Part Number: TMS320F2800157
Dear Expert
We are currently encountering some issues with the TMS320F2800157 chip and would like to inquire about:
We took a new chip from the warehouse to develop a new project and found that it could not be programmed. The peripheral voltage was normal, but the reset pin (with a 2.2k pull-up) was periodically pulled down (about 14ms once), causing it to be unable to be programmed. The burning adopts a 4-wire system (VCC GND TMS TCK). Because we had previously developed projects using this chip and did not find this issue, we replaced the problematic chip with a non problematic peripheral platform and found that the reset pin was still periodically pulled down. Please help to see what problem is causing the reset foot to be constantly pulled down.
Below is RST pin waveform:
