C2000-CGT: cl2000.exe crashes with INTERNAL ERROR
Part Number: C2000-CGT
Other Parts Discussed in Thread: TMS320F28379D
I would like to ask about an issue with the TI C2000 Code Generation Tools compiler.
My environment is:
- Windows 11 25H2
- TI C2000 Code Generation Tools v22.6.4.LTS
- Target device: TMS320F28379D
I first encountered this problem while building a PLECS-generated project. However, after further investigation, I confirmed that the issue is reproducible even when running cl2000.exe directly, without using PLECS.
Running the following command:
cl2000.exe test.c
causes the compiler to abort with:
INTERNAL ERROR:
cl2000.exe had an internal inconsistency and aborted
while processing file test.c
In some cases, a Microsoft Visual C++ Runtime Library dialog is also displayed with the following assertion:
Debug Assertion Failed!
File:
minkernel\ucrt\src\appcrt\convert\isctype.cpp
Expression:
c >= -1 && c <= 255
I have also confirmed the following:
- The same problem occurs with both CGT v22.6.1.LTS and v22.6.4.LTS.
- Reinstalling the compiler into a directory without spaces does not resolve the issue.
- The same problem occurs when building the official PLECS demo project.
- The issue is reproducible by running cl2000.exe directly, so it does not appear to be specific to PLECS.
Has this issue been reported before?
If so, is there any known workaround or recommended solution?
Thank you for your support.
Kosuke Mikawa
