Part Number: TMS320F28388D
I am new to programming TI microcontrollers. I have a design that has multiple SPI peripherals connected to SPIA. The part I tried to bring up is connected to SPIA_PTE4 (GPIO61). Using sysconfig I was able to establish communcations with the part. However, the second part has chip select SPIA_PTE1 (GPIO19). When I tried to make a second SPI port on sysconfig, I got a message of "resource conflict." Further investigation suggests that I need to disable the automatic chip select in the sysconfig for each one and operate them manually by writing a '0' to the individual pin using GPIO_writePin(GPIO61,0). Is this correct? My issue is that I cannot figure out how to disable the SPI_PTE pin in sysconfig so I get a buss conflict between the two peripherals when I try to communicate with the second SPI part. Can you direct me to a tutorial or document that describes the process? Thanks in advance.
