Other Parts Discussed in Thread: TMS320F28035
Dear friends,
Is it possible to run TMS320F28035 orTMS320F28027 using simulator in Code Composer Studio 5.3.0.00090?
Best regards
Ricardo
Dear friends,
Best regards
Ricardo
Ricardo,
I checked and it appears that there is a CPU cycle accurate simulator for F283x devices. Given that the core and instruction set are similar between these devices I would think that you could simulate 35 or 27 code on this. The only difference I can think of is that the simulator will have floating point support.
To use the simulator:
Create a new target configuration
Select "Texas Instruments Simulator" as your connection
Select "F283x CPU Cycle Accurate Simulator" as your device
Save the configuration, Launch the configuration and debug as you normally would.
Trey
