28335 Flash Problem
       We are using f28335 processor and Code Composer Studio v3.3. When we tried to do On-chip flash programming after including the Non-Bios flash command file, the chip got locked. On retry, it required a password for unlock. On giving 0xFF, it was not accepted.On compiling the code, there was this warning appearing:
"One or more sections of your program falls into memory region that is not writable. These will not actually be written to the target. Check your linker configuration and/or memory map
The code did not run from flash and the chip is getting locked every time. Is there any Tech support for TI in Chennai to help us out?! We would like to contact the concerned technical person in this regard.
Thanks in advance..
