Other Parts Discussed in Thread: TMS320F2812, CONTROLSUITE
Could you please help me in describing step by step procedure for generating a sine wave code in TMS320F2812.
Hello Sreekanth,
After a quick search of the forums I found the following posts with some great references and information. Hopefully these can help get you started:
Reference Sine and Triangular Carrier Wave
Sine-wave reference generation using math library
I used a search for "sine wave f2812", but other keywords may produce even more results.
Also, as mentioned in a few posts linked above, the Signal Generation Library found in the controlSUITE Libraries section is a great place to start. Notably the C28x Signal Generation Library User's Guide contains a section on sine wave generation and multiple examples of different sine wave configurations.
Hope these resources help,
Mark-
Thank you Mark. That helped me a lot.
One more question , How to access Sine wave look up Table from Boot Rom so that i can use it in my program?
I have seen it in this discussion Regarding 50Hz sine wave PWM! where F28335 was used.
But I am working on F2812. So where can i get Sine wave look up Table ?
Hello Sreekanth,
This post in particular should be helpful in this regard. The x281x Boot ROM Guide should be the only documentation difference for using the F2812 as opposed to the F28335. The other documents referenced in that post should still be relevant for your device.
Hope this helps,
Mark-
