM_MINDB_SEL_OUTXBAR_OUT7" : "XBAR_OUTPUT7",
     "EPWM_MINDB_SEL_OUTXBAR_OUT8" : "XBAR_OUTPUT8",
     "EPWM_MINDB_SEL_OUTXBAR_OUT9" : "XBAR_OUTPUT9",
     "EPWM_MINDB_SEL_OUTXBAR_OUT10" : "XBAR_OUTPUT10",
     "EPWM_MINDB_SEL_OUTXBAR_OUT11" : "XBAR_OUTPUT11",
     "EPWM_MINDB_SEL_OUTXBAR_OUT12" : "XBAR_OUTPUT12",
     "EPWM_MINDB_SEL_OUTXBAR_OUT13" : "XBAR_OUTPUT13",
     "EPWM_MINDB_SEL_OUTXBAR_OUT14" : "XBAR_OUTPUT14",
     "EPWM_MINDB_SEL_OUTXBAR_OUT15" : "XBAR_OUTPUT15",
     "EPWM_MINDB_ICL_XBAR_OUT1" : "XBAR_OUTPUT1",
     "EPWM_MINDB_ICL_XBAR_OUT2" : "XBAR_OUTPUT2",
     "EPWM_MINDB_ICL_XBAR_OUT3" : "XBAR_OUTPUT3",
     "EPWM_MINDB_ICL_XBAR_OUT4" : "XBAR_OUTPUT4",
     "EPWM_MINDB_ICL_XBAR_OUT5" : "XBAR_OUTPUT5",
     "EPWM_MINDB_ICL_XBAR_OUT6" : "XBAR_OUTPUT6",
     "EPWM_MINDB_ICL_XBAR_OUT7" : "XBAR_OUTPUT7",
     "EPWM_MINDB_ICL_XBAR_OUT8" : "XBAR_OUTPUT8",
     "EPWM_MINDB_ICL_XBAR_OUT9" : "XBAR_OUTPUT9",
     "EPWM_MINDB_ICL_XBAR_OUT10" : "XBAR_OUTPUT10",
     "EPWM_MINDB_ICL_XBAR_OUT11" : "XBAR_OUTPUT11",
     "EPWM_MINDB_ICL_XBAR_OUT12" : "XBAR_OUTPUT12",
     "EPWM_MINDB_ICL_XBAR_OUT13" : "XBAR_OUTPUT13",
     "EPWM_MINDB_ICL_XBAR_OUT14" : "XBAR_OUTPUT14",
     "EPWM_MINDB_ICL_XBAR_OUT15" : "XBAR_OUTPUT15",
     "EPWM_MINDB_ICL_XBAR_OUT16" : "XBAR_OUTPUT16"
    var boardCTemplate = "/driverlib/epwm/epwm.board.c.xdt";
    var boardHTemplate = "/driverlib/epwm/epwm.board.h.xdt";
    /* Intro splash on GUI */
    let longDescription = "";
    function CommentOutCode (inst, ui)
        if (inst.enableAllCode == true)
            ui.commentOutDefaultCode.hidden = false;
        else
            inst.commentOutDefaultCode = false;
            ui.commentOutDefaultCode.hidden = true;
    function performCopy(inst, ui)
        for (var instance_index in inst.$module.$instances)
            var instance_obj = inst.$module.$instances[instance_index];
            if (instance_obj != inst) {
                //console.log(instance_obj)
                if (instance_obj.$name == inst.copyFrom)
                    copyAllSettings(inst, instance_obj);
    function getConfigNameRecursive(arrayConfigs)
        var configNames = [];
        for (var modConfig of arrayConfigs)
            if (modConfig.config)
                configNames = configNames.concat(getConfigNameRecursive(modConfig.config))
            else
                var modConfigName = modConfig.name;
                configNames.push(modConfigName);
        return configNames;
    function copyAllSettings(inst_copy_to, inst_copy_from)
        var configNames = getConfigNameRecursive(inst_copy_from.$module.config);
        for (var configOptionIndex = 0; configOptionIndex<configNames.length; configOptionIndex++)
            var configName = configNames[configOptionIndex];
            if (DO_NOT_COPY_configNames.includes(configName))
                continue;
            //console.log(configName);
            //console.log(inst_copy_from[configName]);
            inst_copy_to[configName] = inst_copy_from[configName];
    var longDescriptionMemoryLoad = `
    **Note: Currently, this tool is unable to map any of the Link settings for the EPWM. As such, they must be input MANUALLY.**
    This tool functions by taking the register memory you're inputting (.dat) and setting the associated settings in Sysconfig for you.
