Other Parts Discussed in Thread: CONTROLSUITE
Is there a register that needs to be set up before branching to SCI_boot beyond turning off the watch-dog and interrupts, i.e. setting up an entry point register or something? Why does the f2808 dsp using the SCI-GPIO boot behave any differently than branching directly to the SCI_boot address. Case in point, using C2Prog with SCI-GPIO boot works perfect, but after branching fom Flash it gets hung up halfway into the SCI bootloading process after successful autobaud (during one of the Uint16 SCIA_GetWordData() routine calls).
thank you for your help!
FYI:For branch from Flash to SCI boot process please see e2e forum http://e2e.ti.com/support/microcontrollers/c2000/f/171/p/244450/858111.aspx#858111
