System(CPU) timer issue in F2808
I am trying to use CPU timer 0 of F2808 .but i'm unable to make it work.can anyone help me out and explain how to use the timer 0 (concept of timer).
Sanath Rai
    Sanath Rai
    The CPU timer is just that - a counter that counts based on some parameters you set like how often it resets and what the period is.
    The CPU timer for 2808 is documented in www.ti.com/lit/SPRU712
    -Lori
  • Hello Mam,
    Thank you for the guidance and suggestion.I'll go through the doc and make it work.
    Sanath Rai
  • Hello mam,
    i'm using CPU timer 0 which is working fine.
    now the issue is regarding  ConfigCpuTimer(&CpuTimer0,Freq,Period);
    i need the interrupt to cause for maximum delay say for about  5 seconds.How to configure it ?
    (i hope you got the point.i'm trying to say that i'm using CPUtimer 0 to blink an LED.i have wrote the code in cpu ISR for blinking.i want it to blink for 5 seconds.that means interrupt (timer)should be called for 5 seconds ).
    please help
    Thanks and Regards,
    Sanath Rai
