Part Number: C2000WARE
Hi ,
i am using below command for generating bin file in CCS , Now i need to implement to check bin file inside some constant string to indentify the proper bin file .
#pragma RETAIN(MCU_IDENTIFICATION)
#pragma DATA_SECTION(MCU_IDENTIFICATION, ".mcu_id")
const char MCU_IDENTIFICATION[] = "Main_V1.0_MCU";
using this cmd in main i can able to generate the string in out file but its not generating in bin file using below mentioned commend .
${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat ${BuildArtifactFileName} ${BuildArtifactFileBaseName}.bin ${CG_TOOL_ROOT}/bin/ofd2000.exe ${CG_TOOL_ROOT}/bin/hex2000.exe ${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe
So kindly suggest some method to generate string in bin file .
Regrads,
Subash
