SCIB on the 28069
Other Parts Discussed in Thread: CONTROLSUITE
We are having a problem running the SCIA example modified to run with SCIB port. We have changed all references from Scia to Scib and also called ScibGPIOInit instead of SciaGPIOInit. Still  there is no output from SCIB. We are using GPIO22 and GPIO23, we have modified the GPIO init routine accordingly.
Most of the times the send byte function hangs at the place where it waits for transmit to end. Some times it comes out but there is no output on the TXB pin as seen in a scope.
We tested with a ControlCard and docking station - still same result.
What could be the problem?
Situation urgent since we are in the board testing stage now.
