Other Parts Discussed in Thread: ADS1672, TMS320C28346
I have modified the example code "Example_2834xMCBSP_DLB_DMA.c" of the TI Delfino TMS320C28346 to acquire the data from a Ti ADS1672 EVM at 625 KSPS at 24 bits per sample. I connect the ADS1672 to the McBSP of the TI Delfino and use the DMa for transfers of consecutive bursts of 1000 data points.
By sending a linear ramp, I have noticed that between two consecutive bursts, around 3 data points are lost. I do that by checking the last sample of the precendent buffer and the first sample of the current buffer.
It seems that the DMA takes around 5 us to set up (3*sampling rate). Is there a way for avoinding loosing these 3 data points. if you need, I can send the details about the connection of the TI Delfino EVM and the ADS1672EVM.
BEST
Daniele
PS:
My code is the following.
&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& CODE &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
// FILE: Example_2834xMCBSP_DLB_DMA.c
// TITLE: DSP2834x Device McBSP Digital Loop Back with DMA program
// ASSUMPTIONS:
// This program requires the DSP2834x header files.
// As supplied, this project is configured for "boot to SARAM"
// operation. The 2834x Boot Mode table is shown below.
// For information on configuring the boot mode of an eZdsp,
// please refer to the documentation included with the eZdsp,
// $Boot_Table:
// GPIO87 GPIO86 GPIO85 GPIO84
// XA15 XA14 XA13 XA12
// PU PU PU PU
// 1 1 1 1 TI Test Only
// 1 1 1 0 SCI-A boot
// 1 1 0 1 SPI-A boot
// 1 1 0 0 I2C-A boot timing 1
// 1 0 1 1 eCAN-A boot timing 1
// 1 0 1 0 McBSP-A boot
// 1 0 0 1 Jump to XINTF x16
// 1 0 0 0 Jump to XINTF x32
// 0 1 1 1 eCAN-A boot timing 2
// 0 1 1 0 Parallel GPIO I/O boot
// 0 1 0 1 Parallel XINTF boot
// 0 1 0 0 Jump to SARAM <- "boot to SARAM"
// 0 0 1 1 Branch to check boot mode
// 0 0 1 0 I2C-A boot timing 2
// 0 0 0 1 Reserved
// 0 0 0 0 TI Test Only
// Boot_Table_End$$
// DESCRIPTION:
// This program is a McBSP example that uses the internal loopback of
// the peripheral and utilizes the DMA to transfer data from one buffer
// to the McBSP, and then from the McBSP to another buffer.
// Initially, sdata[] is filled with values from 0x0000- 0x007F. The DMA
// moves the values in sdata[] one by one to the DXRx registers of the McBSP.
// These values are transmitted and subsequently received by the McBSP.
// Then, the DMA moves each data value to rdata[] as it is received by the McBSP.
// Three different serial word sizes can be tested.
// Before compiling this project:
// * Select the serial word size (8/16/32) by using
// the #define statements at the beginning of the code.
// The program loops forever after all values have been transferred to sdata.
// It is up to the user to stop the program.
// By default for the McBSP examples, the McBSP sample rate generator (SRG) input
// clock frequency is LSPCLK (150E6/4 or 100E6/4) assuming SYSCLKOUT = 150 MHz or
// 100 MHz respectively. If while testing, the SRG input frequency
// is changed, the #define MCBSP_SRG_FREQ (150E6/4 or 100E6/4) in the Mcbsp.c file must
// also be updated accordingly. This define is used to determine the Mcbsp initialization
// delay after the SRG is enabled, which must be at least 2 SRG clock cycles.
// Watch Variables:
// sdata
// rdata
// $TI Release: 2834x Header Files V1.12 $
// $Release Date: March 2011 $
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
// Choose a word size. Uncomment one of the following lines
//#define WORD_SIZE 8 // Run a loopback test in 8-bit mode
//#define WORD_SIZE 16 // Run a loopback test in 16-bit mode
#define WORD_SIZE 32 // Run a loopback test in 32-bit mode
#define BUFFER_SIZE 1000
// Prototype statements for functions found within this file.
