Regarding eZdspf28335
Other Parts Discussed in Thread: CCSTUDIO, TMS320F28335
hello,
I am Naveen Rangu,Doing Bachelors of Engg.I am doing a project which is control application.So i am using ezdspf28335 kit.AS i am new to this i do not understand how to do programming,checking output by using ports.I installed CCStudio_v3.3.Plese help me to start working on the kit.and also kindly suggest me to follow which Reference guides.i studied CCStudio getting started.plase help me.u feel that I dont know any thing and help me out in that way.HOW to start,How to RUN,How to Load,How to Check port outputs using oscilloscope. etc...
  • Here is the product folder for the device you are using, this is where most everything you need can usually be found
    http://focus.ti.com/docs/prod/folders/print/tms320f28335.html
    getting started
    http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=spraam0a
    http://focus.ti.com/mcu/docs/mcuproductcontentnp.tsp?sectionId=95&familyId=916&tabId=2288
    Install Header Files
    http://focus.ti.com/docs/toolsw/folders/print/sprc530.html
    then look here
    C:\tidcs\c28\DSP2833x\v131\DSP2833x_examples
    there are also some good videos and different software examples for other F28335 kits here (look at Peripheral Explorer)
    http://focus.ti.com/mcu/docs/mcuprodmsptoolsw.tsp?sectionId=95&tabId=1222&familyId=916&toolTypeId=1
  • Hi ChrisClearman,
    Thank you for your Information.i gone through these links,and also studied some important documents.But I am unable to doing the coding in CCStudio_v3.3.actually I am having background of electrical Engg.suddenly i am not cope with this microcontrollers,DSP and coding part.when i am coding facing some problems like header files and linker command files are not including even i use them in # include files.Please  help me out.please give me some more advices..
    NAVEEN RANGU
  • As Chris suggested, first install the appropriate header files. Once header files are installed go through one of the example projects to better understand the setup. These example projects will not need you to change anything and therefore you will not have any missing file situation.
  • thank you arefeen mohammed.
    now i am practicing the examples.getting understanding