    To ensure that your .dat file is correctly exported, please follow these steps (information shown is for EPWM1 but works for all EPWMs):
    *   1) Load your codebase onto your MCU in debug mode
    ![an offline image](../../driverlib/.meta/memory_mapping/docs/stage_1_mm_debug_view.png "Memory File Export")
    *   2) Run until your peripheral setup is complete and the sync clock is enabled
    ![an offline image](../../driverlib/.meta/memory_mapping/docs/stage_2_mm_debug_view.png "Memory File Export")
    *   3) Save the register memory (using 'Memory Browser' or via 'Tools') for your peripheral in 16-bit TI Style format.
    ![an offline image](../../driverlib/.meta/memory_mapping/docs/stage_4_mm_debug_view.png "Save Memory View")
    ![an offline image](../../driverlib/.meta/memory_mapping/docs/stage_3_mm_debug_view.png "Memory File Export")
    *   4) Once these steps have been completed and your .dat file has been generated, load your .dat via 'EPWM Memory File'
    *   5) Determine if you want to overwrite all existing settings with those within the memory file OR if you only want 'non-default' settings to be imported via 'Overwrite All Values From Memory File'
    *   6) Click the 'Load Configuration' button and all of your settings for this EPWM will be imported and set
    /* Array of CAN configurables that are common across device families */
    let config = [
            default: false,
            onChange : (inst, ui) =>
                console.log(inst.$module.$configByName)
            displayName: "Load EPWM Settings From Device Memory Export",
            longDescription: longDescriptionMemoryLoad,
            config: [
                    displayName: "EPWM Memory File",
                    default: "",
                    hidden: false,
                    fileFilter: ".dat",
                    displayName: "Overwrite All Values From Memory File",
                    longDescription: "Loads in all values from memory, overwriting current settings.",
                    default: false,
                    hidden: false,
                    displayName: "Load Configuration",
                    buttonText: "Load the memory configuration",
                    longDescription: "Load the configuration from the selected .dat file into Sysconfig.",
                    hidden: false,
                    onLaunch: (inst) => {
                        //console.log(inst.epwmMemoryFileBrowse)
                        return ({
                            command: "../driverlib/.meta/epwm/epwmMemory.bat",
                            args: [inst.epwmMemoryFileBrowse, "$comFile"],
                            initialData: ""
                    onComplete: (inst, ui, result) => {
                        // console.log(inst);
                        // console.log("inside onComplete");
                        let deviceName = Common.getDeviceName();
                        //NEED TO SET IP_NAME FOR EACH IP
                        let IP_NAME = 'epwm';
                        // console.log(deviceName);
                        let memoryData = result['data'].toString().split('\n');
                        const conversionFunctions = require("./mapping_input");
                        let sysOptions = conversionFunctions.callParser(memoryData, 0, deviceName, IP_NAME, inst.epwmLoadAllValues);
                        //algorithm run
                        // console.log(sysOptions);
                        for(let mapVals of sysOptions){
                            if((/^[0-9]+$/).test(mapVals["value"])){
                                mapVals["value"] = parseInt(mapVals["value"]);
                            try{
                                inst[mapVals["name"]] = mapVals["value"];
                            catch (e) {
                                // console.log(e);
                                if(typeof(mapVals["value"]) == "number"){
                                    mapVals["value"] = mapVals["value"].toString();
                                else if(typeof(mapVals["value"]) == "string"){
                                    let holder = [];
                                    holder.push(mapVals["value"]);
                                    mapVals["value"] = Object.assign([], holder);
                                try{
                                catch(err){
                                    if(typeof(mapVals["value"]) == "object"){
                                        mapVals["value"] = mapVals["value"][0];
                            // if(ui[mapVals["name"]]["hidden"] == true){
                            //     ui[mapVals["name"]]["hidden"] = false;
                            if(inst.$module.$configByName[mapVals["name"]].default  != mapVals["value"] && "onChange" in inst.$module.$configByName[mapVals["name"]]){
                                inst.$module.$configByName[mapVals["name"]].onChange(inst, ui);
            displayName: "Template Code Generation",
            description: "",
