F29H850DM: TRM discrepancy
Part Number: F29H850DM
Looks like there is a discrepancy in the TRM for F29.
Please confirm this descrepancy; this customer is using RTDMA successfully, but this conflicts with the documentation:
Yes, your hardware observation is correct—CLB_DATA_EXCHANGE_REGS is accessible by RTDMA, and TRM Section 10.6 contains a documentation discrepancy inherited from legacy C28x devices.
Why Your Setup Works (Hardware & Bus Architecture)
  • Legacy C28x vs. F29x Architecture. On older C28x devices, the standard DMA controller did not have bus master access to the CLB registers, requiring workarounds like routing CLB data through the SPI RX buffer (which is still documented in Section 10.7 of the F29H85x/F29P58x Technical Reference Manual (SPRUJ79)). [1]
  • F29x RTDMA Peripheral Bus Access. On the F29x series, the new Real-Time DMA (RTDMA1 and RTDMA2) has direct peripheral bus access to CLB_DATA_EXCHANGE_REGS (CLB1_DATA_EXCHANGE_BASE through CLB6_DATA_EXCHANGE_BASE), allowing you to push and pull data directly between system RAM and the CLB FIFOs/pull-push registers at 6.75 Mbps without CPU intervention.
Documentation Discrepancy Breakdown
Document Section Status Details & Explanation
TRM Section 10.6 (RTDMA Access) Incorrect / Outdated States that RTDMA cannot access CLB registers directly. This text was carried over from C28x TRMs during IP reuse and was not updated when the F29x peripheral interconnect opened CLB_DATA_EXCHANGE_REGS to RTDMA1/RTDMA2.
TRM Table 10-21 (CLB Memory Map / Access) Correct Accurately reflects the hardware interconnect showing RTDMA read/write access permissions to the CLB_DATA_EXCHANGE_REGS frame.
Datasheet Table 7-28 (Peripheral Registers Memory Map) Correct Lists CLB_DATA_EXCHANGE_REGS with YES under the RTDMA1 and RTDMA2 bus master columns, matching the actual silicon behavior you verified on your evaluation kits.
