PWM problem in delfino 28335
Other Parts Discussed in Thread: CONTROLSUITE
Hello all
i want to ask about few things regarding epwm channels of delfino..
1. How much low frequenc can we achieved by using epwm modules as TBCRD is a 16 bit counter but when i load 65530 in it, i dont get any response on pwm lines...
similarly when i load values greater then 10000 i dont get any response... what is the problem in it??
regards
salman
  • Salman,
    If the SYSCLK frequency of your F28335 device is 150MHz, the slowest possible clock frequency is:
    150MHz / 65535 / 2 = 1.144kHz (the divide-by-2 factor exist if you have configured your PWM to be in up-down count mode)
    Without more information I am unsure what your exact problem is.  I would recommend continuing to experiment and, if you haven't already, take a look at some of the PWM examples in controlSUITE.
    Thank you,
    Brett