            longDescription: "Generate template code for EPWM configuration",
            config: [
                    displayName : "Generate Code Template",
                    description : 'Enable the template code generation',
                    hidden      : false,
                    default     : false
                    displayName : "Code Template Name",
                    description : 'The name of the code template generated for this EPWM configuration',
                    hidden      : false,
                    default     : "ePWMConfigurationTemplate"
    function filterHardware(component)
        return (Common.typeMatches(component.type, ["EPWM"]));
    function modules(inst)
        if (inst) {
            return [
                    moduleName: "/driverlib/epwm/templates/epwm.dot.dynamic.js",
        return [];
    let submodulesComponents = [
            moduleName: "/driverlib/epwm/modules/epwm_globalLoad.js",
            displayName:"EPWM Global Load",
            description:"Global Loading",
            moduleName: "/driverlib/epwm/modules/epwm_timebase.js",
            displayName:"EPWM Time Base",
            description:"Time Base Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_counterCompare.js",
            displayName:"EPWM Counter Compare",
            description:"Counter Compare Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_actionQualifier.js",
            displayName:"EPWM Action Qualifier",
            description:"Action Qualifier Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_deadband.js",
            displayName:"EPWM Dead-Band",
            description:"Dead-Band Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_chopper.js",
            displayName:"EPWM Chopper",
            description:"Chopper Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_tripZone.js",
            displayName:"EPWM Trip Zone",
            description:"Trip Zone Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_digitalCompare.js",
            displayName:"EPWM Digital Compare",
            description:"Digital Compare Submodule",
            moduleName: "/driverlib/epwm/modules/epwm_eventTrigger.js",
            displayName:"EPWM Event-Trigger",
            description:"Event-Trigger Submodule",
            moduleName: "/driverlib/epwm/modules/hrpwm_extension.js",
            displayName:"HRPWM",
            description:"High Resolution Pulse Width Modulation",
    const insert = (arr, index, newItem) => [
    // part of the array before the specified index
    ...arr.slice(0, index),
    // inserted item
    newItem,
    // part of the array after the specified index
    ...arr.slice(index)
    submodulesComponents = insert(submodulesComponents, 3,
            moduleName: "/driverlib/epwm/modules/epwm_xcmpmode.js",
            displayName:"EPWM XCMP Mode",
            description:"XCMP Submodule",
    submodulesComponents = insert(submodulesComponents, 8 ,
            moduleName: "/driverlib/epwm/modules/epwm_diodeEmulation.js",
            displayName:"EPWM Diode Emulation",
            description:"Diode Emulation Submodule",
    submodulesComponents = insert(submodulesComponents, 10 ,
            moduleName: "/driverlib/epwm/modules/epwm_minDBILC.js",
            displayName:"EPWM Minimum Dead Band and Illegal Combo Logic",
            description:"Minimum Dead Band and Illegal Combo Logic Submodule",
    for (var submoduleComponent of submodulesComponents)
        var submodule = system.getScript(submoduleComponent.moduleName)
        config = config.concat([
                name: "GROUP_" + submodule.defaultInstanceName,
                displayName: submodule.displayName,
                longDescription: submodule.description,
                description: "",
                config: submodule.config
    config.push(
            displayName : "PinMux Use Case",
            description : 'Peripheral use case',
            hidden      : false,
            default     : 'ALL',
            options     : Pinmux.getPeripheralUseCaseNames("EPWM"),
            onChange    : Pinmux.useCaseChanged,
            shouldBeAllocatedAsResource: true,
    var moduleStatic = {
        displayName: "EPWM Global Settings",
        config: [
            //     name: "printModuleInfo",
            //     displayName : "Print Module Info",
            //     description : '',
            //     hidden      : false,
            //     buttonText: "Print",
            //     onLaunch: (inst) => {
            //         return ({
            //             command: "../driverlib/.meta/epwm/epwmMemory.bat",
            //             args: [inst.epwmMemoryFileBrowse, "$comFile"],
            //             initialData: "",
            //     onComplete: (inst, ui, result) => {
            //         Common.printConfigsInfo(system.modules['/driverlib/epwm.js'].$configByName)
                displayName: "Enable Info Mode",
                default : true
                displayName: "Enable Warnings",