//interrupt void local_D_INTCH1_ISR(void);
interrupt void local_D_INTCH2_ISR(void);
void mcbsp_init_dlb(void);
void init_dma_32(void);
void start_dma(void);
void error(void);
void init_buffer(void);
#pragma DATA_SECTION(rdata, "DMARAML4")
Uint16 rdata[2*BUFFER_SIZE]; // Recieved Data
Uint16 data_size; // Word Length variable
Uint32 rdata1_ext;
Uint32 rdata2_ext;
Uint32 buffer_act;
Int32 buffer[BUFFER_SIZE];
Int32 buffer_act_signed;
Int32 buffer_averaged[BUFFER_SIZE];
Int32 buffer_test[BUFFER_SIZE];
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initalize GPIO:
// Setup only the GP I/O only for McBSP-A functionality
InitMcbspaGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
EALLOW; // Allow access to EALLOW protected registers
PieVectTable.DINTCH2= &local_D_INTCH2_ISR;
EDIS; // Disable access to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2833x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
// Step 5. User specific code, enable interrupts:
data_size = WORD_SIZE;
init_buffer();
init_dma_32(); // DMA Initialization for 32-bit transfers
start_dma();
mcbsp_init_dlb(); // 2. Then initialize and release peripheral (McBSP) from Reset.
// Enable interrupts required for this example
PieCtrlRegs.PIECTRL.bit.ENPIE = 1; // Enable the PIE block
//PieCtrlRegs.PIEIER6.bit.INTx5=1; // Enable PIE Group 6, INT 5
// PieCtrlRegs.PIEIER6.bit.INTx6=1; // Enable PIE Group 6, INT 6
// PieCtrlRegs.PIEIER7.bit.INTx1 = 1; // Enable PIE Group 7, INT 1 (DMA CH1)
PieCtrlRegs.PIEIER7.bit.INTx2 = 1; // Enable PIE Group 7, INT 2 (DMA CH2)
IER=0x60; // Enable CPU INT groups 6 and 7
EINT; // Enable Global Interrupts
// Step 6. IDLE loop. Just sit and loop forever (optional):
for(;;);
// Step 7. Insert all local Interrupt Service Routines (ISRs) and functions here:
void error(void)
asm(" ESTOP0"); // Test failed!! Stop!
for (;;);
Int16 i;
for (i=0; i<BUFFER_SIZE; i++)
buffer_averaged[i] = 0;
void mcbsp_init_dlb()
McbspaRegs.SPCR2.all=0x0000; // Reset FS generator, sample rate generator & transmitter
McbspaRegs.SPCR1.all=0x0000; // Reset Receiver, Right justify word
McbspaRegs.MFFINT.all=0x0; // Disable all interrupts
McbspaRegs.RCR2.all=0x0; // Single-phase frame, 1 word/frame, No companding (Receive)
McbspaRegs.RCR1.all=0x0;
McbspaRegs.XCR2.all=0x0; // Single-phase frame, 1 word/frame, No companding (Transmit)
McbspaRegs.XCR1.all=0x0;
McbspaRegs.SRGR2.bit.GSYNC = 1; // FPER = 32 CLKG periods
McbspaRegs.SRGR1.bit.FWID = 0; // Frame Width = 1 CLKG period
InitMcbspa24bit();
//************* Enable Sample rate generator
McbspaRegs.SPCR2.bit.GRST=1; // Enable the sample rate generator
delay_loop(); // Wait at least 2 SRG clock cycles
//McbspaRegs.SPCR2.bit.XRST=1; // Release TX from Reset
McbspaRegs.SPCR1.bit.RRST=1; // Release RX from Reset
McbspaRegs.SPCR2.bit.FRST=1; // Frame Sync Generator reset
// DMA Initialization for data size > 16-bit and <= 32-bit.
