How to enable Floating Point Support? - F28335
Hello all,
I have been able to successfully connect to my F28335 board, compile code, load, etc.. One thing I wanted to do was to make sure that the FPU code generation was enabled. I found some steps to do so however one thing goes beyond my knowledge. In the document DSP2833x_HeaderFiles_QuickStart_Readme.pdf it mentions to go to
a. Go to Project->Build Options.
b. In the Compiler tab window, click on the “Advanced” category and select “None”
from the “Floating point support: ” pull-down menu OR remove:
--float_support=fpu32 from the textbox at the top of the window.
The problem is that in the PDF they show a drop down menu for Floating point support None/On. However in my CCS 3.3.82.13 I do not even have this drop down menu or text. Here is additional information from the About Box:
Integrated Development: 5.98.0.393
Code Generation Tools v4.1.3
Board Revision 0.0.0
Target Silicon Revision 0.0.2
Any help is appreciated.
Josh
