Other Parts Discussed in Thread: CONTROLSUITE
Where I can obtain schema of "F28069 Piccolo controlCARD" to reduce hardware design time after creating solutions on design board?
Schematics can be found in the controlSUITE content management software download.
I downloaded controlSUITE and installed it. In directory C:\tidcs\TI_F28xxx_SysHW\ there are some directories with schemas all other cards:
CC2802xHWdevPkg ("CC2802x(Picc-A)-R1-SCH.pdf" )
CC2803xHWdevPkg ("F2803xcontrolCARD-SCH[R1].pdf" )
CC280xxHWdevPkg ("F28044controlCARD-Schem[R1.4].pdf" , "F2808controlCARD-Schem[R1.4].pdf" )
CC2833xHWdevPkg ("F28335controlCARD-Schem[R1.2].pdf" )
CC2834xHWdevPkg ("CC2834x-DIM100_SCH_V0_11.pdf ")
DIM168CC2834xHWdevPkg
DIM168DockingStn-HWdevPkg
DockingStn-HWdevPkg
But there is not F28069.
I believe you are looking at an older package of hardware that isn't controlSUITE. F28069 controlCARD should be in controlSUITE.
By default, controlSUITE usually installs to
C:\TI\controlSUITE\
can you take a look to see if the schematic is there (within application_kits\~controlCARDs\)
Thank you,
Brett
