Hi guys, I was debugging my F28027 and while the JTAG integrity test passed, the code I was gonna load into it returned this:
C28xx: Flash Programmer: Warning: The configured device (TMS320F28027), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed Software Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.520.0)
C28xx: Trouble Reading PC Register: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.520.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.520.0)
C28xx: GEL: Error while executing OnReset(1): target access failed.
C28xx: Flash Programmer: Error erasing flash memory. Device is locked or not connected. Operation cancelled
C28xx: Flash Programmer: Error erasing Flash memory.
C28xx: Error resuming a profile counter: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.520.0)
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f6215 on Page 0 of Length 0x16: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.520.0)
C28xx: GEL: File: C:\TI\controlSUITE\development_kits\Piccolo controlSTICK\Timer - BlinkingLED\F2802x_FLASH\BlinkingLED.out: Load failed.
I did more reading on the datasheet, and figured out that the TRST pin needs to be pulled down. I did that, but still the same results. Is there anything else I need to cover?
Thanks guys.
