Other Parts Discussed in Thread: CONTROLSUITE
hey
I am using customized board of F28335 running at 24.576 MHz. The program takes the data from serial port at 9600kbps from the sensors. Same program is running fine from Ram but it doe not work from flash. If I omit the line in which program takes the data from serial port and give constant values, the program works fine. Any help is highly appreciated.
Kind Regards,
