Other Parts Discussed in Thread: TMS320F28335
When Programming the TMS320F28335 in Flash Using On-Chip Flash Programming utility(CCSV3.3),the erase Operation is Interrupted so my CSM passwords are Corrupted.
I can't access the Flash as it is Locked.
But in System Control & Interrupts User Guide provided by TI it is mentioned that
If a device is reset while the password locations are all zero or an unknown value, the device
will be permanently locked unless a method to run the flash erase routine from secure
SARAM is embedded into the flash or OTP. Care must be taken when implementing this
procedure to avoid introducing a security hole.
Can any one know How to Implemet this method if you please help me
Thanks in Advance
Sadguna Rao.K
