TMS320F28386D: Simultaneous access interference on IPC registers
Part Number: TMS320F28386D
Can you confirm that there is simultaneous access:
  • By CPU1 in write to CPU1TOCPU2IPCSENDDATA
  • By CPU2 in read to CPU1TOCPU2IPCRECVDATA
None of them will be delayed as these are pure registers, in contrary to when accessing peripheral frames for example.
Clément
  • Hi Clement,
    Yes, CPU1 writing to CPU1TOCPU2IPCSENDDATA and CPU2 reading from CPU1TOCPU2IPCRECVDATA can occur simultaneously without either CPU being delayed. This is because the IPC module architecture shows that these are dedicated register spaces with separate access paths for each CPU:
    • CPU1 has R/W access to CPU1TOCPU2IPCSENDDATA
    • CPU2 has read-only access to CPU1TOCPU2IPCRECVDATA
    Hope this helps answer your question.
    Ira