                default : true
                displayName: "Enable All Code Generation",
                description: "Enable All Code Generation",
                default : false
                displayName: "Comment Out the Default Settings Code",
                description: "Comment Out the Default Settings Code",
                default : false
                displayName: "Generate Init Function for Each Instance",
                description: "Generate Init Function for Each Instance",
                default : false
                displayName: "Enable Time Base Clock Synchronization",
                description: "Enable Time Base Clock Synchronization",
                default : false
                displayName: "Enable Global Time Base Clock Synchronization",
                description: "Enable Global Time Base Clock Synchronization",
                default : false,
                onChange    : (inst, ui)=>
                    if(inst.globalClockSyncEnable)
                        ui.clockSyncEnable.readOnly = true;
                        if(inst.clockSyncEnable)
                            inst.clockSyncEnable = false;
                    else
                        ui.clockSyncEnable.readOnly = false;
                displayName : "Enable XLINK Feature",
                longDescription : "This Configuration is only accessible from CPU 1.",
                readOnly    : !Common.isContextCPU1(),
                options     : sysctl_options.SYSCTL_EPWM,
                minSelections : 0,
                default     : [],
        moduleInstances: (inst) => {
            let components = [];
            // If Time Base Clock Synchronization is enabled, create perClock instance for TBCLKSYNC
            if (inst.clockSyncEnable) {
                components.push({
                    group: "Group_Sys",
                    displayName: "",
                    moduleName: "/driverlib/perClock.js",
                    collapsed: false,
                    requiredArgs: {
                        pinmuxPeripheralModule: "",
                        peripheralInst: "TBCLKSYNC"
            if (inst.globalClockSyncEnable) {
                components.push({
                    group: "Group_Sys",
                    displayName: "",
                    collapsed: false,
                    requiredArgs: {
                        peripheralInst: "GTBCLKSYNC"
            return components;
        // sharedModuleInstances : (inst)=>{
        //     return([
        //             name : "SYNC",
        //             displayName : "SYNC Configurations",
        //             moduleName  : "/driverlib/sync.js",
        //             collapsed   : false,
        // modules: Common.autoForce("sync", "/driverlib/sync.js")
    function validatePinmux(inst,validation){
        if (inst.epwm && inst.epwm.$solution) {
            let selectedPeripheral = inst.epwm.$solution.peripheralName; // e.g., "EPWM10"
            if (Common.is_instance_not_in_variant(selectedPeripheral)) {
                validation.logError(
                    `${selectedPeripheral} is not supported for ${Common.getVariant().replace(/^TMS320/, '')}.`,
                    inst,
                    "epwm"
        if(false == Common.checkXtalPinMux()) {
            validation.logError(`X1/X2 pin conflict`, inst, "epwm")
    function onValidate(inst, validation)
        // Check if the sync module is added on CPU1 if the current context is CPU2
        // if (Common.isMultiCoreDevice() && Common.isMultiCoreSysConfig())
        //     if (Common.isContextCPU2())
        //         if (Common.isModuleOnOtherContext("/driverlib/sync.js") == false)
        //             validation.logError("The SYNC module needs to be added on CPU1 when an EPWM instance is added on CPU2",
        //             inst, "epwmTimebase_forceSyncPulse");
        // }else
    	// 			validation.logWarning("The SYNC module needs to be added on CPU1 when an EPWM instance is added on CPU2",
        // Static Variables
        var useInfos = inst.$module.$static["enableInfo"]
        var useWarnings = inst.$module.$static["enableWarning"]
        // End of static variables
        // Copy Check Start
        var validCopyName = false;
        if (inst.copyUse)
                        validCopyName = true;
            if (!validCopyName)
                    "The copy from name is not a valid EPWM name",
                    inst, "copyFrom");
        // Copy Check End
        var usedEPWMTemplateNamesInsts = [];
            if (instance_obj.generateCodeTemplate)
                usedEPWMTemplateNamesInsts.push(instance_obj.codeTemplateName);
        var duplicatesResult = Common.findDuplicates(usedEPWMTemplateNamesInsts)
        if (duplicatesResult.duplicates.length != 0)
            var allDuplicates = "";
            for (var duplicateNamesIndex in duplicatesResult.duplicates)
                allDuplicates = allDuplicates + Common.stringOrEmpty(allDuplicates, ", ")
