Part Number: F28E120SC
customer will use the comparator as "standalone" with output pin. Customers wants to know if the comparator still works if there is a system clock failure.
Regards, Holger
Regards, Holger
Holger,
I don't believe this will work correctly in the absence of a clock. The reason is that the control signal to the GPIO output data is a latched value, so even in the case where the comparator is functioning properly; its output to a pin will still be gated by a clock to latch it to the GPIO.
With that said, I will point out that this device has a backup(WROSC) clock, that if a missing clock is detected on the main clock, the MCD logic will automatically switch to this clock, which would let the Comparator output be latches to the GPIU output.
Matthew
Hi Matthew,
customer had another question.
if customer don't use MCD, the GPIU state of the comp out would stay the same or switch to tri-state in case of a clock failure?
Regards, Holger
Holger,
I'm confirming with the design team, should have a reply by tomm.
Matthew
Hi Holger,
The expert on this is out of office until Jul 29th, please expect a delay in response and thank you very much for your patience
Peter
Holger,
Thanks for your patience here, I've confirmed with design that ASYNC path out of CMPSS routed through X-bar to GPIO should function correctly in absence of system clock.
So customer should be able to use as standalone comparator as desired.
Matthew
