Other Parts Discussed in Thread: TMS320F2812
Greetings !
I'm currently using "Flash2812_API_V210.lib" within my embedded code (TMS320F2812 MCU) for flash erase needs.
Q1: Is it possible to perform flash erase from within the embedded code, WITHOUT using "Flash2812_API_V210.lib"?
Q2: Can you provide source code for this library ("Flash2812_API_V210.lib")?
Q2: Is there any design reference or technical documentation that describes the key sequence to be performed for erasing F2812 micro controller, if I decide to write my own code for flash programming needs.
Kindly suggest !
Thanks a ton,
Ravi
