Other Parts Discussed in Thread: TMS320F28334, CCSTUDIO
Hello all,
I'm starting with CCS 3.3. Where I can find DSP/BIOS configuration (CDB file) for TMS320f28334?
Regards.
Hello all,
Regards.
look in help----> contents----->dsp/bios, there are examples, but you're gonna have some problems if you don`t have settle ths bios in the variable environment. check here http://www.cs.usask.ca/~wew036/latex/env.html, note that the dsp/bios have two "//", you're gonna erase one. Before to do this you have to close ccs. hope this help you.
The problem is that I do not have f28334 CDB file when I choose File->New->DSP/BIOS Configuration from the CCStudio menus. I see EZDSP2808 and EZDSP2812 files.
ok, do you enter to the setup code composer? you have to select your plataform.
When you install your product, you'll see code composer v3.3, f28334 ezdsp and setup code composer. 3 icons.
the other thing, when you enter to code composer studio, select dsp/bios---->new.., you have to select again your plataform.
