Other Parts Discussed in Thread: TMS320F28027, TMS320F28035, CONTROLSUITE
Where can i find the schematic library and a pcb footprint of SM320LF2407A for altium designer.
Thank you
Praveen M
Thank you
Praveen M
Praveen,
Unfortunately, we do not have a readily available LF2407A schematic/design for you to use. I can recommend taking a look at the LF2407A eZdsp board as a reference to look at:
http://c2000.spectrumdigital.com/ezlf2407a/
I also wanted to inform you that the 'LF2407A is not recommend for new designs. If your project is a new design, a TMS320F28027 or TMS320F28035 might be a good replacement.
Thank you,
Brett
Dear Brett
Thank you for your reply. Can i use SM320F2808PZMEP instead ? It satisfies the temperature and I/O requirement. But i cant find a schematic library and pcb footprint in Altium Designer.
Praveen M
Praveen,
Sure, you can use the 'F2808. Only you know your full set of requirements. :) The 'F2808 does not have the same concerns with regard to product lifetime.
Schematics and hardware design files can be found for the F2808 eZdsp:
http://c2000.spectrumdigital.com/ezf2808/
Note that tools like Altium can usually import other CAD design tools like OrCAD.
(note that for other C2000 devices, like the Piccolo or Delfino series, you can use the controlCARD as a reference. This data is found for free in controlSUITE)
Thank you,
Brett
