Other Parts Discussed in Thread: CCSTUDIO, CONTROLSUITE
Hello
I am new to the CCS environment and know hardly anything about TI's DSP
Processor. Hence I tried dumping the code using MATLAB's C2000 embedded target
toolbox. I have installed in my computer CCSv3.1, CCSv3.3 and CCSv4 with Matlab R2012a.
I have installed all the 3rd party tools required but cant still configure correctly.
when i run the configuration for CCS v4
checkEnvSetup('ccsv4','f2803x')
1. Checking CGT (Texas Instruments C2000 Code Generation Tools) version
Required version: 5.2.1 to 5.2.3
Required for : Code generation
Your Version : 5.2.1
### Setting environment variable "C2000_CGT_INSTALLDIR" to "C:\Program Files\Texas Instruments\C2000 Code Generation Tools 5.2.1"
2. Checking DSP/BIOS (Real Time Operating System) version
Required version: 5.33.05 to 5.41.09.34
Your Version : 5.33.05
### Setting environment variable "CCSV4_DSPBIOS_INSTALLDIR" to "C:\CCStudio_v3.3MCU\bios_5_33_05"
3. Checking XDC Tools (eXpress DSP Components) version
Required version: 3.16.02.32 or later
Your Version : 3.22.01.21
4. Checking CCS (Code Composer Studio) version
Required version: 3.3.83.11
Required for : Automation and Code Generation
Your Version :
Incompatible version detected. CCS version does not satisfy product requirements!
5. Checking 2803x C/C++ Header Files version
Required version: 1.21
Your Version : 1.21
### Setting environment variable "DSP2803x_INSTALLDIR" to "C:\ti\controlSUITE\device_support\f2803x\v121"
6. Checking Flash Tools (TMS320F2803x Piccolo(TM) Flash API) version
Required version: 1.00
Required for : Flash Programming
Your Version : 1.00
### Setting environment variable "FLASH_2803X_API_INSTALLDIR" to "C:\ti\Flash28_API\Flash2803x_API_V100_CCS3.3v"
in point 3 it does not recognize the latest CCS installed. And then when I run the configuration for CCS v3.3, it does not recognize the tools installed or CCS, even as shown previously, they are correctly installed.
Your Version :
Incompatible version detected. CGT version does not satisfy product requirements!
Required for : Real-Time Data Exchange (RTDX)
Your Version :
Incompatible version detected. DSP/BIOS version does not satisfy product requirements!
3. Checking CCS (Code Composer Studio) version
Your Version : 3.1.0
4. Checking 2803x C/C++ Header Files version
Your Version : 1.21
5. Checking Flash Tools (TMS320F2803x Piccolo(TM) Flash API) version
Your Version : 1.00
Could you point me in the right direction please?
thank you
