F28M36 XCLKCFG register
Other Parts Discussed in Thread: F28M36P63C2
Hi Team,
For the F28M36P63C2, I can not find the definition for the XCLKCFG register referenced in both data-sheet and TRM
"External oscillator output.  This pin outputs a clock divided-down from the internal PLL System Clock at XCLKOUT PF2_GPIO34. The divide ratio is defined in the XCLKCFG register ."
I believe this is a typo and should read "XPLLCLKCFG" instead.  I see the same issue with F28M35 TRM.
Can someone confirm?
Thank you in advance,
Juan
