Part Number: LAUNCHCC3235MOD
Other Parts Discussed in Thread: LAUNCHXL-F28379D, TMS320F28379D
TI Part should be LAUNCHXL-F28379D (Delfino F28379D LaunchPad)
Hardware Platform: LAUNCHXL-F28379D (Delfino F28379D LaunchPad)
Part Number: TMS320F28379D
Toolchain / IDE: Code Composer Studio (CCS) v12
Compiler: TI v22.6.0.LTS
Description of Issue:
We are implementing hardware-level oversampling on a LAUNCHXL-F28379D development board to capture phase currents at a 20kHz control frequency (50µs execution window). Our design requires a factor-8 oversampling mechanism to filter noise from the analog feedback lines before feeding a motor control algorithm.
To achieve this, our initialization code configures ADC-C (Phase A) and ADC-B (Phase B) to run in Burst Mode with a burst size of 8 samples, triggered via ePWM1 SOCA (Trigger 5). The Post-Processing Blocks (PPB1) are mapped to capture the accumulated results.
Our driver configuration file establishes the following baseline mapping:
- Phase B (
Ib): Handled byADC_B, pinADCIN2. It is mapped toSOC0with an active hardware trigger (TRIGSEL = 5U, ePWM1 SOCA). - Phase A (
Ia): Handled byADC_C, pinADCIN2. In our hardware driver, this physical pin is mapped to bothSOC0(TRIGSEL = 5U, ePWM1 SOCA) andSOC2(TRIGSEL = 0U, software/disabled trigger).
The Core Failure:
The project compiles cleanly with zero warnings or errors. However, at runtime, as soon as the execution loop begins, the
ADCPPB1RESULT registers for both modules read completely dead (absolute 0), regardless of whether we map the PPB to track SOC0 or SOC2.If we completely disable the custom Burst Mode initialization code block and read the normal
ADCRESULT0 registers, the analog feedback signals return instantly and track the motor currents perfectly.The configuration code is executed within the EALLOW-protected initialization phase. What are we missing or misconfiguring in the hardware sequence that causes the oversampled result registers to remain stalled at zero when Burst Mode is active?
Initialization Code Segment:
c
void init_ADC_Burst_Oversampling(void)
EALLOW;
// 1. Configure Burst Mode and link master trigger to ePWM (Trigger 5)
AdccRegs.ADCBURSTCTL.bit.BURSTSIZE = 7; // Take 8 burst samples (Factor-8 requirement: N+1)
AdccRegs.ADCBURSTCTL.bit.BURSTRIGSEL = 5; // Trigger source: ePWM1 SOCA
AdccRegs.ADCBURSTCTL.bit.BURSTEN = 1; // Enable Burst Mode globally for ADC-C
AdcbRegs.ADCBURSTCTL.bit.BURSTSIZE = 7; // Take 8 burst samples (Factor-8 requirement: N+1)
AdcbRegs.ADCBURSTCTL.bit.BURSTRIGSEL = 5; // Trigger source: ePWM1 SOCA
AdcbRegs.ADCBURSTCTL.bit.BURSTEN = 1; // Enable Burst Mode globally for ADC-B
// 2. Bind Post-Processing Blocks to respective asynchronous channels
// Note: We have tested both CONFIG = 2 and CONFIG = 0 for ADC-C due to dual-pin mapping. Both result in 0.
AdccRegs.ADCPPB1CONFIG.bit.CONFIG = 0; // Link ADC-C PPB1 to SOC0 (Phase A)
AdccRegs.ADCPPB1CONFIG.bit.TWOSCOMP = 0; // Unsigned standard format
AdccRegs.ADCPPB1OFFREF = 0; // Clear hardware calibration offsets
AdcbRegs.ADCPPB1CONFIG.bit.CONFIG = 0; // Link ADC-B PPB1 to SOC0 (Phase B)
AdcbRegs.ADCPPB1CONFIG.bit.TWOSCOMP = 0; // Unsigned standard format
AdcbRegs.ADCPPB1OFFREF = 0; // Clear hardware calibration offsets
EDIS;
Use code with caution.
Runtime Readout Sequence (inside the 20kHz main interrupt loop):
c
// Reading from the respective PPB result buffers
// A factor of 0.125f (1/8) scaling is applied downstream to resolve the 8x accumulation average.
uint32_t Ia_raw = AdccResultRegs.ADCPPB1RESULT.bit.PPBRESULT; // Stalled at 0
uint32_t Ib_raw = AdcbResultRegs.ADCPPB1RESULT.bit.PPBRESULT; // Stalled at 0
Specific Technical Inquiries for TI Support:
- When
BURSTEN = 1andBURSTTRIGSEL = 5(ePWM), does the burst engine always start converting fromSOC0throughSOC7sequentially regardless of the individualADCSOCxCTL.bit.TRIGSELsettings? If so, why doesADCPPB1RESULTstay at 0 whenCONFIG = 0? - Does enabling global Burst Mode require us to manually disable or clear the base
ADCSOCxCTL.bit.TRIGSELconfigurations for our active channels, or should they be left pointing to5U? - Is there a specific clock gate, interrupt flag, or timing constraint within the F28379D round-robin state machine that causes the PPB result registers to latch/freeze at zero if a hardware ePWM trigger arrives while a burst sequence is executing?
The C file without PPB Oversampling
- Phase B (
The Core Failure:
c
EALLOW;
EDIS;
c
- When
The C file attached has no PPB Factor-8 Oversampling, it works fine. PPB failed to work after we add the above code.
