Hi Community,
I'm looking for a PC debug possibility for the IQmath Library. The C64x set contain a special Library for PC debug. Is there a similar Library for the C28x set?
Thanks in advance!
Hi Community,
Thanks in advance!
I know this is an old post, but I am also looking for a C28x IQmath library that will compile on a PC. Does this exist?
Jeff
Thanks for the update Lori. What if I used the C64x PC version? Are they functionally equivalent? If the error between the C28x (running on a C28335) and the C64x (running on a PC) is relatively small, I would consider using it. The alternative I'm faced with is manually writing the entire library and tediously comparing my results to the actual C28x library.
Jeff
Jeff Tackett said:Thanks for the update Lori. What if I used the C64x PC version? Are they functionally equivalent? If the error between the C28x (running on a C28335) and the C64x (running on a PC) is relatively small, I would consider using it. The alternative I'm faced with is manually writing the entire library and tediously comparing my results to the actual C28x library.
Jeff
Jeff,
Unfortunately I don't know the answer to that question. As far as I know, nobody has done that particular comparison. I wish I could provide a better answer.
-Lori