void init_dma_32()
EALLOW;
DmaRegs.DMACTRL.bit.HARDRESET = 1;
asm(" NOP"); // Only 1 NOP needed per Design
// Channel 2, McBSPA Receive
DmaRegs.CH2.BURST_SIZE.all = 1; // 2 words/burst
DmaRegs.CH2.SRC_BURST_STEP = 1; // Increment 1 16-bit addr. btwn words
DmaRegs.CH2.DST_BURST_STEP = 1; // Increment 1 16-bit addr. btwn words
DmaRegs.CH2.TRANSFER_SIZE = BUFFER_SIZE; // Interrupt every 63 bursts/transfer
DmaRegs.CH2.SRC_TRANSFER_STEP = 0xFFFF; // Decrement back to DRR2
DmaRegs.CH2.DST_TRANSFER_STEP = 1; // Move to next word in buffer after each word in a burst
DmaRegs.CH2.SRC_ADDR_SHADOW = (Uint32) &McbspaRegs.DRR2.all; // Start address = McBSPA DRR
DmaRegs.CH2.SRC_BEG_ADDR_SHADOW = (Uint32) &McbspaRegs.DRR2.all; // Not needed unless using wrap function
DmaRegs.CH2.DST_ADDR_SHADOW = (Uint32) &rdata[0]; // Start address = Receive buffer (for McBSP-A)
DmaRegs.CH2.DST_BEG_ADDR_SHADOW = (Uint32) &rdata[0]; // Not needed unless using wrap function
DmaRegs.CH2.CONTROL.bit.SYNCCLR = 1; // Clear sync flag
DmaRegs.CH2.CONTROL.bit.ERRCLR = 1; // Clear sync error flag
DmaRegs.CH2.DST_WRAP_SIZE = 0xFFFF; // Put to maximum - don't want destination wrap
DmaRegs.CH2.SRC_WRAP_SIZE = 0xFFFF; // Put to maximum - don't want source wrap
DmaRegs.CH2.MODE.bit.CHINTE = 1; // Enable channel interrupt
DmaRegs.CH2.MODE.bit.CHINTMODE = 1; // Interrupt at end of transfer
DmaRegs.CH2.MODE.bit.PERINTE = 1; // Enable peripheral interrupt event
DmaRegs.CH2.MODE.bit.PERINTSEL = DMA_MREVTA; // Peripheral interrupt select = McBSP MRSYNCA
DmaRegs.CH2.CONTROL.bit.PERINTCLR = 1; // Clear any spurious interrupt flags
EDIS;
void start_dma (void)
EALLOW;
// DmaRegs.CH1.CONTROL.bit.RUN = 1; // Start DMA Transmit from McBSP-A
DmaRegs.CH2.CONTROL.bit.RUN = 1; // Start DMA Receive from McBSP-A
EDIS;
// INT7.2
interrupt void local_D_INTCH2_ISR(void) // DMA Ch2
Uint16 i;
EALLOW; // NEED TO EXECUTE EALLOW INSIDE ISR !!!
DmaRegs.CH2.CONTROL.bit.RUN = 0; // Re-enable DMA CH2. Should be done every transfer
PieCtrlRegs.PIEACK.all = PIEACK_GROUP7; // To receive more interrupts from this PIE group, acknowledge this interrupt
for (i = 0; i < BUFFER_SIZE; i++)
buffer_test[i] = buffer[i];
for (i = 0; i < 2*BUFFER_SIZE; i = i + 2)
rdata2_ext = ( (Uint32) rdata[i] );
rdata1_ext = ( (Uint32) rdata[i + 1] );
buffer_act = ((rdata2_ext<<16) | rdata1_ext);
buffer_act_signed = ((Int32) buffer_act);
buffer_act_signed = (buffer_act_signed<<8);
buffer_act_signed = (buffer_act_signed>>8);
if (i==0)
{buffer[i] = buffer_act_signed;}
else
{buffer[i>>1] = buffer_act_signed;}
buffer_averaged[i] = buffer_averaged[i] + buffer[i];
EDIS;
return;
// No more.
