Hi Folks,
I am aware that the PWMxB channel of a C2000 Piccolo when in HRPWM mode is not specified as a valid output with regard to the HR waveform, unless configured to be the inverted form of the PWMxA channel. However, having observed the operation of the demo code on the scope I note that the PWMxB channel does seem to have a signal on it, it would seem to be a similar signal to that on PWMxA, varying in related fashion. However, I note that it's of a different duration.
What is the definition of the signal that shows on PWMxB when in HRPWM mode? Does this signal have a formal definition or it just an escaped internal signal of multitudinous possible definitions? IF I knew that it had a formal definition related to the HRPWM on PWMxA, I may be able to use it...
Cheers
Rob
