Part Number: F29H859TU-Q1
Hi team,
I ask this for my customer.
My customer use FLASH API: Fapi_issueProgrammingCommand((uint32_t*) address, (uint8_t*) write_buffer, WRITE_SIZE_BYTES, 0, 0, Fapi_AutoEccGeneration, u32UserFlashConfig); to program the data flash, and they find if they write data 64bit, it will generates the ECC error; if they write data 128bit, it will not generates the ECC error.
Could you help to check if data flash supports a 64-bit write at once? What's the may reason cause ECC error when customer do a 64bit write?
BRs
Shuqing