                                + duplicatesResult.duplicates[duplicateNamesIndex];
                "The EPWM template name is already used. Duplicates: " + allDuplicates,
                inst, "codeTemplateName");
        for (var valIndex = 0; valIndex < epwm_validation.epwm_validation.length; valIndex++)
            var valObject = epwm_validation.epwm_validation[valIndex];
            if (!valObject.devices.includes(Common.getDeviceName()))
                continue;
            if (valObject.type == epwm_validation.validation_info && !useInfos)
                continue;
            if (valObject.type == epwm_validation.validation_warning && !useWarnings)
                continue;
            valObject.func(inst, validation, valObject.name);
        if(EPWM_div_support.includes(device))
                let warningMsg1 = "ePWM TZFRC and TZCLR events will sometimes be missed when EPWMCLKDIV is divide by 2. Always program EPWMCLKDIV to divide by 1 if using TZFRC or TZCLR register. ";
                let warningMsg2 = "Please refer to the " + system.deviceData.device + " Silicon Errata for more details.";
                let warningMsg = warningMsg1 + warningMsg2;
                validation.logWarning(warningMsg, inst, "periphClock");
    if (Common.onlyPinmux())
        config = [config[config.length - 1]];
        moduleInstances = undefined
    if (pinmuxOnlyRelease)
        modules = undefined;
        boardCTemplate = "/driverlib/epwm/epwm_empty.board.c.xdt";
        boardHTemplate = "/driverlib/epwm/epwm_empty.board.h.xdt";
        onValidate = undefined;
        moduleStatic = undefined;
    var sharedModuleInstances = undefined;
    sharedModuleInstances = function (inst) {
    	let mindb_icl_xbar = [];
    	if (Common.isContextCPU2()){
    		return [];
        if (inst.epwmMinDeadBand_A_inputRefSignal != "EPWM_MINDB_SEL_DEPWM" && inst.epwmMinDeadBand_EnableA)
            mindb_icl_xbar = mindb_icl_xbar.concat(
                        displayName: "MINDB X-BAR Configuration",
                        moduleName: "/driverlib/mindbxbar.js",
                        collapsed: true,
    					group: "GROUP_MINDB_Output_A",
    					requiredArgs: {
    						xbarOutput : mindb_icl_xbar_map[inst.epwmMinDeadBand_A_inputRefSignal]
        if (inst.epwmMinDeadBand_B_inputRefSignal != "EPWM_MINDB_SEL_DEPWM" && inst.epwmMinDeadBand_EnableB)
                        collapsed: true,
    					group: "GROUP_MINDB_Output_B",
    					requiredArgs: {
    						xbarOutput : mindb_icl_xbar_map[inst.epwmMinDeadBand_B_inputRefSignal]
    	if (inst.epwmICL_EnableA)
                        displayName: "ICL X-BAR Configuration",
                        moduleName: "/driverlib/iclxbar.js",
                        collapsed: true,
    					group: "GROUP_ICL_A",
    					requiredArgs: {
    						xbarOutput : mindb_icl_xbar_map[inst.epwmICL_A_selXBAR]
    	if (inst.epwmICL_EnableB)
                        collapsed: true,
    					group: "GROUP_ICL_B",
    					requiredArgs: {
    						xbarOutput : mindb_icl_xbar_map[inst.epwmICL_B_selXBAR]
        return mindb_icl_xbar;
    config.push(
            displayName : "System Configuration",
            collapsed : true,
            config : []
    var epwmModule = {
        peripheralName: "EPWM",
        displayName: "EPWM",
        totalMaxInstances: Common.peripheralCount("EPWM"),
        defaultInstanceName: "myEPWM",
        description: "Enhanced Pulse Width Modulator Peripheral",
        //longDescription: (Common.getCollateralFindabilityList("EPWM")),
        filterHardware : filterHardware,
        config: Common.filterConfigsIfInSetupMode(config),
        templates: {
            boardc : boardCTemplate,
            boardh : boardHTemplate
        modules: modules,
        moduleInstances : (inst) => {
            var regInterrupts = []
            var pinmuxQualMods = Pinmux.getGpioQualificationModInstDefinitions("EPWM", inst)
            regInterrupts = regInterrupts.concat(pinmuxQualMods)
            if (inst.epwmEventTrigger_registerInterrupts)
                regInterrupts.push({
                    displayName: "EPWM Interrupt ",
                    moduleName: "/driverlib/interrupt.js",
                    collapsed: true,
                    args: {
                        $name : inst.$name + "_ET_INT",
                        typeInterruptName : true,
                        pinmuxPeripheralModule : "epwm",
                        driverlibInt: "INT_#",
                        interruptHandler : "INT_" + inst.$name + "_ISR",
            if (inst.epwmTripZone_registerInterrupts)
                    displayName: "EPWM TZ Interrupt ",
                    collapsed: true,
                    args: {
                        $name : inst.$name + "_TZ_INT",
                        driverlibInt: "INT_#_TZ",
                        interruptHandler : "INT_" + inst.$name + "_TZ_ISR",
            // regInterrupts is also being used for peripheral clock/config as well
            regInterrupts = regInterrupts.concat([
                    group: "Group_Sys",
                    displayName: "",
                    collapsed: false,
                    requiredArgs:{
                        peripheralInst: ""
                    group: "Group_Sys",
                    displayName: "",
                    moduleName: "/driverlib/perConfig.js",
                    collapsed: false,
                    requiredArgs:{
                        cpuSel: inst.$assignedContext ?? system.context,
                        peripheralInst: ""
            //regInterrupts = regInterrupts.concat(submodules)
            // regInterrupts = regInterrupts.concat([
            //         name : "SYNC",
            //         displayName : "SYNC",
            return regInterrupts;
    	sharedModuleInstances: sharedModuleInstances,
        moduleStatic: moduleStatic,
        pinmuxRequirements    : Pinmux.epwmPinmuxRequirements,
        validate : onValidate,
        validatePinmux: validatePinmux,
        migrateLegacyConfiguration : (inst) =>
            // Migrating old method for T1 and T2
            var AQLocation = 0;
            for (let i=0; i< inst.$module.config.length; i++)
                if (inst.$module.config[i].name == "GROUP_EPWM_AQ")
                    AQLocation = i;
            var A_t1Value = "";
            var A_t2Value = "";
            var B_t1Value = "";
            var B_t2Value = "";
            // Get the old values for T1 and T2
            for (let x=0; x< inst.$module.config[AQLocation].config.length; x++)
                if (inst.$module.config[AQLocation].config[x].name == "GROUP_AQ_Output_EPWM_AQ_OUTPUT_A") // Check T1 and T2 for A Output
                   for (let y=0; y< inst.$module.config[AQLocation].config[x].config.length; y++)
                      if (inst.$module.config[AQLocation].config[x].config[y].name == "epwmActionQualifier_EPWM_AQ_OUTPUT_A_t1Source")
                        A_t1Value = inst[inst.$module.config[AQLocation].config[x].config[y].name]
                      if (inst.$module.config[AQLocation].config[x].config[y].name == "epwmActionQualifier_EPWM_AQ_OUTPUT_A_t2Source")
                        A_t2Value = inst[inst.$module.config[AQLocation].config[x].config[y].name]
                if (inst.$module.config[AQLocation].config[x].name == "GROUP_AQ_Output_EPWM_AQ_OUTPUT_B") // Check T1 and T2 for B Output
                   for (let z=0; z< inst.$module.config[AQLocation].config[x].config.length; z++)
                      if (inst.$module.config[AQLocation].config[x].config[z].name == "epwmActionQualifier_EPWM_AQ_OUTPUT_B_t1Source")
                        B_t1Value = inst[inst.$module.config[AQLocation].config[x].config[z].name]
                      if (inst.$module.config[AQLocation].config[x].config[z].name == "epwmActionQualifier_EPWM_AQ_OUTPUT_B_t2Source")
                        B_t2Value = inst[inst.$module.config[AQLocation].config[x].config[z].name]
            // Setup the new T1 value
            if (A_t1Value != device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t1Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t1Source = A_t1Value
            else if (A_t1Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t1Value != device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t1Source = B_t1Value
            else if (A_t1Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t1Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t1Source = device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name
            else
            // Setup the new T2 value
            if (A_t2Value != device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t2Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t2Source = A_t2Value
            else if (A_t2Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t2Value != device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t2Source = B_t2Value
            else if (A_t2Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name && B_t2Value == device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name)
                inst.epwmActionQualifier_t2Source = device_driverlib_peripheral.EPWM_ActionQualifierTriggerSource[0].name
            else
            // Update Digital Compare Combo Logic
            for (var dcCompareTypeIndex in device_driverlib_peripheral.EPWM_DigitalCompareType)
                var dcCompareType = device_driverlib_peripheral.EPWM_DigitalCompareType[dcCompareTypeIndex];
                var dcTypeName = "epwmDigitalCompare_" + dcCompareType.name
                var dcTypeNameCombo = "epwmDigitalCompare_" + dcCompareType.name + "_combinationInputConfig"
                if (inst.dcTypeNameCombo != [])
                    inst.dcTypeName = "EPWM_DC_TRIP_COMBINATION"
    if (epwmModule.maxInstances <= 0)
        delete epwmModule.pinmuxRequirements;
    else
        Pinmux.addCustomPinmuxEnumToConfig(epwmModule)
        Pinmux.addPinMuxQualGroupToConfig(epwmModule)
    exports = epwmModule;
  • okk, when will fix this issue? Next version SDK?
